07-27-2011, 10:21 PM | #26 |
Just here to tinker
Re: lets hear those engines! 73-87 trucks!
Here is my '78 factory 5.7 Diesel. It still has the corvair turbo mufflers that were installed in 1979.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) Last edited by Corts60; 07-27-2011 at 10:26 PM. |
07-28-2011, 12:59 AM | #27 |
@CrewCabMan
Thank you. Its a 406 with 10.1 comp, 5.7 rods and 291 heads. The cam is a Crane Cams Energizer 302H has .500 lift and 246 duration at .050.
http://www.cardomain.com/id/rcflyer1234 http://www.youtube.com/user/liftedtruck77 |
07-30-2011, 09:46 PM | #28 |
The first part of this clip is the same as the first one I posted, but the second half of it also shows my 78 K10 with 3/4 ton axles and 412 small block running. I should have posted this clip in the first place but I forgot that I had it.
11-22-2011, 07:30 AM | #29 |
running flowtech long tube headers, true dual 3 inch exhaust with 3 inch in/out cherry bombs. mainly cause with open headers i can vibrate every window in the house. open headers http://www.youtube.com/watch?NR=1&v=_GVgqIV6iHk plan on switching to Thrush welded aluminized mufflers soon.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L |
11-23-2011, 10:15 AM | #30 |
11-23-2011, 10:56 AM | #31 |
When I first fired it up idling a bit high.
http://s1082.photobucket.com/albums/...t=7fde5fce.mp4 Now with idle adjusted and timing locked down. http://s1082.photobucket.com/albums/...t=675d429a.mp4
84 GMCummins 91 CCSB Dually american squarebody association Last edited by bustedknuckles; 11-23-2011 at 11:02 AM. |
11-25-2011, 12:48 AM | #32 |
Forgot to add my exhaust specs.
Stainless ebay chevelle mid length headers, 3" pipe w/ 2.5" h-pipe, flowmaster super40s dumped. also, I can't figure out how to embed the vid??
84 GMCummins 91 CCSB Dually american squarebody association |
11-25-2011, 12:49 AM | #33 |
Already posted here but I put a new engine in, here's a video before adjusting carb/timing.
Has Longtube headers, no catalytic converters, true duals, flowmasters... thinking of going thresh welded mufflers maybe
1983 Chevy lwb: 400 sbc destroked to 377, comp cams xe 268, Holley Street Dominator Intake, Holley Street Avenger 670 cfm, headers, flowmasters. SOLD 1998 Trans am, mostly stock with magnaflow catback My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=454329 |
11-25-2011, 07:39 PM | #34 | |
11-25-2011, 09:06 PM | #35 |
Navy Radioman Veteran
Here's mine:
1976 3/4ton Farm truck 454 rebuilt in my '87 SWB.
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside |
11-29-2011, 04:34 PM | #36 |
Here's that same 377 in my last video but now the carb and timing is set.
11-30-2011, 12:11 AM | #37 |
11-30-2011, 02:13 AM | #38 |
Here is mine, .060 over 350, summit 224/224 cam, pete jackson gear drive (hate it), 3/4 chevelle headers, 2.5" piping and summit turbo mufflers turned down at the axle.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
12-29-2011, 01:00 PM | #39 |
Hooker long tubes, 3" with H pipe, dynomax super turbos
12-30-2011, 07:35 PM | #40 |
how do i post a youtube vid on here?
12-31-2011, 12:53 AM | #41 |
Copy the YouTube link and paste it in the body of your post. Once that is completed you can do a preview post to make sure it works before you you hit "submit reply". *
I had to do it using my laptop, for some reason I couldn't the YouTube link to work using my iPad.* Posted via Mobile Device |
12-31-2011, 03:55 AM | #42 |
my 74 with 2.5 inch exhaust and thrush turbo muffler. want to get headers soon.
12-31-2011, 03:36 PM | #43 |
http://www.youtube.com/watch?v=wE4SadpJWUw
My old small block. 3" exhaust, 2 chamber flowmasters and no tailpipes.
1987 R10 Pump Gas 496/TH375 Best 1/4 pass to date 60' 1.49 1/4 10.93 MPH 120 |
12-31-2011, 04:03 PM | #44 |
edelbrock intake and holley carb on the motor insides are all stock 2-1/2 on the exhaust with two flowmasters dumped http://youtu.be/GTrfVjj0vps
01-05-2012, 06:26 PM | #45 |
This is the only good video I have of my truck, havent gotten around to doing an actual exhaust video. Stock 350 with headers, 3" true duals and stainless steel Flowmaster 40s, exits in front of the rear tires...
~Wooden Indian~ 1979 C10 SWB, shaved bed rails, drip rails, tailgate handle. 350 w/ Comp cam, hydraulic lifters, Edelbrock Performer intake, Edelbrock 650 carb, Flowtech headers, Flowmaster 40s, turbo 350 w/stage 2 shift kit...so much fun! |
01-06-2012, 10:56 PM | #46 |
Location: Hickory, NC native, but stuck in Valdosta, Ga
02-28-2012, 10:14 PM | #47 |
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
02-28-2012, 11:09 PM | #48 | |
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
02-28-2012, 11:29 PM | #49 |
02-29-2012, 01:41 AM | #50 |
Tags |
loudest thread! |
