01-12-2009, 12:34 AM | #26 |
Never Ending Projects
Re: Project: Hot Rod Hauler (HRH) Build Up
Did a little more work. Got the rear end painted and the new Trans Dapt chrome cover on. Also got the flange on the axle hubs machined off, so the Impala rotors will sit flush with the hub face. Need to get the axle installed next.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
01-12-2009, 12:43 AM | #27 |
Lookin good man! Makin good progress
01-12-2009, 12:54 AM | #28 |
Thanks Lucky. Funny you're the first to post up, it was pics from your built thread that actually got me to buy the chrome cover. It looked cool on yours so I copied it.
01-12-2009, 01:00 AM | #29 |
Hey cool, glad I could influence someone I have my eye on your build, so when you post progress I am all over it
01-12-2009, 01:02 AM | #30 |
Oh, and did your cover come with new bolts? Mine did, and they were nice and shiny but they didn't fit the holes? So I had to go back and use the OG crusty bolts. Just curious if you had the same problem....
01-12-2009, 01:08 AM | #31 | |
I just used the stock ones for now but will be swapping them out, maybe to stainless socket head with washers.
01-12-2009, 01:13 AM | #32 |
Ok thats good. I don't know why mine didn't work.
01-12-2009, 09:38 AM | #33 |
Restoration Virgin!
Nice Build Mike....Looking forward to watching this one progress....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
01-12-2009, 10:40 AM | #34 |
Restoring a 68 SWB
Is the new rear end setup for a panhard bar, or what are you plans there?
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
01-12-2009, 11:08 AM | #35 |
Using a ECE Super Track Bar kit, which moves the mount to the pass. side trailing arm. One of the nice things about using a rear end that did not have a track bar mount, once done, it will look like it was meant to be there and not have an unused mount on the axle housing.
01-12-2009, 05:23 PM | #36 |
nice work!
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
01-12-2009, 09:39 PM | #37 |
Formerly- 1972SuperCheyenne
Looking great, keep it up.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
01-15-2009, 12:34 AM | #38 |
Finally, some light at the end of the tunnel. Made some good progress on the back half of the truck. Basically got the axle, springs, panhard bar and shocks mounted. Still need to torque a few bolts down. I then started mocking up the disc brakes using the brackets I got from a board member. Been doing a lot of cleaning and painting of parts, which just takes forever to do. Here's the pics of the current progress.
01-15-2009, 12:37 AM | #39 |
And so more... mainly brake mock up.
01-15-2009, 12:41 AM | #40 |
Looking good that rear looks real nice
01-15-2009, 02:26 AM | #41 |
I agree. I put a 13" wheel on my '72. Made it weird to drive. Once I get it running again, the original wheel goes back on.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
01-16-2009, 12:08 AM | #42 |
cadi brakes I presume
bogey5 |
01-16-2009, 12:26 AM | #43 |
Nope, Camaro calipers with Impala rotors. Caddy brakes suck, especially the e-brake part comparted to the PBR calipers. I have known, seen and read about too many issues with the Caddy ones. I have used the Camaro (PBR) and they work very well. That's one reason Baer brakes uses them on a lot of their systems.
02-05-2009, 11:43 AM | #44 |
It's been a few weeks since my last update. So much going on I haven't had a lot of time to work on it but I did make a major step last night. I finally finished up the back half of the truck. It is now sitting on its own wheels again (temp ones at that). The last thing I need to do is to make sure the rear end is centered and then tighten up the panhard bar bolts. Then I need to attach the e-brake cables and put gear oil in. The fact it's a roller again is a major step. Now I get to move onto the front end. I have decide to put the front clip, engine and tranny, which will make cleaning, painting and putting the front suspension back together much easier.
Here are the pics from finishing up the brakes and lines. A little bead blasting and the calipers look like new. Back on its own wheels.
02-05-2009, 04:22 PM | #45 |
PROJECT 7DEUCE
Looking good looks like ya got a new drive shaft also..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
02-05-2009, 04:29 PM | #46 |
That's my original one that I had rebuilt, balanced and painted. I was going to put it in but decided I am pulling the engine/tranny so it didn't make sense to do it yet. It's all ready though.
02-21-2009, 11:07 PM | #47 |
Finally got some time to get back on the project. Removed the front clip. Overall it went very well without any real issues. Next step should be removing the suspension and then the engine and tranny.
Hood off Front bumper removed And now the front clip
02-22-2009, 01:11 AM | #48 |
Resident of Here
I love this build. Keep up the good work!
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
03-15-2009, 10:11 PM | #49 |
Well, it's been a little longer then I had hoped to get back to work on the truck. Last month we adopted a dog and a lot of attention has been spent with her. She is a sweetie but a lot more time has been spent walking and training her. Here name is Ellie.
Here's our sweet girl Okay, now the truck. Started pulling the engine and tranny Part way out Hey, who stole my engine??? Oh... there it is... boy is it dirty! Here is the engine I am going to put in. Came out of a friend's '69 Camaro and is a little better performance then what came out. Need to clean it up and paint it. I have a bunch of dress up parts for it. Now I need to clean up the frame and front suspension, start paint it and get the new suspension and steering parts installed. Little by little...
04-14-2009, 11:04 AM | #50 |
Finally got some free time again. Decided to pull the cab off the frame. That was an entertaining project. Since I still have the doors on and the full interior in, including the gas tank with gas in it. I managed to do it without killing myself or hurting the cab but there were a few times I wasn't sure of the outcome.
Cab and frame seperated Cab on 4x4's and jackstands. With the front and rear ends resting on car dollies, I can just squeak the frame under the bottom of the 4x4. Now I just need to find a place to power wash and strip the front half of the frame.
