Old 02-24-2015, 04:11 AM   #551
RockTonka
RockTonka's Avatar
Re: 1958 Apache 38 Dually Dump Project
Originally Posted by ChuckDriver View Post
Awesome!
Thanks CD!
We added some side lights into the headache rack gussets...gonna give us 360 degrees of light when we want!
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 02-24-2015, 04:37 AM   #552
RockTonka
RockTonka's Avatar
As we continue to add weight to the back, the old rear springs keep flattening out. You can see the nose high stance in the first pic.
I spoke to a couple spring manufacturers and have plenty of options...except, we kinda need to have a realistic rear weight. That's not gonna happen until we get it closer to being done...still have a lot of weight to add with fuel tank, lift cylinder, and whatnot.
The short term solution for us was to add 3" lift blocks in back so we can continue building with a better idea of the angle of the dangle moving forward...rear driveline, new rear shocks (more on that in a couple days).
Instead of building new springs with overloads, we want to go with an air bag overload system. That way we can optimize spring design for vehicle weight and ride quality and not expected load capacity (i.e. crappy, stiff, ride)
So, that left a lot of frame brackets we didn't need anymore...held on by a couple dozen rivets.
Then that left a frame rail with a bunch of holes all over....so...
My build thread
Old 02-24-2015, 04:54 AM   #553
RockTonka
RockTonka's Avatar
We had a bunch of holes to fill!
We pulled the rear and put the truck back on the lift to work through some frame mods we wanted to try.
First, we decided to go ahead and box the rear section of the frame between the spring hangers.
My build thread
Old 02-24-2015, 05:12 AM   #554
RockTonka
RockTonka's Avatar
We're working through the passenger side frame rail first...this is going to take a few days to get done!!
With the frame boxed, we're gonna sink sections of pipe through it, ranging from 4" down to 2" along the length between spring hangers.
and weld those holes shut!
My build thread
Old 02-24-2015, 09:19 AM   #555
Kim57
Kim57's Avatar
You guys are doing some real neat stuff to the truck.
The frame is going to be stout and really cool looking.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-24-2015, 09:32 AM   #556
Advanced Design
Advanced Design's Avatar
Looks really good. Dumb question here...are the holes just to follow the theme of the build or will they serve some other purpose? Either way it looks very stout!
Advanced Design is offline   Reply With Quote
Old 02-24-2015, 06:37 PM   #557
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work guys! It's looking great.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-25-2015, 01:07 AM   #558
coops714x4
coops714x4's Avatar
really great work, I got a question do you plan on running the brake lines, wiring and air lines through the frame ? if so you might want to consider getting the hard lines in place first. keep up the good work, its gonna be cool. Coop
1971 K20, Coop's beast (project)
1972 C30 wrecker, "Big Ernest" (SOLD)
1975 K5 Blazer (wife's toy) she got it in the divorce
2014 Street Glide Special
1983 K20 Big Block, auto (work horse)
coops714x4 is offline   Reply With Quote
Old 02-25-2015, 01:41 AM   #559
RockTonka
RockTonka's Avatar
Kim
Thanks Kim!
Thank you AD! There are no dumb questions, and with us, there isn't always a legitimate reason we do things! We mainly like the look, but the boxing and thru tubes will add substantial strength to that section of frame.
Thanks DW!!
Thanks Coop, we will run all the lines/wiring externally on the frame. I like visibility/access if there are any issues and wouldn't trust pre-ran lines/wiring subjected to the heat of the welding we're doing.
My build thread
Old 02-26-2015, 02:53 AM   #560
RockTonka
RockTonka's Avatar
So, a bit of hole sawing (actually burned up one drill, had to go get another!), a bit of welding, a bit of smoothing, and the passenger side is done!
My build thread
Old 02-26-2015, 02:58 AM   #561
stersam
All of your guy's trucks are amazing. This and the Suburban are my favorite. I love the speed holes in the frame.
stersam is offline   Reply With Quote
Old 02-26-2015, 03:33 AM   #562
RockTonka
RockTonka's Avatar
Thanks stersam!! You have good taste...those two are my favorites also!!
My build thread
Old 02-26-2015, 08:16 AM   #563
Advanced Design
Now that is cool! Nice work guys.
Old 02-26-2015, 09:24 AM   #564
Kim57
Kim57's Avatar
Looks sweet.
Kim
My build thread
Old 02-26-2015, 05:00 PM   #565
Dieselwrencher
That looks awesome! Seeing that makes me think my 40 Ford's frame needs that treatment.
Ryan
Old 02-27-2015, 09:19 AM   #566
Baldeagle SR
That does look awesome. and it isn't even painted yet. Rich
my build
http://67-72chevytrucks.com/vboard/s...d.php?t=576185
Baldeagle SR is offline   Reply With Quote
Old 02-28-2015, 06:38 AM   #567
RockTonka
RockTonka's Avatar
Thanks AD!
Looks sweet.
Kim
Thank you, Kim.
Thanks DW! You should do it!
Ahhhh, paint...one of these days!
And the driver side is done...
My build thread
Old 02-28-2015, 10:33 AM   #568
Kim57
Kim57's Avatar
Very cool looking.
Kim
My build thread
Old 02-28-2015, 04:58 PM   #569
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
I like that!
ChuckDriver is offline   Reply With Quote
Old 03-02-2015, 11:12 PM   #570
RockTonka
RockTonka's Avatar
Very cool looking.
Kim
I like that!
Thanks y'all!
My build thread
Old 03-03-2015, 11:01 PM   #571
coops714x4
coops714x4's Avatar
man this truck is gonna be insane !!!! Coop
Old 03-04-2015, 12:04 AM   #572
dyno
dyno's Avatar
Love the frame mods. Awesome craftmanship!
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 03-10-2015, 02:39 AM   #573
RockTonka
RockTonka's Avatar
Thanks!
Part of the reason we are reworking the rear of the truck is to make room for a custom 44 gal. tank we ordered from Aluminum Tank Industries, Inc about a month ago. Tank came in today
My build thread
Old 03-10-2015, 02:56 AM   #574
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Looks sweet! It should get you a few miles with that big block ;-)
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 03-10-2015, 03:28 AM   #575
RockTonka
RockTonka's Avatar
Yea, just a bit farther than the stocker...
My build thread
