11-02-2007, 09:51 AM | #26 | |
Re: How to: Ruin a perfectly good Blazer...
http://www.*****************/showfull...itle=Firestone F9000 Sleeve Bags |
11-02-2007, 12:35 PM | #27 |
On the fast track to nowhere..
Looked good in person before. It'll look AWESOME now! Can't wait to see it all finished up!. BTW, I brought those wasps home with me in the fenders, and got bit!
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
11-02-2007, 06:00 PM | #28 |
I think Your bazer is bad a$$.Thanks for the slow build tip.I posted about 20 pics of the frame if You want to check them out?
11-02-2007, 06:32 PM | #29 | ||
A guy with a truck
Haha- Me too!
Thanks! I'll check 'em out. Sounds like a cool project you've got going.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) 07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 11-26-2012 at 12:58 AM. |
11-02-2007, 07:44 PM | #30 |
67-72 parts collector,
gringoloco,... have you ever thought about flipping the crossmember brackets that attach the front end of the trailing arm? I'm thinking about helping the pinion angle. If you swap them "side-to-side" and flip them upside down,... it would raise the front pivot point "up" on your ECE crossmember. I'm subscribing to this one!!!
11-03-2007, 12:24 AM | #31 | |
A guy with a truck
When I bagged it the first time, I used the weld-on ECE saddles and set my pinion angle according to ride height. If I run into any problems, I will either reposition them or use angle shims to correct. My ride height will be about 5" lower than before, so I will probably have to do something...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) 07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
11-04-2007, 04:06 PM | #32 |
Outlandish Trends - FL
Hell yeah Chris! Good job on the slots for the panhard mount. I ended up ditching mine alltogether and am almost done with my Watts Link install. KP makes some really nice stuff. I've been extremely happy with their product and service. My only problem is finding time to work on my heap. Really enjoying the progress pics. You're doing a super job, keep it up and good luck!
-Bret 67 short-fleet sold! |
11-06-2007, 04:40 PM | #34 |
chevy only
mr gringo i would like to ruin a perfectly good suburban,I am working a deal for one.Nice job with the tech info
11-06-2007, 05:05 PM | #35 |
Yeah Chris. What'd you tear up this weekend?
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver Last edited by babyblueoval; 11-06-2007 at 05:34 PM. |
11-06-2007, 05:29 PM | #36 | |
A guy with a truck
Not yet...
Unfortunately, nothing. Maybe tomorrow...
11-06-2007, 05:41 PM | #37 |
Hey Chris,
While you've got your truck torn apart you should put that early front cap on there then your truck would be absolutely perfect. When I finish mime, our trucks could be twinkies except for the color... and the interior.... and the engine....and the trans.....and....and. Ok so maybe not twinkies but when I come to visit and we go down a few at Superior we'll certianly draw some attention.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
11-06-2007, 06:43 PM | #38 |
Seρor Member
With the ECE xmember, it's easier to make spacers for the trailing arm mounts since they bolt on. Then you use stock holes for the xmember.
11-06-2007, 11:03 PM | #39 |
:( BYEBYE :(
looking good!!!
11-08-2007, 12:59 AM | #40 |
A guy with a truck
It's definitely in the cards, but bodywork/paint is down on the list a few notches. I have a '70 pickup that is sorely neglected and in need of some attention too once this little project is done...
11-09-2007, 09:55 PM | #41 |
A guy with a truck
Made a little progress tonite- finally. Before I started welding, I spent some time setting up a dedicated 20A circuit to feed the welder. The first pic is my test piece. I wanted to make sure I was getting good penetration, plus it has been a while since I laid a bead. I think It will work...
I got the outer plates tacked, well actually, stitched in. Besides just running a bead around the perimeter, I also did a few plug welds in the existing holes in the frame for some insurance. After I got them where I wanted them, I marked the excess....
11-09-2007, 10:07 PM | #42 |
A guy with a truck
...and lopped it off with a cut-off wheel. You can see that I made the cut a little bit above the bottom of the frame so that when I run the bead there, it will not be an overhead weld. I HATE overhead welding...
Everything so far is going well and it all ended up level and symmetrical. Guess all the obsessive measuring is paying off. The front to back is not level- it is parallel with the frame. When I set the jackstands I had about 1/8 bubble on the top of the frame rails and that is where I set the notches. Side-to- side and up-and-down they are level and plumb.
11-10-2007, 08:42 AM | #43 |
Looking good Gringo
11-10-2007, 12:04 PM | #44 |
This is going to tun out great.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
11-10-2007, 06:35 PM | #45 |
good job
11-10-2007, 06:40 PM | #46 | |
Seρor Member
11-10-2007, 08:08 PM | #47 |
11-10-2007, 09:29 PM | #48 |
A guy with a truck
Thanks for the props everyone. You guys keep motivated.
XXL is just yankin' your chain. Could be cool though. Hmmmm... So I spent some time test fitting the inner plates. They require a lot of trimming/fitting because of the panhard crossmember. I started out by clamping a straight edge to the framerail to use as a guide to cut it straight. This allows the inner and outer plates to be parallel. Next, I made a cardboard template of the inner plate and cut it to fit. It is clamped in place and ready to burn in. I also fitted the top cap. Next step is weld it up and cut the frame!
11-10-2007, 09:39 PM | #49 |
Gringo,
You wanna take a short 2 1/2 hr drive over here to Little Rock and help me lay out mine? Nice work.
11-10-2007, 10:16 PM | #50 |
I need some help on mine this weekend also.
