Old 01-17-2010, 07:21 PM   #426
Sub-versive
Boss Hogg
Sub-versive's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Originally Posted by Twisted Minis View Post
Looking awesome.
Keep it up!!!
Sub-versive is offline   Reply With Quote
Old 01-17-2010, 10:43 PM   #427
tdave00
Restoring a 68 SWB
tdave00's Avatar
Serious attention to details on those gauges. Great job.
tdave00 is offline   Reply With Quote
Old 01-18-2010, 02:25 PM   #428
Mil-Spec
Mil-Spec's Avatar
Originally Posted by Frizzle Fry View Post
Hey there Mil-spec. First, Thanks Second, why would anyone switch from Air Force to Navy???
Other functions of the PCB. Yes, I plan to build a board to remote mount many of the indicator LEDs and LCD.
I will mount the PCB high under/behind the dash inside the plastic enclosure. It has fairly flat front/back covers. The front cover includes the Acura gauge faces that no one will see.
The 9-pin DSUB connector (often used for RS-232) mounted to the board is not the one shown in the vice with soldered wires (that's the gauge side). The one on the board has crimped/inserted pins and a plastic section/pin-housing protruding from the back side, which is what comes close to touching the PCB but is actually held off the board by the stand-offs.
I'll get some close-up shots of that for ya.
[QUOTE=Frizzle Fry;3738211]Here you go Mil-spec. What do you think?
Looks good. Please I hope you don't think I'm being too anal. I really like what you're doing a lot and don't want you to have any problems. I work in development, prototyping and PCB design, so my kids can eat (by no means an expert though)
The only immediate potential issue I see is where the standoffs interface with the PCB. The solid green areas where the standoffs are resting on are copper plains. I have no idea without looking at a schematic, if the 2 planes are electrically the same, or what. You could trace the plains back to a component with an exposed solder joint and using an Ohm meter, see if they are the same potential or shorted to each other. If they are NOT, then the metal standoffs and metal connector case would provide a shorting path from one plain to the next if the solder mask were to be comprimised. Couple things you could do (if you want), replace the stand-offs with a non-feris type or plastic hardware. Or isolate the existing stand-offs with a material like mylar or some sort of plastic sheet under them. (I like to use old coffee can lids because they are flat and can be trimmed to whatever you want. ** also as expoxy forms because the 2 part I use won't stick to it**).
Another possiblity might be to locate an appropriatly sized enclosure to house the PCB (Mouser or Digi-Key or some similar online place). With the PCB ridgidly mounted, you could use panel mount I/O connectors mounted in the enclosure itself and that would help protect the board from Vibration at the connection points. If grounded properly, then from noise as well(I didn't even want to get into injecting noise in the plains). Depending on the enclosure selected, might make easier to install in the Minx.
Hopefully that wasn't too Nerdy. I you need more clarification, let me know.
I had fun in both services
SEMPER FORTIS
U.S. NAVY 97-05
USAF 94-97
Mil-Spec is offline   Reply With Quote
Old 01-19-2010, 12:24 AM   #429
Frizzle Fry
Frizzle Fry's Avatar
Too nerdy??? We are well beyond that!
Thanks for the suggestions. The the holes I put the standoffs in were pre-existing with metal screws holding the needle actuator at that position. I think I'll take your advice and add some plasic washers anyway.
Frizzle Fry is offline   Reply With Quote
Old 01-19-2010, 08:53 AM   #430
Mil-Spec
Mil-Spec's Avatar
No prob.
If that is the case, then it maybe that the 2 plains are the same potential and you'll be fine. It's hard to tell, not having the board in front of me. What your doing looks sound, I was just looking at it from longevity stand point if you planned to drive it hard or AutoX the car, but I'm sure you'll baby it like a Grandma right? Hopefully not with the redline that engine has. (I've breifly entertained the idea of mating a Honda engine to the transaxle in my wife's Corvair)
Regarding your LCD package, are you planning on desoldering it and relocating or getting another display and jumpering onto the thru-hole leads on the secondary side of the board?
SEMPER FORTIS
U.S. NAVY 97-05
USAF 94-97
Old 01-19-2010, 11:38 AM   #431
Slick17
Slick17's Avatar
Man I have to say. That thing is awesome. Great job.
05 Chevy 3500 Crew Cab Dually
Sold 1984 Custom Deluxe K/30, 350 SBC with 4 Speed, 6" Lift, 35" Boggers, Headmen Headers, Custom Full 3" Dual Exhaust, Qualitex Buckets with Flip Center Console
Slick17 is offline   Reply With Quote
Old 01-19-2010, 04:05 PM   #432
Frizzle Fry
Originally Posted by Mil-Spec View Post
No prob.
...if you planned to drive it hard or AutoX the car, but I'm sure you'll baby it like a Grandma right?
It will be autox'ed and driven hard
The LCD contacts are just pressed in so it's easy to remove. I am planning to simply solder leads between the back of the board and the LCD contacts with another DSUB arrangement in between.
Thank you!
Old 01-19-2010, 09:06 PM   #433
Mil-Spec
Mil-Spec's Avatar
I look forward to watching your progress. I'm curious how do you plan to resilkscreen the Tach?
SEMPER FORTIS
U.S. NAVY 97-05
USAF 94-97
Old 01-19-2010, 10:31 PM   #434
JRBECK64
Frizzle,
I didn't know they made a Chevy Sunbeam!!! This thing looks like its going to fly.
JRBECK64
JRBECK64 is offline   Reply With Quote
Old 01-20-2010, 03:40 PM   #435
Frizzle Fry
Gauge shops can do it. Here's one example.
Originally Posted by JRBECK64 View Post
Frizzle,
JRBECK64
You can make anything a Chevy! But this one has zero Chevy blood. Well, I did use a section of Chevy inner fender...
Old 01-21-2010, 12:19 AM   #436
ed2552
ed2552's Avatar
Umm, wow is all I have to say. This car is going to be one of a kind, and friggin amazing at that. Good luck with the rest!!!!
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 02-01-2010, 10:30 PM   #437
Frizzle Fry
Thanks Ed
I've made some serious progress with the DS inner fender and frame rail. Same deal as the other side so I'll post pics when it's further along. I did get the itch to ditch the honda logo and VTEC lettering from the coil cover. Here's the direction I'm going with it (script is just sitting on there for now):
Old 02-02-2010, 12:07 AM   #438
VA72C10
VA72C10
VA72C10's Avatar
Nice!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-02-2010, 12:21 AM   #439
dammitmitchell
the pollock
dammitmitchell's Avatar
sick sense of humor.. but i like it!
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 02-02-2010, 12:29 AM   #440
nuke1
nuke1's Avatar
Frizzle, that car is coming along nicely, way prefer the sunbeam wmblem over the V=TEC emblem. i SURE WISH THAT I NEVER SOLD MY s-2000 now. I had plans for it but needed the money. darn it. Darn caps lock also. to lazy to fix it.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-02-2010, 02:13 AM   #441
watahyahknow
watahyahknow's Avatar
looks realy nice even kindof era correct maibe you be able to find a metal oilcap too or make a sunbeam medalion over it
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-02-2010, 12:51 PM   #442
Mil-Spec
Mil-Spec's Avatar
Really nice touch with the emblem. Any other thoughts on giving the engine a Sunbeam retro look?
SEMPER FORTIS
U.S. NAVY 97-05
USAF 94-97
Old 02-02-2010, 01:03 PM   #443
kyull67
kyull67's Avatar
Nice!!!
kyull67 is offline   Reply With Quote
Old 02-02-2010, 03:34 PM   #444
Frizzle Fry
Yeah, wherever possible. ITB's would be a nice, yet expensive, touch. I'll probably do some satin black on some parts too. The valve cover itself will either be satin black or body color. Get rid of the plastic fuel rail cover, etc.
Old 02-02-2010, 03:59 PM   #445
thor
thor's Avatar
The 'Sunbeam' script is waaay better looking! Nice touch.
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 02-02-2010, 07:41 PM   #446
Mil-Spec
Mil-Spec's Avatar
FF I'm sure whatever you do will be epic as with the rest of the car. The only reason I asked was the oil cap looked Fugly when next to the Sunbeam script.
But now that you mention it a pair side draft Webers style TBs would look choice
SEMPER FORTIS
U.S. NAVY 97-05
USAF 94-97
Old 02-02-2010, 09:09 PM   #447
Frizzle Fry
Good call on the oil cap. I'll have to find something better...
Old 02-02-2010, 09:56 PM   #448
watahyahknow
one of those round metal ones should fit nicely ......... sumtin like this one : http://www.kreidlerdatabase.nl/Afbee...egraaf%205.jpg (this is a gascap of a moped ) might be one on the original motor that came out the car , might be nice to cadmium plate some of the realy small parts too that gives the metal a greenish brass colour , they do that kindah stuff to carburators linkages a lot
Old 02-10-2010, 07:28 PM   #449
jb1016
"Oh well, it's a driver."
jb1016's Avatar
It took a lot to get that bezel on there, but it was worth it. There is no lense in the pics. I need to have one cut because the fuel gauge lense was too small. I still need to mod the needle to resemble the others and get rid of the dolphin logo.
It's the little perfectionist touches like this that keep me hooked on your build threads, FF. The script on the valve cover is a nice touch too.
Old 02-10-2010, 08:40 PM   #450
Frizzle Fry
Thanks man!
I did some more clean up/wire-tucking on the engine. Permenantly afixed the sunbeam script (was just posed in the previous pics), and finally got the right length serp belt to run with A/C delete.
Most importanlty, the frame rails are 99% done! Just a bit of clean up left to do and I'm on to the rest of the build.
