Old 06-25-2018, 11:11 PM   #451
Joe Pass
Joe Pass's Avatar
Re: Used Parts Build
That's going to be sweet.....alot of creative energy.....
Joe Pass is offline   Reply With Quote
Old 07-02-2018, 01:35 PM   #452
tinydb84
tinydb84's Avatar
Thank you for the kind words.
David
Instagram: myfabguy
Old 07-02-2018, 01:36 PM   #453
tinydb84
tinydb84's Avatar
Trans cross member going in
Inner chassis stiffener started
David
Instagram: myfabguy
Old 07-09-2018, 12:22 PM   #454
tinydb84
tinydb84's Avatar
Got the inner structure done. Still trying to figure out if I should add additional tubes. I am thinking I should tie the cab mounts to the inner structure. Any thoughts?
David
Instagram: myfabguy
Old 07-09-2018, 12:56 PM   #455
aggie91
I'm just glad to be here!
aggie91's Avatar
I think I would tie them in...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-09-2018, 05:25 PM   #456
Joe Pass
Joe Pass's Avatar
I second that....you got alot going on there with highly modified frame...never hurts to over build in this case.....
Old 08-06-2018, 12:32 PM   #457
tinydb84
tinydb84's Avatar
Center section is almost done.
20180805_201112
David
Instagram: myfabguy
Old 08-06-2018, 04:18 PM   #458
aggie91
aggie91's Avatar
That should do it! Looking good.
Karl
The LST Challenge:
Old 08-06-2018, 10:06 PM   #459
Joe Pass
Joe Pass's Avatar
Great work.....can't wait to see it with the cab on...
Old 08-20-2018, 01:10 PM   #460
tinydb84
tinydb84's Avatar
Thanks guys. I appreciate it.
Got the trans cross member finished.
Everything is welded in.
Going to pull the engine and trans to paint it all then toss the cab back on next unless someone has recommendations otherwise.
David
Instagram: myfabguy
Old 08-21-2018, 01:03 PM   #461
daddyjeep
daddyjeep's Avatar
Are you going to get your exhaust run before putting the cab on? Now seems like a good time to address that.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 08-21-2018, 02:07 PM   #462
Joe Pass
Joe Pass's Avatar
You might want to fit the cab with the eng/trans in before paint....you'll possibly have to cut/grind and tweak something........
Murphy's law applies...lol
my2cents....
Old 08-21-2018, 05:35 PM   #463
tinydb84
tinydb84's Avatar
Im running a fender exit exhaust off the turbo. Hows your truck doing? I haven't see many pics lately.
my2cents....
My buddy Murp...I know it isn't going to fit. I had to raise the engine an inch or so because I didn't account for the forward sump on the Fbody pan. Thanks for looking out. Should I drop my cab off at your place for paint? I'm thinking a three stage pearl white. If you aren't too busy...
David
Instagram: myfabguy
Old 08-22-2018, 02:12 PM   #464
daddyjeep
daddyjeep's Avatar
That would certainly simplify your exhaust routing.
Nothing new with my truck. I have too many projects going on and just haven't done anything with it. I just use it when I need it. I do have a 4" lift and some new tires sitting in the shop ready to go on... and new bed sides ready to go on.... and I still have a lot of work to do on the hood.
04 1500 crew cab
Old 10-01-2018, 01:30 PM   #465
tinydb84
tinydb84's Avatar
Finally got a bit of work done:
Mounted my tanks
Welded the bolts on for easier installation
Painted the center section of my frame
David
Instagram: myfabguy
Old 10-01-2018, 04:02 PM   #466
Lokin4AReason
Lokin4AReason's Avatar
those are some really pretty weld(s) ....
nice progress also
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 10-01-2018, 11:21 PM   #467
Joe Pass
Joe Pass's Avatar
Wow.....taking shape now....
Old 10-08-2018, 04:14 PM   #468
tinydb84
tinydb84's Avatar
And the cab is back on. Hopefully permanently!
The front is hung up a bit. In shortening the control arms so much I dont have as much drop in airing down. I plan on making tubular ones eventually and will have to fix that.
David
Instagram: myfabguy
Old 10-09-2018, 08:45 PM   #469
BIGglaSS
BIGglaSS's Avatar
Ohhhh yeaaaahhh.
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30
BIGglaSS is offline   Reply With Quote
Old 10-15-2018, 01:40 PM   #470
tinydb84
tinydb84's Avatar
Originally Posted by BIGglaSS View Post
Ohhhh yeaaaahhh.
Thank you sir
David
Instagram: myfabguy
Old 10-15-2018, 01:41 PM   #471
tinydb84
tinydb84's Avatar
Didnt take a lot of pictures but...
20181013_182044
Got the engine in. Put the turbo on. Cut the floor out. Starting on fixing the floor. Then finish the exhaust.
David
Instagram: myfabguy
Old 10-16-2018, 10:51 AM   #472
daddyjeep
daddyjeep's Avatar
Now we're talking. I have been thinking a lot about the same powerplant in mine lately. You are not helping.
04 1500 crew cab
Old 10-16-2018, 12:43 PM   #473
tinydb84
tinydb84's Avatar
The internet makes it easy now. I got most of the turbo stuff from a friend who I did some work for. I found another guy off Instagram/LS1tech who I just copied the set up from and he is going to load his tune on my ECU so I don't have to worry about messing anything up while I play with it before I actually dyno it (if I get that far).
David
Instagram: myfabguy
Old 10-31-2018, 01:13 PM   #474
tinydb84
tinydb84's Avatar
The steel shop had 10 feet of stainless 4'' .065 wall tube in the scrap pile so I figured I would try to make it work. It is a bit bigger than I wanted but whatever. I am making two exhausts for it. One for daily driving and one for when I go to cruise nights and meet ups. You can guess what this one is for.
David
Instagram: myfabguy
Old 10-31-2018, 02:51 PM   #475
daddyjeep
daddyjeep's Avatar
Might as well add some propane and an igniter while you are at it.
04 1500 crew cab
