#401 |
Re: 1952 Chevy Vette Roadmaster LT1 Farm Truck Build
I'm a welder by trade. Heading to my site and I got to read about half your build. Can't wait to get home and really look at this thing. Beautiful
2010 dodge 3500 dually (Cummins tow pig) 2010 CTS-V 2003 TT 03 Cobra The BUILD!!! 1955 GMC series 1 This build is a wedding present to my soon to be wife. She has no clue. But I'm building her dream truck and hands down one of my favorite vehicles of all times. |
#402 | |
Simple? What's simple?
![]() Join Date: Apr 2007
As to the hydroboost - it's got some benefits, as far as being physically smaller unit, and having a more consistent pedal feel (especially if you had a lumpy cam and little vacuum) - but it's a bunch of extra plumbing. I did it on my '72 K3500 build, but I personally wouldn't ever do all that extra plumbing on a street car unless it was turbo.
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
#403 | |
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
#404 |
Had a night off of hockey so one of my young lads and I headed out to the barn and installed the Vette suspension and placed the engine to see how the milled Camaro manifolds fit. As you can see, no go unless I modify the frame. Will have to wait and see how the Hooker LS manifolds fit up.
![]() Here you can see the rack clearance I have between oil pan and crank pulley. I may have to raise the engine a bit and use F body accessories to move things closer to the engine for rad clearance. Man.... all these little things are starting to $$$$$. ![]() Here you can see how low the truck oil pan hangs below the cross member. I will have the F body pan here shortly. ![]() ![]() And an overall shot of how things are sitting. ![]()
#405 | |
On the rack, your pan and pulley clearance looks okay (since the rack is stationary), but would there be interference between the PS pump and the input on the rack? Just from my view, that looks like the biggest hurdle to overcome. All of the factory LS bracketry has something in that spot, except the 'vette.
#406 |
Hey nice "rollers"
I am having the same problem with the PS pulley and rack input port, maybe a smaller pulley on the pump. I did have to lower the rear trans mount to get clearance but now I am concerned about the drive shaft angle, how much angle are you running on your D/S
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#407 |
![]() Join Date: Jul 2012
Well, I was hoping the exhaust manifolds would fit after the modification. Ugh. Hopefully the Hookers will. Always something.
#408 |
Try also BBK - they make the most compact shorty headers I have ever seen and decently priced.
My Build: 57 Chevy Pro-Street |
#409 |
JJ - I will get some better pics tonight after hockey. I have the pump but it's filthy and will clean it up and see if I have any issues. Got me worried now.
Solid - You copy cat! LOL! My engine is 3* down and rear is 3* up. AD - It sure is always something. If it's not that its $$$ ptc - thanks for the BBK info. Will look into them if my hookers don't fit.
#410 |
Went down to the barn after hockey and did some figuring. I installed the PS pump for ya solid to see my setup. I tightened down the 2010 Camaro exhaust manifolds as they were loose as the bolts are now too long. They fit much better. The drivers side clears but the passenger side is still a bit too close to the frame rail. A little more angle milling and it will work. Still hoping the Hooker manifolds fit better. On with the pictures.
#411 |
#412 |
#413 |
Your getting there
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#414 |
looks great. Do they make a remote PWS set up like they do for racecars? be interesting to see if any are available for situations like this.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#415 | |
![]() I think any 'block hugger headers' will work better than your stock ones....
#416 |
#417 |
#418 |
A few of the new oil pan. Thing is pretty heavy! There's a lot of casting flash in side and out. I'd like to smooth it up a bit. Good idea or not? Gasket is riveted on the pan in two places. Worried about filings and such>
#419 |
The header looks pretty tight on the right side. May be the angle of some of some of the pictures? If you want to clean up casting flash you can drill the rivets to move the gasket out of the way and to allow for cleaning.
#420 |
The flange is higher above the frame than the Camaro manifold. They tuck in a bit more than the Camaro manifolds after being angle milled. The engine is centred. I will get a few more pics.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() Last edited by FarmerSid; 11-26-2015 at 09:07 PM. |
#421 |
thanks for the pics. I'll be starting an LS engine in and OG frame for a guy real soon. Ordering parts while they are on sale. So this info is gonna help!! What pan did you go with? I see you posted the numbers. I'd clearance every bit you can put some tape around the whole top of the gasket and pan if you are that worried, which I wouldn't be. Just clean it good.
#422 |
No problem 99! The pan is for a 98-02 F-body Camaro. GM part# and part. Truck pan hangs way lower than the cross member. These pans are pricey as everyone wants/needs it for a lot of LS swaps. I think I got lucky and found a brand new one for $215 US shipped to the Canada/US border. It came with some extra parts that are needed for the swap.
#423 |
You could always tape up the gasket to keep it clean. Manifolds look like they should work.
#424 |
Had a rare day off so I worked on cleaning up the casting flash on the f body oil pan and installed it.
![]() ![]() Shortened the truck windage tray and modified it for the pickup tube. ![]() ![]()
#425 |
