08-07-2017, 09:37 PM | #451 |
Hollister, CA.
Re: '62 GMC BurbMaster "Rust"oration, Patina Build.....
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
08-08-2017, 03:03 AM | #452 |
Congrats! Looks like it is in very good shape! could have been a lot worse.
08-10-2017, 10:27 PM | #453 | |
Hollister, CA.
08-11-2017, 09:41 AM | #454 |
08-11-2017, 09:51 AM | #455 | |
Hollister, CA.
But more that likely, a programmable Guage set, like the Dakota VHX serious, for example. I need to get back to this. .thank for the motivation, guys ....
08-11-2017, 11:46 AM | #456 |
i like the half round tank strap mounts looks factory u fancy!!!
08-18-2017, 01:01 PM | #457 |
any chance you dont need the body brace from the one you cut out? or know any leads?
08-18-2017, 01:03 PM | #458 |
mine are uber jacked up. i need to replace it all. the PO reinforced the bad original steel with plate and angle iron, strong but not correct.
01-29-2018, 01:58 AM | #459 | |
Hollister, CA.
but you can have this 1 here if you still need it
01-29-2018, 09:55 AM | #460 |
02-21-2018, 09:37 PM | #461 |
Looking good John, Estate Wagons had 22 gallon tank, side fill, looks identical. I used the side fill from 93 Caprice on my panel, Don't know if you have a plan for how yours will fill. Keeping the side fill option? Your welding is Stout. Front and back are rock solid. Going to be a sweet ride.....Ed
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
03-14-2018, 04:51 PM | #462 | |
Hollister, CA.
I plan on piping the tank to the original side fill.
03-17-2021, 02:30 PM | #463 |
Hollister, CA.
Man....Did I fall asleep at the wheel on this one !!!
I still have this thing .. currently in my container, as life took over. When I do get back on it, I will be changing directions and going 4wd...so I will have a running LT1 chassis available to whoever is interested. Thanks
