Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-13-2016, 01:52 AM   #26
Nitis
Nitis's Avatar
Re: Fitech swap on my 1972 K20
what did you do with your return vent line from the FCC?
Nitis is offline   Reply With Quote
Old 02-13-2016, 09:23 AM   #27
CUSTOM/10
CUSTOM/10's Avatar
Did you have to run a return fuel line back to the gas tank ?
Also what about venting, do you have a vented cap or a vent line of some sort ?
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 02-13-2016, 01:32 PM   #28
coopdog
coopdog's Avatar
For know I just vented it to the ground , worked fine , I plan on running it to the vent on the tank.
Went for a quik rip in the old girl , as you can probably see in the pick there is a little snow on the ground but you only live once right!
.................._____
__________//___{\____
/__---____//____/__---/
.....(O). ..................(O).
BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4
coopdog is offline   Reply With Quote
Old 02-13-2016, 01:39 PM   #29
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Nothing squirts out the vent hose but air?
66 C20 Service Truck:
Old 02-13-2016, 03:57 PM   #30
coopdog
coopdog's Avatar
So far yes
Old 02-22-2016, 11:26 PM   #31
tjsblazer
tjsblazer's Avatar
Looks like from the fuel routing you mounted the fuel center on the drivers side of the truck. Do you think it could fit on the Rh side behind the battery in the corner. Near where the cannister mounts?
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 02-24-2016, 09:26 AM   #32
coopdog
coopdog's Avatar
It would be tight, especially with the battery and all that on that side. I would just mount it on the driver side like I did ,
Good luck
Old 02-24-2016, 09:32 AM   #33
coopdog
coopdog's Avatar
More pics
Old 03-10-2016, 08:45 PM   #34
First c10
First c10's Avatar
Quick question.
Have you noticed any problems with the fuel command center starving the throttle body when climbing or off roading? Fitech told me that sometimes the fcc will not fill up by the stock pump... He said that the fcc is basicly a larg fuel bowl that works on a float..
Nice truck by the way.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-10-2016, 09:25 PM   #35
coopdog
coopdog's Avatar
Thanks man, nope I Have not noticed a problem yet, will let u know if I do
Old 04-25-2016, 04:00 PM   #36
First c10
First c10's Avatar
Hey coop,
How is the truck running???
I have been waiting on the FCC and carb/throttle body as it is back ordered till 5/6. On my 68 I had to add a vent line at the tank sending unit since 68 had no vent just the vented cap.
Do you mind snapping a few pictures of how you mounted the FCC and how you routed your fuel lines and vent line?
I appreciate it
Scott
GO GO!!!
Old 04-25-2016, 09:18 PM   #37
coopdog
coopdog's Avatar
It's funny you asked about the old girl, I was just sprucing her up for the prom that's in a couple of weeks!!
Yes yes , the truck runs really good, me and my old man did some fine tuning to get it just right.
Here are some of the pics u requested
Old 04-25-2016, 09:19 PM   #38
coopdog
coopdog's Avatar
Command center
Old 04-25-2016, 09:19 PM   #39
coopdog
coopdog's Avatar
Vent line
Old 04-25-2016, 09:20 PM   #40
coopdog
coopdog's Avatar
Old 04-25-2016, 09:21 PM   #41
coopdog
coopdog's Avatar
Old 04-25-2016, 09:25 PM   #42
First c10
First c10's Avatar
Looking good man! I cant wait to get my set up. How did you run the high pressure line from the pump to the TB? and is that the controller in the cup holder???
GO GO!!!
Old 04-25-2016, 09:27 PM   #43
coopdog
coopdog's Avatar
Old 04-25-2016, 09:39 PM   #44
coopdog
coopdog's Avatar
I ran the high pressure fuel line from the FCC then through the driver side fender and then had it come in the back side of the throttle body, it all worked out pretty slick if I do say so my self !!!!
Old 04-25-2016, 09:41 PM   #45
First c10
First c10's Avatar
Nice ok cool Thank you
GO GO!!!
Old 04-25-2016, 09:43 PM   #46
coopdog
coopdog's Avatar
And yes I ran the controller through the glove box , it comes with the window cling but I thought it looked classier tucked away in the GB , when I go driving I just lay it in the consoles cup holder , and at shows I hide in the GB
Old 04-26-2016, 05:30 PM   #47
Birdman72
Awesome truck. I am wanting to do this efi swap on my truck also.What performance gains did you get. More power, better throttle response ?.
Birdman72 is offline   Reply With Quote
Old 04-26-2016, 06:03 PM   #48
Birdman72
This is a pic of mine at a show.
Old 04-26-2016, 09:45 PM   #49
coopdog
coopdog's Avatar
Killer truck birdman,
Yes, I do see a huge difference in throttle response and power, the truck truly drives like a new car now , I am very impressed. you literally turn the key and go!
Old 04-26-2016, 11:10 PM   #50
Birdman72
Re: Fitech swap on my 1972 K20asw
Awesome,I have been thinking on the fi tech swap for a while but wasn't sure if was worth the money.I have heard nothing but great reviews!!!:
