02-01-2016, 09:31 PM | #426 |
Re: New project! The "Red Herring"
Nice finds in the salvage yard. The terminals / grounding block will be pretty handy. I'm going to need a positive for under the hood and gotta admit, I wasn't thinking of finding one in a yard. Thanks for the reminder.
02-02-2016, 12:20 AM | #427 | |
Simple? What's simple?
My pleasure! I'll admit that idea shopping at the yard is something I really enjoy doing - I just go over there with an idea of what I need to do, and see what strikes my fancy!
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
02-02-2016, 10:40 PM | #428 |
Data call! Anybody with a stock frame 1/2 ton AD truck - I need a few measurements:
Width of the rear frame rails at the bumper brackets Distance from the top of the frame rail to the bumper brackets Distance from rear cross sill to the rear bumper (at the center of the truck) Thanks in advance!
02-03-2016, 09:19 AM | #429 |
I was given some help with measurements a while back on my build. Of those you need, 46 1/6" is the width of the frame at the very back. I cant help out on the the other two as I don't have a bumper or brackets yet.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 |
02-03-2016, 02:44 PM | #430 |
I have the frame in storage, bumper and bracket on the attic.
Can measure it on Saturday, hope this helps You. |
02-03-2016, 11:00 PM | #431 | |
If you could, that would be great! Hope the truck is coming along well.
02-06-2016, 08:45 AM | #432 | |
I haven't seen the frame in a time so its good to see it again. Wrenching time....., bumper and bracket to the frame and get measurements. With of the frame is 117,4 cm, is the same as FarmerSid mentioned, see for other measurements attached drawing. |
02-06-2016, 01:32 PM | #433 |
Richard, this is perfect! Thank you!
02-07-2016, 01:52 AM | #434 |
These photos may not look like much, but that means I did it right
The entire underhood harness is pinned and run to where it needs to go - I just have a handful of loose ends (the power solenoid for the fuse panel and the proportioning valve wire) which aren't hooked up yet, because the things they go to aren't mounted yet! I still have a LOT of taping, looming and wrapping to do, but this is a major milestone in the wiring
02-07-2016, 08:34 AM | #435 |
Looking good JJ! Man I'm not looking forward to the wiring part of my build.
02-08-2016, 10:58 AM | #436 |
That looks amazingly factory. Great job
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
02-08-2016, 10:21 PM | #437 |
Neat, clean, factory...a lotta effort to get it there. Well done!
02-09-2016, 12:16 AM | #438 | ||
Tonight, only had a short bit but I did a lot of tinkering and fitting on the inside of the truck, figuring out where everything needs wiring to run to. To that end, installed the wiper motor (Yes, I got lazy and bought a conversion motor ), and it looked like it wasn't going to clear the gauges, so I had to break those out and try them for clearance: The upper connector body wouldn't fit with the wiper motor where it is, but fortunately the speedometer doesn't use that connector so I've had my hand forced as to which gauge goes where, but it all fits. Phew!! Took a couple shots for the feel, first time I've tried the gauges in the truck and I am as pleased as could be!
02-09-2016, 08:31 AM | #439 |
Those gauges look real nice mounted in there home finally.
02-09-2016, 08:02 PM | #440 |
JJ, did you move your column a little to the left so it is spaced evenly between the gauges?
The gauges look great! I was looking mine over and I guess I didn't recall the factory dash mount location is a little right of center between the gauges. |
02-09-2016, 08:31 PM | #441 |
Thanks Lowers! Now I just have to get caught up to you, running engines and working gauges and all
Thanks Doug! Yes, guilty as charged. Those sorts of little asymmetric details drive me absolutely BATTY, so it had to be centered. Of course, once I deleted the recess in the dash (where it was cracked) it was a blank canvas, anyway
02-09-2016, 09:19 PM | #442 |
Thanks JJ, I gotta do the same on this one...all things in balance. And it will help with getting the intermediate shaft system past the exhaust.
02-10-2016, 12:33 AM | #443 | |
Mounted up the keyless entry control box: The box I am using (looks just like this one but has a second connector) is a 95-96 model year only unit, common to Tahoes and Suburbans of that vintage, it does keyless locks and also delayed illumination on unlock and door open - will be a nice modern touch. Also set up this little bracket: The flasher block came from a '96 S10 truck, I'm pretty sure it's '95-'97 range - anyways, holds two standard flashers and a GM headlight buzzer (not sure if I'm going to install that or not, but I'll wire it up since it will take all of two extra minutes). I modified it a little to make it fit in the bracket. I'm going to weld it up on top of the brake pedal support (bad photo) so it's out of sight but still reachable: Speaking of interior lights, anybody have any good ideas for door jamb switches and running wires into the doors? I've looked at a couple different "hot rod" wire conduits but none of them will work with how tight these door jambs are
02-10-2016, 08:25 AM | #444 |
I'll be using something like this next time when I paint my truck. They are from something like a mini van sliding door.
Amazon.com: Painless 40024 Jamb Tac Four Contact...
02-10-2016, 12:52 PM | #445 | |
02-10-2016, 01:00 PM | #446 |
I thought about those too, but just ran wiring through the hinge. I'v had no problems yet.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
02-10-2016, 02:35 PM | #447 |
Did you just lay it on the hinge and tape or tie it somehow? I was looking at making a sheetmetal cover to attach to the lower hinge to run wires underneath, on top of the hinge itself.
02-10-2016, 02:44 PM | #448 |
I'd have to find or take a pic, I ran it on top of hinge. Loomed it. I was skeptical on the route at first. But my doors and jams were already painted. I have had no problems with it.
02-10-2016, 03:04 PM | #449 |
I'm just putting a loop on the inside of the door and under the dash. Same as 99 my doors where already painted oops.
02-10-2016, 04:45 PM | #450 |
That seems to be the way of it, haha! I imagine just a loop inside the cowl would be enough? Seems like the wires in the doors shouldn't be moving about, to speak of. Hrrrrrm
