12-03-2010, 01:16 PM | #501 |
VA72C10
Re: Project: Recycle
Chassis looks great! And I like the clamps too
Looking for a 67-72 swb or blazer project in or around VA. |
12-04-2010, 01:58 AM | #502 |
Drumroll . . ..... the chassis for 'Recycle' officially touched mother earth tonight.
There's no air in the bags (no air-lines yet) & it only has shocks on the front, but @ full dump, the frame rail was 2.5" (F) & 3.0" (R) @ the cab mount centerlines w/stock spindles (15" wheel, 27" tall tire). The upper BJ's appear to be binding (or the tie-rods) because the bags are @ approx 4.5" & the shocks are still @ 12". I should have another 1-1.5" to go up front. I'm going to disconnect the TRE's tomorrow & see if there's a change. The rear was/is the limiting factor (as planned). It's bottomed out in the c-notch. I'm thinkin' it will look pretty decent & should drive low full time w/plenty of ground clearance (my objective vs. trying to lay frame). I couldn't get pics as it was too dark for pics & my cell just can't capture a good image (the shop is crowded so it's hard to get a decent view). I plan to put some schraders into place tomorrow & will roll it out in the sun for some pics......
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-04-2010 at 01:59 AM. |
12-04-2010, 10:17 AM | #503 |
67cheby
its tomorrow ......
12-04-2010, 12:26 PM | #504 |
Happy to be here
12-04-2010, 12:30 PM | #505 |
67cheby
LOL, i am sure everyone on this board gets tired of me harrassing them and thinks i must have nothing better to do all day every day other than ask them for pics....... Well this is mostly true , i sell cars for a living 6 days a week 10 hrs a day and most of that time right here at my desk in front of this computer... so what i am saying is ...... WHERE'S THE PICS !!
12-04-2010, 07:47 PM | #506 |
Tough crowd. A guys gotta' sleep @ some point . . ....
12-04-2010, 07:49 PM | #507 |
PROJECT 7DEUCE
Scoti you did a killer job on that chassis congrats man..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-04-2010, 07:50 PM | #508 |
A few more . . ....
12-04-2010, 07:53 PM | #509 |
Happy to be here
Dude, sleep is waaay over rated. You will have plenty of time to sleep when you have passed on to that big garage in the sky.
Meanwhile, that frame is kickin. I love the clean fresh look....
12-04-2010, 08:15 PM | #510 |
67-72 parts collector,…
Beautiful chassis.
What did you use for washers under the heads of all the bolts? AN washers?
12-04-2010, 09:05 PM | #511 |
Senior Enthusiast
Absolute artwork. That chassis is really beautiful.
12-04-2010, 09:33 PM | #512 |
I'm just glad to be here!
That is just beautiful! I love the wheel/hub cap set up. I think that you had a 10" rear wheel made, what size tires did you use front/rear?
After reading your post about the front BJ binding, in the pictures it looks like your upper A-Arms are upside down, possibly swapped side to side (compared to other photos I have seen)? Am I missing something about that? Anyway, I am jealous of your progress...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
12-05-2010, 12:43 AM | #513 |
looks great
12-05-2010, 12:49 AM | #514 |
1 thing at a time is progress.
I'm speachless!!
Alan
Philippians 2:14-16 |
12-05-2010, 01:56 AM | #515 |
Thanks guys.
Lolife99, I used SS lock washers (the split-lock washers are readily available). This give more clamping force on the bolt/nut & keeps the end that turns off of the fresh PC/paint. I also used nyloc nuts everywhere except for the front shocks (not available in that particular sizing). All nuts/bolt for frame, brackets, & x-members is GRADE-8. The T/A mounts got GRADE-9. Aggie91, the a-arms are mounted different vs. typical set-ups. I tried them both ways & couldn't see any difference as far as functionality. The way I installed them just 'looked' cleaner. We also installed the BJ from the bottom of the arm (again, a cleaner look). My feeling is the binding is a result of absolutely no shims for the upper a-arms. Space them out .750" or so & I think I'll be fine. The tie-rods were definitely in bind..... As soon as I raised the suspension, I could easily adjust the toe; with it dumped, I couldn't get the adapter sleeve to budge. Rolling stock is 215-70-15's on 15x6's & 285-60-16's on 16x10's.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-05-2010 at 01:56 AM. |
12-05-2010, 02:29 AM | #516 |
60-66 Nut
Looks great Scot
12-05-2010, 09:06 AM | #517 |
Almost a shame to put the cab and bed on that, it's a rolling platform for your skills and abilities. Awesome
12-05-2010, 12:59 PM | #518 |
This is 'practice' for my 67 RetroRod. Definitely learned a thing or two here....
12-05-2010, 07:38 PM | #519 |
Job well done.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
12-06-2010, 02:19 AM | #520 |
chevy only
nice work!!! congrats i dig the caps and wheels
CHEVY ONLY... Nothin Else ! |
12-06-2010, 07:44 AM | #521 |
That looks great, I REALLY LIKE the tire/wheel combo! Where did you get those rear wheels?
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 Last edited by darkhorse970; 12-06-2010 at 07:47 AM. Reason: speeling |
12-06-2010, 08:15 AM | #522 |
Tot Roddin'
Awesome attention to detail!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-06-2010, 10:03 AM | #523 |
Had them built & I would not recommend the place that did it (Stockton Wheel).
12-06-2010, 10:40 AM | #524 |
Slots go on anything!
Definitely the right wheel and tire combo for this truck. Frame looks great, definitely worth all the hassle. When is the body swap party? I'm in!
1974 Jimmy- 5.3/4L80e/NP241 |
12-06-2010, 10:58 AM | #525 |
67cheby
cleanest Z i have ever seen, super nice job
