Old 02-22-2015, 08:19 PM   #26
LDO
LDO's Avatar
Re: Lets see your gauges setups
Originally Posted by 66LSx View Post
Speedhuts....
Their simply awesome....
You know, I've been leaning towards Dakota Digital but lately, these are lookikng better and better; with red lighting of course...
LDO is offline   Reply With Quote
Old 02-22-2015, 08:59 PM   #27
Mjminino
66LSX, I know I talked to you before about you're gauges, simply beautiful. One thing
I didn't ask was; What all does the digital display on the spedometer display. just trip and odo?
Mjminino is offline   Reply With Quote
Old 03-04-2015, 07:53 PM   #28
hillbean
Thanks guys time to go fleabay hunting
hillbean is offline   Reply With Quote
Old 03-04-2015, 08:25 PM   #29
Hugh in NC
Hugh in NC's Avatar
Autometer Sport Comp gauges. Boese insert.
Hugh
Hugh in NC is offline   Reply With Quote
Old 03-04-2015, 08:27 PM   #30
61ChevyPanel
Active Member
61ChevyPanel's Avatar
I did all the aluminum work.
61ChevyPanel is offline   Reply With Quote
Old 03-05-2015, 01:54 AM   #31
Captainfab
60-66 Nut
I like that. Are those switches in the upper part of the center panel?
Old 03-05-2015, 08:24 AM   #32
corvettejim1968
corvettejim1968's Avatar
before powdercoat
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 03-05-2015, 05:37 PM   #33
Mjminino
that cluster is sexy Jim
Old 03-05-2015, 10:07 PM   #34
boat
boat's Avatar
It's not wired up yet Name:  image.jpg
STEVES 63 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=412554 GIBSON63 YouTube channel https://www.youtube.com/user/1gibsonl4
boat is offline   Reply With Quote
Old 03-05-2015, 10:52 PM   #35
Joe Pass
Joe Pass's Avatar
Originally Posted by boat View Post
It's not wired up yet Attachment 1373249
Very nice
Joe Pass is offline   Reply With Quote
Old 03-05-2015, 10:58 PM   #36
Joe Pass
Joe Pass's Avatar
Old 03-07-2015, 09:36 AM   #37
turbohounds
I'm trying to use as many of the leftover parts from my Chevelle as possible. The '65 SS gauge cluster fits fairly well. I added green LEDs from Ron Francis for turn signals. Haven't decided yet whether I need to make bezels for the left and right pods. I'm sure there are better ideas for the backing than diamond tread, but it's what I could find.
turbohounds is offline   Reply With Quote
Old 03-07-2015, 05:47 PM   #38
Popcorn W
Popcorn W's Avatar
Anybody thought about using a GPS Speedometer? I think that's the route I'm going.
They're a little pricey, but 100% accurate, and no cables or sensors to worry about.
Just a power wire and you're good to go.
http://www.speedhut.com/gauges/GPS-S...KtMaAmow8P8HAQ
They've even got odometer and trip odometer too.
To me, it's worth it to not have to worry about getting an accurate speedo hooked up.
They do have an external antenna but I assume it would be just like a GPS in your car, just set it on the dash.
My build thread:
Project Moonshiner Bagged & Z Frame 63
http://67-72chevytrucks.com/vboard/s...d.php?t=659205
"I love the smell of grinding metal"
Popcorn W is offline   Reply With Quote
Old 03-07-2015, 08:05 PM   #39
Mjminino
what if the gps has bad signal??
Old 03-08-2015, 12:22 AM   #40
par4tom
Stock gauges with refinished display. Old School...
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 03-08-2015, 09:18 PM   #41
Mtrhd329
Heres mine. I had an old 94 z28 cluster laying around and i jeeded electric gauges with my 5.3l swap. Went together pretty easily
Mtrhd329 is offline   Reply With Quote
Old 03-08-2015, 10:35 PM   #42
Mtl-Marc
Originally Posted by Budman56 View Post
Here is mine but it not in the truck yet
There was one for sale on ebay last month.
Mtl-Marc is offline   Reply With Quote
Old 03-08-2015, 11:00 PM   #43
Joe Pass
Joe Pass's Avatar
Is that silver detailing around the gages...?
Old 03-09-2015, 08:36 PM   #44
Captmatt
Here's mine
Captmatt is offline   Reply With Quote
Old 03-09-2015, 09:09 PM   #45
Mjminino
That's interestingly cool
Old 03-09-2015, 09:26 PM   #46
Joe Pass
Joe Pass's Avatar
That's clean....
Old 03-10-2015, 11:29 PM   #47
Mackie
Mackie's Avatar
My `63 came with a repop cluster when I bought it. I cut "windows" in the Gen and Oil idiot light spots to resemble the needle windows of the fuel and temp gauges then RTV glued eBay Jeep volt and oil gauges to the back side.
Redneckin fer shore.
Mackie is offline   Reply With Quote
Old 03-11-2015, 04:57 PM   #48
61ChevyPanel
Active Member
Yes the black things in the center of the dash are aircraft switch covers. I use them for ignition power & other stuff. The ignition switch is gone and I mounted the light switch vertically under the dash.
Old 03-14-2015, 11:54 AM   #49
64chevycrewcab
Pyro and Tach for the 453 Turbo Detroit Diesel in a 1961 K20 long stepside
1961 Apache 10 with side trim
1964 4 door crew cab C20
1966 Chevy Suburban with custom trim
1961 K30 with a 4-53T Detroit diesel
1966 GMC 4X4 Suburban
64chevycrewcab is offline   Reply With Quote
Old 03-14-2015, 03:18 PM   #50
gmcdeadhead
gmcdeadhead's Avatar
Hugh in NC, what size are those autometer sport comp gauges ? and what's the thickness of that boise aluminum insert ? i am going to make my own inset and would like to no the thickness i could use. thanks
gmcdeadhead is offline   Reply With Quote
