Old 04-01-2016, 11:20 PM   #426
75Dually
75Dually's Avatar
Re: 75 Dually build
Watts link mount is now done and welded to the rear end. I need to make the rest of the assembly that attaches the link arms to the mount, but that will get done later this weekend. I am also going to make new side mounts for the link arms. I want them to be stouter and look a lot better than my first go around. Progress!
Stay tuned!
75Dually is offline   Reply With Quote
Old 04-04-2016, 01:09 AM   #427
75Dually
75Dually's Avatar
Re: 75 Dually build
New Watts link, check! It's shown here just being mocked up. The bars need to be adjusted and it needs to be painted up and have all the correct hardware installed, but we are well on our way to buttoning this portion of the project up!
Old 04-04-2016, 09:44 AM   #428
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: 75 Dually build
Nice job!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-04-2016, 10:39 PM   #429
75Dually
75Dually's Avatar
Re: 75 Dually build
Originally Posted by aggie91 View Post
Nice job!
Thanks Karl!
Old 04-05-2016, 04:06 PM   #430
RNmatt87
Re: 75 Dually build
Still kicking ass. Love it.
RNmatt87 is offline   Reply With Quote
Old 04-06-2016, 02:32 PM   #431
travlinman
Re: 75 Dually build
I probably missed it in this thread somewhere but what bags are u running front an rear?
I was going to run 4-Dom 2600 but a buddy suggested I should run some re-8 in back.
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline   Reply With Quote
Old 04-06-2016, 02:47 PM   #432
75Dually
75Dually's Avatar
Re: 75 Dually build
I use 3800 bags from airbaggit on all 4 corners.
Old 04-12-2016, 11:18 PM   #433
75Dually
75Dually's Avatar
Re: 75 Dually build
So a short update. I've been finishing up getting the truck back together. One good thing about the 4 link is my pinch is only 3" above the shop floor. I gained 1.5" of additional drop! Now the truck sits level when slammed. My only issue is now the drive shaft needs some additional clearance around the cross member when fully laid out. Man if it is not one thing it is another... The truck does look a lot better laid that close to terra firma! I'll get some pics this weekend and post them.
Old 04-13-2016, 11:26 AM   #434
83GMCK2500
Re: 75 Dually build
How dare you write a post about stance like that without posting pictures!
Sounds like some good progress, looking forward to seeing the updates.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 04-13-2016, 05:41 PM   #435
75Dually
75Dually's Avatar
Re: 75 Dually build
Gotta keep you guys in suspense!
Old 04-13-2016, 06:01 PM   #436
mooseknuckles
mooseknuckles's Avatar
Re: 75 Dually build
yeah. what the hell...
mooseknuckles is offline   Reply With Quote
Old 04-15-2016, 12:11 AM   #437
75Dually
75Dually's Avatar
Re: 75 Dually build
So I found out there was some slight interference issues with the top watts link arm. Because I have felt for quite a while the old arms were a bit to small I thought this would be a good time to replace them and build a bigger and stouter set. So I went with 1 1/4" tubing and some chromoly heim ends. I also pulled out my tubing roller and gave each arm a slight bow to clear the mount. Now all is good with the world!
With the new ride height I wanted to check the clearance with the tires to the flares and the bed sides. I got the bed sides mounted back up tonight, and then check all the clearances at full drop. Thankfully there are no issues. I still have a lot of room on all sides. Whew!
Now I need to do an overall check and take it out for a run this weekend.
Stay tuned!
Old 04-15-2016, 11:05 PM   #438
75Dually
75Dually's Avatar
Re: 75 Dually build
So I got the big girl out of the shop today after work. I took a couple of pics, and I was comparing it to an older side view at roughly the same distance and angle. You probably cannot see any major difference, but because I am around it all the time I can see the inch difference.
Anyway I took it out for a short drive and the ride is really nice. Yes even better than before, and the ride was pretty good before.
So what is next... Most likely the interior, but the bodywork and panel fitment might take presidence. Oh yeah and the AC needs to get finalized too. Lots to do still!
Stay tuned!
Old 04-15-2016, 11:33 PM   #439
cochino12
It followed me home?
cochino12's Avatar
Re: 75 Dually build
bad ass!!!!!!
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 04-15-2016, 11:58 PM   #440
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: 75 Dually build
Looks good. You can definitely see the difference in the rear now.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 04-16-2016, 12:02 PM   #441
dropd80s
dropd80s's Avatar
Re: 75 Dually build
Looks good man.
"I'm Dirk Diggler enough to own and operate a vehicle of this caliber" -veinbar
Dropped and LS Swapped SWB 87 Build Thread
dropd80s is offline   Reply With Quote
Old 04-16-2016, 02:31 PM   #442
D.FENS
Re: 75 Dually build
Really informative build thread. Thanks for sharing the good and the bad.
Looking forward to digging into mine, looks like a good way to push my TIG and fab skills along.
D.FENS is offline   Reply With Quote
Old 04-18-2016, 02:27 PM   #443
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 75 Dually build
That looks very nice! Yeah, I'm sure AC needs to be on your top of the list down there! It's been in the high 70's and mid 80's up here already. It makes me believe July will be over 100* for sure. They say it's cause that ElNino dude.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-18-2016, 03:58 PM   #444
DblTrbl
DblTrbl's Avatar
Re: 75 Dually build
Looks great!
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192
Instagram: lofab77
DblTrbl is offline   Reply With Quote
Old 04-18-2016, 04:21 PM   #445
75Dually
75Dually's Avatar
Re: 75 Dually build
Thanks everyone for the encouraging words! Yeah the AC is a must have here in West Texas! The weekend drive my son and I took went very well. I like this truck, still needs a lot of work, but at least it goes down the road now!
Old 04-29-2016, 12:24 AM   #446
75Dually
75Dually's Avatar
Re: 75 Dually build
Check this out! Working on a short video of the 75Dually. More to come!!
https://www.youtube.com/watch?v=4CfyYOoD5TA
Old 04-29-2016, 02:24 PM   #447
RNmatt87
Re: 75 Dually build
Truck looks beautiful and you can definitely tell a big difference. Video is a good teaser.
Old 04-29-2016, 03:14 PM   #448
75Dually
75Dually's Avatar
Re: 75 Dually build
Thanks man!
Old 04-30-2016, 08:44 PM   #449
75Dually
75Dually's Avatar
Re: 75 Dually build
Went to a local show today and there were a lot of cool square dually 1 tons out. Cesar Castro in the teal rat rod dually came all the way from Hobbs NM, and the Root Beer dually is a local ride. Tons of fun, pun intended!
Old 05-02-2016, 10:57 PM   #450
75Dually
75Dually's Avatar
Re: 75 Dually build
Ok so I have not really liked all the plastic air tubes since the beginning of this project. They are prone to fail, and I simply don't want to trust my ride to them. Weakest link you know...
I want hard lines for the whole system at some point. So tonight I took off the tank to tank line and ran some copper line in it's place. The next line I'm going to run is from the filters to the tanks, and then from the tanks to the valve. It has been a while since I have soldered any joints. Not since the last water heater went kapoot!
Eventually I will do the main supply line from the York to the filters, but that hydraulic line is doing a fine job at this point. And naturally I will do all 4 corners to the bags. One less thing to worry about! My stuff may not be as pretty as some of the show trucks I see, but I want mine to be mechanically sound first.
Looks a little steam punk to me!
air bags, alcoas, chevy, dually, lowered
