#476 |
Re: 1952 Chevy Vette Roadmaster LT1 Farm Truck Build
I am using a 16" Derale 16136. All the good aftermarket fans should be similar.
I never had any luck with the fan temp probe in the block as the thermostat keeps the engine at a consistent temp. But there is no pcm.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#477 |
Thanks again JJ!
Looks like the Spal I'm looking at is pretty much the same as the Derale you are using. Where do you order your parts from? Even with the crappy dollar, it's still cheaper on a lot of things to get them out of the states.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
#478 | |
Simple? What's simple?
![]() Join Date: Apr 2007
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
#479 |
Just noticed JJ but I meant to ask Lowers where he orders his stuff fro as he's in Canada too. Brain fart on my end.
Question. What year of S-10 are you guy's using the brake pedal assembly out of?
#480 |
on my 51' I used a brake pedal from a square body s10. I just bought a corvette pedal assembly off egay for dirt cheap should work out pretty similar. I used a 98 Silverado pedal on my 49' little taller allowing the booster to go up higher. I like it. I like the s10 pedal setup the least.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#481 |
Mine was out of a square S10 as well, '87-'93 vintage. I think a fullsize truck bracket from the '88-'98 realm might work reasonably well, too.
**EDIT** saw 99 to Life recommended the '88-'98 bracket, too ... so +1 ![]()
#482 |
Thanks guys! Maybe I should be rethinking things. I have a booster MC coming. Thinking of using a factory pedal and bracket such as the s10 as I don't know the dimensions to build my own. If anybody has ideas, please share.
#483 |
I was thinking of building my own on last two builds and just became easier to use one that was already someone done. but... it would be easy to build non the less.
#484 |
Congrats to your son and the proud ole' man! Great memories for sure.
Build is looking great! I still order from Summit now and then. Some stuff there's not a ton of options and have to go State side. If youre close to the border get it shipped to a UPS store and pick it up there. A lot of US based companies offer free shipping within the States. Last edited by 4DSEVEN; 02-06-2016 at 08:14 AM. |
#485 |
Thanks 99. Have any pictures of the 98 brake pedal assembly? Found your S10 setup in your builds. What year Vette assembly did you get? No sense in re inventing the wheel!
Found your bracket mods in your build JJ. Great work and very detailed documentation! Will be referencing that for sure. 4Dseven. That's pretty much what I have been doing too. I have a shipping address at Wellesley Island just across the border at thousand islands. I actually have a rad and fan sitting there ready for pickup. Waiting on a few more parts to come in before I go and pick it all up.
#486 |
corvette was c4 90-96 automatic pedal. Here is the 98' set up
#487 |
here is the pedal I got, this one is on ebay right now same price, same seller. only mine came with the brake light switch, but those are dirt cheap. Preliminary viewing, the bolting pattern on the back of the pedal most likely isn't going to line up with the booster I have. So.. I'll confirm that tomorrow. If I was a real man I'd have a friggin tig welder and I could work with this aluminum bracket. Since I'm a pauper, well I'll have to bolt a plate with the right bolt pattern to this and mount to firewall that way. Which... isn't bad to do since you need to reinforce the firewall anyway, the plate will serve two purposes.
#488 |
Thanks 99! Pictures and info is a great help. Found a guy parting out a 1992 and a couple 1997 trucks. Is there a prefered year of truck to get the brake assembly out of that you know of? I'm gonna take your advice and get a longer siverado setup.
#489 |
well, my pedal came out of an automatic and let me tell you, was the biggest nightmare I ever had taking something out. There are lots of spot welds on the top, some of which I had to cut a hole in the cowl from the outside to drill them out. So if you can get in there and torque it out, I'd suggest that. If you could find one out of a 73-87 I bet it would work just as good and easier to take out.
#490 |
![]() Join Date: Jul 2012
Sid, have you considered this one from Speedway?
http://www.speedwaymotors.com/Univer...unt,59785.html Reaper71 used it in his Orange truck build and it is $80. Has good reviews. |
#491 | |
#492 | |
#493 |
Yes I believe the 73-87 assemblies unbolt. My mid '80's chev van pedal did.
#494 | |
#495 | |
#496 |
Re: 1952 Chevy Vette Farm Truck Build
Jim, just reading thru your build. I'm doing C4 with flatout. I see early on you indicated that you wish you had done the front suspension first. I was thinking of starting on the rear first. What was your reasoning there ? Thanks Jay.
#497 |
The reason I said that was because of the way the rack mounts to the cross member which limits how low one can get the front. That's with my type of front cross member anyways.
#498 |
I understand know. I think I'll take your advice and mock the front up first. Thank Jim. Appreciate the quick response.
#499 | |
#500 |
I go the pan from a private seller. It came with the pan, windage tray and pickup tube.
https://www.superchevyperformance.co...tCode=12628771 Above is a pan and the related parts are available there too.
