Old 07-12-2017, 06:48 PM   #451
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: 1961 Crew Max
Looks great!!
Simple Green is great stuff!! I use it all the time
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-18-2017, 04:25 PM   #452
namloc
namloc's Avatar
Re: 1961 Crew Max
Originally Posted by CHIZZLER View Post
Yesterday was a fun day. We finally got the big girl outside to stretch out. The side view makes this think look really long. We couldn't even push it from the gravel back to the shop. Had to pull it back in with the tractor. Decided to do something different and welded the headlight trim rings to the grill and closed up the holes. I guess were getting to the next phase of a quick re- blast and epoxy the whole thing. I brought the motor/trans and bed home to do some cleaning and fit the bed wood. I really don't want to pull this motor apart but want to get it clean. I've read a lot of good results with simple green automotive so I'm going to try that first. Lots of welding to do on the frame still but that will be after body work is mostly done and before paint. Thanks everyone for checkin this WTF did I get myself into build. CHIZZLER
Can't wait to see it run down the road, Too Cool.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 07-24-2017, 12:07 AM   #453
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: 1961 Crew Max
Little update. Got the motor torn down as far as I think it needs to go. With only 118k everything should be good. Did a major degreasing to start things off and followed two more times with some spot cleaning. Getting it ready for prime and paint. A friend of mine got this ultrasonic cleaner from his work that they were throwing away due to updated cleaners. Overall pretty good with almost no work. Thanks CHIZZLER
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 07-24-2017, 07:00 PM   #454
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1961 Crew Max
Looks really nice. Those ultra sonic cleaners work very nice!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-24-2017, 11:36 PM   #455
lower50's
lower50's's Avatar
Re: 1961 Crew Max
Wow almost new again.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 08-06-2017, 11:38 PM   #456
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Got A Bit more done the last couple weeks. Pulled more of the motor apart and put some primer and paint on it. Also blasted the almost all of the sheetmetal for reassembly. Boss put down a Thick coat of PPG CRE-921 Epoxy primer and this s*** is like powder coat. Going to start bodywork anytime. CHIZZLER
61-crew cab D-max
Old 08-07-2017, 02:13 PM   #457
youngrodder
youngrodder's Avatar
Re: 1961 Crew Max
Looks great all one color.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 08-07-2017, 08:41 PM   #458
61_FL_Apache
Who Me?
Re: 1961 Crew Max
Is that seam sealer on the 2nd body pic? Looking great!!
Steve
2001 Blazer 4D 2WD
Old 08-08-2017, 02:51 AM   #459
Bomp
Bomp's Avatar
Re: 1961 Crew Max
Looking Amazing
Bomp is offline   Reply With Quote
Old 08-08-2017, 06:43 AM   #460
Re: 1961 Crew Max
Very nice!
Old 08-08-2017, 09:53 AM   #461
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
On the outside we used sandable seam sealer. On the inside we used vulcum.
61-crew cab D-max
Old 08-08-2017, 01:50 PM   #462
66ChevyMax
66ChevyMax's Avatar
Re: 1961 Crew Max
Very Nice Chiz!!!
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 08-14-2017, 11:56 PM   #463
lower50's
lower50's's Avatar
Re: 1961 Crew Max
Oh ya here we go.
1951 MG TD
Old 08-15-2017, 09:10 PM   #464
Advanced Design
Advanced Design's Avatar
Re: 1961 Crew Max
Body does look great all same color. Very nice!
Advanced Design is offline   Reply With Quote
Old 12-21-2017, 11:58 PM   #465
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Been A bit guys. Still in body work right now. My parts shelf has grown a lot. Few more items then the motor will be wrapped up. One thing I'm trying to decide on is the turbo. Leaning towards the Danville 68mm charger. Very streetable up to about 600hp. Few more go fast parts coming soon. This motor only has 118k on it and was mainly a pavement princess with no power adders. Got my modified harness back from ken wolkens at stand alone harness and reprogramed ecm and tcm from Dmax swap and they both did a great job. Anyways Happy Holidays to all of you. CHIZZLER
61-crew cab D-max
Old 12-22-2017, 12:56 AM   #466
Dieselwrencher
Re: 1961 Crew Max
Nice parts list showing up for sure. That turbo should work pretty well. The body work is looking like it's going pretty nice too. Merry Christmas and Happy New Year to you and your family!
Ryan
Old 12-22-2017, 11:05 AM   #467
66ChevyMax
66ChevyMax's Avatar
Re: 1961 Crew Max
Shawing, that motor is sexy!
Craig
Old 12-22-2017, 01:38 PM   #468
Bomp
Bomp's Avatar
Re: 1961 Crew Max
Looked cool before body work started, now I'm on pins and needles.
Merry Christmas
Old 12-23-2017, 10:37 PM   #469
awbrown
Re: 1961 Crew Max
Nice to see someone working on their project .... My 63 has sat in the driveway with a trans leak all summer , I sold my green one that I started to put floor boards in and my other project is still taking up space in the garage ...
awbrown is offline   Reply With Quote
Old 01-03-2018, 01:13 PM   #470
lower50's
lower50's's Avatar
Re: 1961 Crew Max
Looking very good!! Do you have a turbo now? I'm looking at getting the Wicked Wheel for mine?
1951 MG TD
Old 01-03-2018, 10:07 PM   #471
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Originally Posted by lower50's View Post
looking very good!! Do you have a turbo now? I'm looking at getting the wicked wheel for mine?
im waiting on a danville performance bmw 66mm billet stage 2. Should be showing up anytime.
61-crew cab D-max
Old 02-07-2018, 09:33 PM   #472
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Few updates. New Danville Turbo made it. Body work is getting closer to actually trying to finalize color. We have done 5 spray outs so far and it's just not right yet. For the inside cab color Im interested on what any of you have used. I've read a lot of different opinions on the two tone dark grey light grey but no shared paint codes. Here is the dash as I got it and you can see the color combo. Thanks for checkin in. Chizzler
61-crew cab D-max
Old 02-07-2018, 11:51 PM   #473
namloc
namloc's Avatar
Re: 1961 Crew Max
Very cool. Coming down to some of details are the most nerve racking at times.In the past on painted vehicles I did and still a lot of people today look at VW color codes and Toyota color codes for ideas. Ya just never know?
The Snortin' Bull
Old 02-08-2018, 03:56 PM   #474
lower50's
lower50's's Avatar
Re: 1961 Crew Max
Ooo nice hair dryer!!!!
1951 MG TD
Old 03-06-2018, 11:03 PM   #475
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Quick update. One more block then sealer. After about 10 spray outs we finally have the color nailed. I had some original interior color mixed and it came out really pinkish. Trying to keep the dash and all other interior panels close to factory. If any of you have and specifics on what you used for 60-61 please share. Thanks all for hanging in on this colossal over the top what did I get myself into build. I know most of you have felt the same way. CHIZZLER
61-crew cab D-max
