Old 08-07-2013, 02:56 PM   #426
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Project Family Chummins
Sounds like some good work going on. Do you plan on taking it to the Nats in September?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-08-2013, 12:28 PM   #427
Ackattack
Ackattack's Avatar
I don't know. I'm planning on taking my 68, but I could bring both. It's only about an hour drive. I might have to show my wife how to drive it (she can drive stick, but its not quite a just hop in and go type of ride
Ackattack is offline   Reply With Quote
Old 08-08-2013, 03:47 PM   #428
Dieselwrencher
Cool deal. I look forward to seeing you there.
Ryan
Old 08-08-2013, 11:34 PM   #429
Ackattack
Ackattack's Avatar
Me too
I got a few things accomplished. Not everything I wanted, but a good chunk.
First I got the truck lowered. Its only an inch an a half, but I think it makes the truck look better since it sits level now.
Before:
After:
To lower the truck, I just had to unbolt the spring hangers and move the buckets up. That part was pretty easy with all the steering links out of the way. Then I had to make room for the panhard bar. I used a piece of 3 inch sch 40 pipe and C-channeled the crossmember....kinda of lowrider style
With this done I have about 3" of compression until things start hitting so I made some brackets for my bumpstops I've had for awhile and set them at 2-1/2" so they'll hit first. If I need to, I can lower them down a little also. I tried to flex the suspension to see how things would be at extremes, but the front springs are so stiff compared to the rear, I could only get ~1/16" of compression with my jack nearly maxed out (no wonder it feels fine without a front swaybar)
Then I moved on to "installing" my steering stabilizer. This required making a bracket under the panhard bar mount and using a tube clamp and making a bracket off of it.
Finally I moved on to installing my near gear box. Straight forward install:
Somewhere in there I also adjusted the right lower control arm to push the axle forward since it wasn't quite square and it will give me a little more tire clearance. I'm also going to adjust the lower control arm mount at the axle and push the axle forward. This will help again with the tire clearance as well as caster.
Oh, I also got a little bit of wiring covered up, but not nearly all of it. Good two days off
Old 08-09-2013, 02:17 PM   #430
Dieselwrencher
Looking good. Didn't you take the truck to have it aligned before you started driving it? I can't believe they didn't square the front axle up first before doing anything else.
Ryan
Old 08-10-2013, 12:03 AM   #431
Ackattack
Ackattack's Avatar
yep, and yep
Just got back from my test drive. Everything went well.
Old 08-21-2013, 12:41 PM   #432
Ackattack
Ackattack's Avatar
Filled up yesterday, and set a new high, 18.8 mpg. I'm not sure if this is due to how/where I drove or if lowering it helped that much. Maybe a combo of both.
I also ordered some seat covers for it, since the drivers side is tore up pretty good.
Old 08-21-2013, 05:44 PM   #433
jbclassix
Junk Yartist
jbclassix's Avatar
I definitely need an NV4500
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 08-21-2013, 06:51 PM   #434
Ackattack
Ackattack's Avatar
a 6 speed would be nicer.
with 3.54s and 35s, the 3 - 4 shift kinda sucks
Old 08-21-2013, 08:55 PM   #435
Dieselwrencher
6 speeds are freaking expensive when they break. You just need more power.
Ryan
Old 08-21-2013, 11:11 PM   #436
Ackattack
Ackattack's Avatar
Good point
My list of things to do is getting short. Pretty much cleaning up the wiring, installing my exhaust tip, and then its onto the "final" stages of more power and getting this thing painted.
Powerwise, I'm not going crazy. Just a few simple/cheap upgrades for now.
Old 08-21-2013, 11:19 PM   #437
Dieselwrencher
Honestly a few DIY adjustments, gov springs, and a good air filter go a long way on them.
Ryan
Old 08-22-2013, 03:06 PM   #438
6lcummins
This is where a 4K GSK comes into play, a little more rpm in 3rd gear cures the 3-4 shift and you can rebuild an NV4500 2 times to the once of a NV5600. The $100 GSK kit, in my opinion, trumps the $1400 upgrade from reman NV4500 to reman NV5600.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 08-24-2013, 12:49 AM   #439
Ackattack
Ackattack's Avatar
Added at least 5 HP tonight
Then I moved on to changing out the fan switch. I got one that comes on at 210. The other one was coming on earlier. I also re-wired it so it will only come on with the key in the on position, rather than anytime.
However, while I was rewiring that switch I pulled out a resistor and wiring that I had for the tach. I had forgotten that it was there as I had read for the instructions for using the factory dodge tach pickup. Well now I'm using a wire off the alternator instead. So now my tach isn't working correctly. I probably just need to play around with my dakota digital box again to get it working right. Kind of a pain, but oh well.
After that I continued looming up more wiring. I think I'm going to have to take off the left fender to get it all cleaned up and looking presentable.
Oh yeah, I also sold my suburban tonight. So that was my back up in case the crew cab had issues, but I haven't had anything come up. I do still have a jeep wrangler I can drive too.
Old 08-26-2013, 03:32 PM   #440
6lcummins
Why? The thermostat is 180* and these engines don't like north of 210* and I know my A/C builds too much pressure at 195* and shuts off.
"STOCK"
ASSEMBLY THREAD
Old 08-27-2013, 06:52 PM   #441
Ackattack
Ackattack's Avatar
The old temp switch would turn on at ~180
The truck hasn't gotten over 190 yet
Old 09-02-2013, 10:49 PM   #442
Ackattack
Ackattack's Avatar
My wiring has been a mess, so over the long weekend I took the time to clean it up. To start I removed the drivers side fender. I started grouping all of the wires, I had to cut, lengthen, and solder several wires to get them to be routed where they need to go. I also took apart the bulkhead connection and removed about a dozen unneeded wires (mostly for the transmission). I still need to go back and put wire loom over it, but its much better.
While I was working on the wiring I noticed the upper radiator hose was touching the #1 injection pump fitting. The vibration/heat started working at the hose and it was obviously weaker than the rest of the hose. Luckily I caught it before I got left on the side of the road. The replacement hose happen to be just the right shape that it is not hitting the injection pump.
My blower isn't working on anything but high, so after a little reading I changed out the blower resistor. Well that didn't work. So I guess I'm going to get a new control panel from the salvage yard.
Then I finally took the time to put on the front air dam.
Pulled the truck out of the garage and turned the wheel, and the tire hit the air dam. A quick trim to make a little more room and I'm good to go.
I finished up the weekend with an oil change.
Old 09-04-2013, 11:51 PM   #443
Ackattack
Ackattack's Avatar
An annoying little story:
To get my blower working correctly I figure I need a new climate control panel. I do a little checking on line and find some new ones on ebay for ~$100, rock auto has it for about the same, oriely's for about $200. So on the way home from work I swing by the salvage yard, figuring they'd have one and I'd save some money. So I ask the guy at the counter about it, he looks it up and sure enough he has one with a broken tab, but it works: $115....just then the phone rings, he picks it ups and spends about 5 min talking to someone else (this is a pet peeve of mine......the caller essentially just cut right in front of me....tell the person on the phone to wait) so he gets off the phone, I explain to him I can get a new one for less than that, he says he can do $100, I tell him I can do $50. He says "no way". I turn around and walk out. What I don't understand is that the likely hood of someone coming in and buying that 1 pound piece of plastic before they crush that vehicle is slim to none and there I was willing to pay $50.
Oh well, their loss. I just placed my order for it on rock auto and it will be here in a few days.
I just think its ridiculous that a salvage yard thinks they can charge just as much for used parts as new. (I also stopped by and had essentially the same thing happen for a tail light out of the dodge pickup I got my drive train out of....that's why I did my research before hand)
Old 09-05-2013, 12:25 AM   #444
jbclassix
Junk Yartist
jbclassix's Avatar
You pull and pay. Only yard i will use. Sucks that there isn't one in this state. Their prices are online and the most reasonable you will find. Do they have them where you are?
-Jeremy
Rebuilding an NP205
Old 09-05-2013, 08:08 AM   #445
mcbassin
Still Learning
mcbassin's Avatar
Very good progress on this project. Too bad about the salvage. I guess you have the same jerks running them up there as we do here. It's almost like they would rather not sell parts at all to me. Rude on the phone, won't return your call about parts inquiry. I have started using Rock auto more and more just to avoid the hassle.
mcbassin is offline   Reply With Quote
Old 09-05-2013, 05:44 PM   #446
I agree, some of the yards here are crazy on what they want for parts that I yank ( or even them) Luckily here they are the exception, rather than the norm.
Old 09-05-2013, 06:04 PM   #447
Dieselwrencher
Here we have a Wrench N"Go and they are about the same. One big pet peev of mine is not listing other charges before you get the part off. These yahoos have a core charge for dang near everything! drives me nuts. I also agree that a lot of places parts prices are too dang high. Just because it's on a car or truck in their yard, doesn't mean it still works. You're taking a gamble buying each part. Especially electrical stuff.......
Ryan
Old 09-06-2013, 02:20 PM   #448
justcuz
justcuz's Avatar
I stopped at the Pick a Part in Adelanto on my way through your neighborhood last week. Not bad compared to the ones down the hill that usually look like they have been hit by a hurricane.
You've seen the guy who has the 3 crew cabs in his yard off of 395 I presume. Looks like a mid 70's Ford and 2 Chevys. Hard to tell for sure at 70 mph!
justcuz is offline   Reply With Quote
Old 09-09-2013, 11:17 PM   #449
Ackattack
Ackattack's Avatar
New ventilation control panel and the blower works again on all speeds!
Also, apparently when I was working on the wiring, I got the brake relay plugged in backwards so my cruise control wasn't working. Apparently neither we're my brake lights! But I got both the brake light and cruise working. Just glad know one rear ended me while the lights weren't working.
Old 09-16-2013, 06:56 PM   #450
Ackattack
Ackattack's Avatar
Houston we have a problem.
The last few days the truck has made a random "barking" noise while crising down the highway. It only happened once each day and sounds like its coming from the transmission.
The today it started making a popping sound if you let off the throttle quickly and shakes the whole truck. I'm hoping its the front driveshaft but I'm not sure at this point. Gonna do some investigating after dinner.
