View Poll Results: What fender opening do you want
2" higher, 4" longer, stock width 18 21.43%
3" higher, 6" longer, Stock width 8 9.52%
4" higher, 8" longer, Stock width 5 5.95%
2" Higher, 4" longer, 1.5" wide flare 9 10.71%
3" higher, 6" longer, 2.5" wide flare 15 17.86%
4" higher, 6" longer, 3.5" wide flare 12 14.29%
Max opening- 6" higher, 10" longer, Stock width 4 4.76%
Max opening- 6" higher, 10" longer, 3"-4" wide flare 12 14.29%
You don't want fiberglass fenders 6 7.14%
If the price is right, the size opening doesn't matter 15 17.86%
Multiple Choice Poll. Voters: 84. You may not vote on this poll
Old 08-09-2008, 01:01 PM   #26
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
Re: Interest for High rise(pre-runner style?) Fenders Fiberglass
ah, dzus fasteners are great! I don't know why I didn't think of it when I saw that, as it's a pretty standard way to mount GRP panels.
If I'm going to take the time and effort to make a mold, I feel it's worth it getting the model/plug as well done as possible. if I half ass the model, the molds will reflect that, and every part from the molds will too. And it's not that much work to retain the curve on top of the lip and the beauty line on the lower part of the lip.
This weekend I'm just pulling my fenders out of the barn, and finish up re-organizing my garage so I have some nice space to work on these fenders.
When I start cutting and welding I'll be posting pics.
I've been experimenting with reinforcing the fender front to back, as the fender holds up the Rad support. On my tilt front, I fabbed some bars to hold the rad. support, but I'd like to make these fenders include something so additional supports aren't necessary
Mordachai is offline   Reply With Quote
Old 08-09-2008, 09:00 PM   #27
jaros44sr
jaros44sr's Avatar
Is it possible to make just the fender skin, I could attach it to my exsisting fender framework. I could flange the fender the thickness of your fiberglas all the way around
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-10-2008, 10:48 AM   #28
Mordachai
Mordachai's Avatar
do you mean that you would cut off the fender skin, leaving an inch or two around the perimeter to mount the new skin to?
That's def possible, but it's hard to get a good true bond with metal and fiberglass. You would pretty much have to rivet or thread set it to the metal frame, and then go over the seam with some fiberglass or similar material.
And it will crack as it flexes. Metal and Fiberglass have different expansion rates in different temps, and they flex differently.
It can def be done, prolly a little cheaper than a fully molded fender with all the mounting points.
I'll send you some pics to clarify that we're talking about the same thing.
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Old 08-10-2008, 11:50 AM   #29
sandking
.....I am working on it.....
sandking's Avatar
I would be interested in this also. Any thought on bedsides? The skin would be ideal here.
View my build thread HERE
sandking is offline   Reply With Quote
Old 08-10-2008, 12:32 PM   #30
Mordachai
Mordachai's Avatar
A fender skin might a good compromise, only thing if you want it to look pretty painted up and all, it will flex and bend, and eventually crack the paint.
Some people might not care, some would.
I could do the fender skin thing for anyone who's interested. It would come off the same mold as the full fender, just not fully cast around the mounting points etc.
As for bedsides, I am planning on making molds of my fleetside bedsides. Actually I'm going to make a full glass bed, it's straight and in really good shape, but I'm going to do the front fenders first. Once there is some good feedback and hopefully some satisfied customers, I'll work on the bed.
To give a quick idea, It'll prolly cost me around 400-600 in materials alone for each front fender mold. That does not include my time to make the plug, or my time to make and clean and polish the mold. Molds are expensive as all hell, but worth it if making a decent number of parts.
But eventually(hopefully sooner than later) I will wet sand and smooth my bedsides and make molds of them. Heck maybe someone will help me with my mold costs in return for the first set of bedsides, as bedside molds are gonna be costly!
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
Last edited by Mordachai; 07-02-2009 at 07:21 PM. Reason: well, after the fact, it's cost MUCH more than $600 per mold. Easy 4x that...
Old 08-10-2008, 01:24 PM   #31
jaros44sr
jaros44sr's Avatar
If you can make the fenderskins in white gelcoat, I won't have to paint them. I was thinking of bonding them to the fender skeletin, once I cut the fender away. How thick would the fibreglas be?
SAFETY FIRST
AS usual, off topic
Jim
Old 08-10-2008, 02:21 PM   #32
Parkerkl
Great Idea! Would definitely like a 2" higher, 4" longer, stock width set
Parkerkl is offline   Reply With Quote
Old 08-10-2008, 04:06 PM   #33
dammitmitchell
the pollock
dammitmitchell's Avatar
<couldnt you cut or match the fender mounting holes with like a metla inlay or say i dunno how to describe it, but like a metal "rib" for the bolt on and mounting areas?
and issue ive had with alot of the newer cars and definatley with the newer body kit rage is that when you install them everything sags or the holes for mounting are just weak and unsupported, if there was a "rib" or a inlaid piece of metal to bolt through for added support said fenders would last much longer wouldnt they? or at least be more rigid at the mounting so they dont "tear off" under normal flex or maby mud weight?
does that make sense?
I think an internal reinforcement would be much sturdier then "modling" a big fiberglass mold to a cut steel fender, and BTW some of us here cant fiberglass.... so how would we make it look descent?
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 08-10-2008, 07:14 PM   #34
Mordachai
Mordachai's Avatar
Hey that's great coincidence, as I generally use black(sometimes orange) tooling gelcoat for the mold and white gelcoat for the parts. The white over black helps to give a visual to when I've got the gelcoat thick enough. I do use a wet film gauge too, but the color is a great starting point.
How were you thinking of bonding them? An adhesive bond alone is probably not enough to really make it strong. I'd suggest a good adhesive and Rivets or threaded inserts or something like that. I'd like to know what you have in mind.
I can add any kind of reinforcement to the fender you'd like, but it's probably not necessary. I will place large fender washers in the mounting areas to help spread the force of the bolts.As for internal ribs to make it stronger, if the part is laminated correctly, there is no need for any other support. The only way I can see it tearing off is in an accident. There's little to no chance it will break under normal flex, or even if covered with 50# of mud.
For instance, I can sit on the tilt forward front end I made, it's def strong enough. It weighs roughly 150#, and that's with the 20# hinge I made out of angle iron grafted to it. As long as the parts are made well, there should be no problem, as pound for pound, composites are much much stronger than steel! I can't wait to have some finished parts to show the quality that I am aiming for.
I agree with you, it will be difficult at best to graft a fender skin to a cut steel fender. And over time, the seam will crack just the nature of two different materials. That's why I'm curious to know what jaros44sr has in mind.
I agree with the whole thing with the body kits you are talking about, but it's the brand of kit that the problems arise. A good well made kit will run anywhere from 10 grand and up, and there's only a few companies that make them, and they don't produce them in high numbers. That's for the real deal kit from the people who originally designed it. Those parts are very high quality and don't sag at all, and line up perfectly.
What happens is some rip-off company buys one kit, and makes cheap molds off the parts without them mounted on a car. Since they are molded off the car, their molds are twisted, wavy and generally lousy.
Then the parts that they pull off are even worse, and very thin and fragile.
Unfortunately that gives all body kits a bad rep, as 90% or more of them are the cheap ones, not the well made kits by well known companies. Unfortunately, the rip off companies market their junk as the real deal, and that causes big problems throughout the industry.
An example: I still have a pair of fenders I got for my Rx-7, that I just couldn't bring myself to bolt on because of shoddy workmanship. A friend bought them and sold his Rex before he put them on, so I got them. These are fenders that sell for $350 or so, but should sell for 100 if that. There's maybe $40 of materials in them, they are so thin it's not even right, that what is supposed to be used as a core material is soaked in resin and slapped on the back to give it some form of strength, with no glass sealing up the 'core'. Basically, the tupperware in your kitchen is probably stronger than those fenders!
So anyways, fiberglass parts have gotten a bad name because of all the rip off companies out there, but composites(fiberglass, Carbon fiber, Kevlar glass etc) if done properly are super strong.
Just for kicks, here's a pic of me sitting on my front end. I know if I can make that front end strong enough to support me, ans weigh in around 150#, that I can surely make a fender as strong(probably stronger) than it's steel counterpart.
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
Old 08-10-2008, 10:34 PM   #35
jaros44sr
jaros44sr's Avatar
Alot of the new panels are just bonded(BMW), but I was planning on using countersunk rivets to hold the two pcs. together...How thick is the fibreglas, I have to make a crimping tool that thickness?
SAFETY FIRST
AS usual, off topic
Jim
Old 08-10-2008, 10:58 PM   #36
dammitmitchell
the pollock
oh well hell.. u know alot more then i do, i recently installed a stalker II body kit on a 01 mustang, looks great till you hit 100, had to go through and "reinforce" with angles sheetmetal to keep the body sucked up, it had the holes and the pictures in the instructions just non of the hardware .. and this is directly from the guys who made it ugggghhh..
ok well we also had baja fenders on a prerunner style ranger a while back and after a few good whacks in muddign trails the fenders were splitting up like old currogated (sp?) fiberglass panels (like a crappy greenhouse)
so... im sorry im bitter..
but your stuff looks alot better
Army vet 02-08
Old 08-10-2008, 11:42 PM   #37
sandking
sandking's Avatar
Just for a little more info on the "skin", here is a picture of my last truck I had. It was a full fiberglass body made by a place called Trailer Products. It was full tube chassis, it had tubes with tabs and the glass was thru-bolted and all bolted together. The thickness was no more then 3/16". The truck has seen the worse of the worse and at 100+ mph, and not one crack. I had since painted the whole thing black, and still no stress cracks. I am just saying, those of you that think you need to beef up the glass, you would be suprised how strong it really is if you have it mounted in a decent application.
Mordachai, if you make the front and rear skins, I would be interested, as my Blazer will see the same terrain that my old truck did. Weight is also a concern for me. Thanks.
Old 08-11-2008, 06:47 AM   #38
vtblazer
vtblazer's Avatar
I would soooo love to do that some day!
No intent to hi-jack but how's your build coming along?
vtblazer is offline   Reply With Quote
Old 08-11-2008, 08:19 AM   #39
sandking
sandking's Avatar
Sssslllloooowwww. I got stuck on the front axle. I will update my build thread soon.
Old 08-11-2008, 02:02 PM   #40
Mordachai
Mordachai's Avatar
I'm pretty sure the panels you are talking about are all ABS, PU, or HDPE plastics.
They are usually thermoset(melted) through holes in the metal frame.
BMW, Mercedes, of course Saturn all have some plastic body panels.
Bodymen have a special tool that melts the plastic stub into a liquid rivet on the backside of the mounting areas. It's pretty cool.
As for placing them in your fender, find some one that has a jenny or swage roller. It'll make the l shaped flange for you. You could also use a bead roller and then flatten the inside half of the bead.
I used to be able to get a line of specialty hot glues that bonded or temp bonded different or similar materials together depending on application.
I'll see if I can get something for steel to fiberglass. If so, I could supply a few sticks with every skin.
For the thickness around 1/4", but depends on the resin. PE or VE resin would be more like 5/16", and epoxy would be closer to 3/16".
Old 08-11-2008, 09:41 PM   #41
jaros44sr
jaros44sr's Avatar
Sounds like you have way more knowledge than I do on the subject, but at least you understand what I want to do. With the metal frame of the fender, I would have support on three sides, top, front, and back. I plan on at least 1" flange all the way around
This body shop up in NJ was putting a Japanese pickup bed together, metal skin to metal inner bedside, and showed me the bonding process. He said no welds just the glue
I have pneumatic flanging tool, I was just going to machine the jaws to the proper thickness, if they are hardened, I'll use a surface grinder
The rivets would be used for more of alignmnet, I don't think they would have much holding power, the glue would do that, maybe it was Ferrari that was using a glue that bonded fibreglas to metal, heard it somewhere. Would you have a scrap pc. of fibreglas down there, 6"x6", that I could start experimenting with? Wait, maybe it was Corvette, with their Alum. frame (Z06)...Thanks
SAFETY FIRST
AS usual, off topic
Jim
Old 08-14-2008, 01:19 AM   #42
skchevota
skchevota's Avatar
I would love a set , then i could ditch the body lift!!!!
skchevota is offline   Reply With Quote
Old 08-15-2008, 09:32 PM   #43
Senator350
Senator350's Avatar
voted for 4" width, 2" height, 1.5" flare.
and i'm in the market for a pair of fenders inside a month.
sell me some. PLEASE! i'm very eager to gain some clearance for 39"s.
i'm glad you seem to have noticed that those of us who actually have modified our fenders have nipped the front bottoms off, somewhat in line with the grill surround line. this is a pretty important point (no pun intended), even with the 4" overall width expansion of the arch. i hope your final design for the fenders incorporates at least a little nip of the front bottom.
eagerly awaiting your progress, as i NEEED a front that's wider to match i full width dually rear when i'm running street wheels, but still be functional when i swap on my H1's with their 7" backspacing for a romp through the woods.
cheers!
RN U OVR
Senator350 is offline   Reply With Quote
Old 08-16-2008, 02:28 PM   #44
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 08-16-2008, 06:07 PM   #45
Mordachai
Mordachai's Avatar
Hey a quick update.
Pulled my fenders and started to mock them up.
I'm in need of extra fender lips and some other sheet metal to make the model for the molds, so waiting for that.
In the meantime, I'm going to make the molds for the supports on the back of the fender for the people that want truly bolt on applications.
I'm making separate molds for that inner support, as I'll be offering three variations of each fender.
1. Just a fender skin with the larger opening. These would be grafted to a cut metal fender like discussed above.
2. A full fiberglass fender with stock mounting points. They would bolt in at all the stock locations, and have a fit and look just like a GM part(what I'm aiming for anyways), but with a larger opening.
This variation will require a steel support to be fabricated to run from the Cowl mounts(or the firewall) to the Radiator support. The steel will be needed to support the radiator support, the hood, and anything else that would normally mount to the fender, as a fiberglass fender, no matter how strong will probably not support a steel hood on stock hinges.
Something like this would be needed:
I made them out of 1.25" box tubing, when I reassemble the truck I will run any wiring through them with caps to hide the wires.
You could easily weld a plate on this type support to have a location to mount the stock hinges/hood, or anything else you would like to mount there.
I have noticed alot of the 4x4's have cages or some sort of added tubing to the chassis, and could be easily modified or added to in order to accommodate the hinge/hood mounts.
3. A full fiberglass fender with an inner support that has a piece of plate steel laminated in that inner support mold. There would be a jig shaped piece of steel laminated in the inner support, which in turn will be laminated to the fender.
This variation would be a true bolt on part, with more than enough strength to support the hood, the radiator support and anything else mounted on the inside of the fender.
Senator- the little nip you are talking about is not a problem at all. I can incorporate a full lower cup, or a cut cup, as much as you would like. The design of the mold and the method of layup will allow me to custom 'tailor' the fender to each individual's needs(with a trade secret!) and still have a factory finish with no sloppily cut edges.
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
Old 08-16-2008, 06:50 PM   #46
Senator350
Senator350's Avatar
trade secret?
RN U OVR
Old 08-16-2008, 07:18 PM   #47
Mordachai
Mordachai's Avatar
^ hahaha, but nope, not even close. Cutting with a sawzall, wheel, body saw etc will leave a 'rough' edge that needs to be resealed and refinished. without taking time to reseal the edge, and make sure it's done well, moisture can wick in the edge, causing delamination over a period of time.
It's thermo-stable wax, and that's as much as I'm going to tell.
Although you can probably figure out the gist of it!
Old 08-20-2008, 06:59 PM   #48
Senator350
Senator350's Avatar
progress?
RN U OVR
Old 08-20-2008, 08:51 PM   #49
Mordachai
Mordachai's Avatar
Yep making progress, Waiting to get the metal parts I need to make the fender model for the mold.
I'm prepping the inner supports so I can make the molds of them this weekend, so that part will be out of the way.
I am going to Colorado in the middle of September for a week or so.
I want to have the molds all finished, and staying on the model while I'm gone so they cam fully cure on there. That will minimize any shrink or warpage that might occur if you pull the molds before they've finished curing. When I get back, I will clean and polish the molds and then I can start making fenders!
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
Old 08-20-2008, 09:03 PM   #50
sandking
sandking's Avatar
Are you going to be able to make just the outer "skins" as previously mentioned?
