Old 05-25-2014, 09:40 PM   #576
tarafied1
tarafied1's Avatar
Re: 1967 Mustang Coupe Build (Electra)
so you replaced the lower cowl (patches) thru that hole in the side?
If you gut the dash (instrument panel, glove box, heater, etc. you might weld it from under the dash.
I had a cowl leak on my 67. Those rings are rusty were they are welded on. I used these little plastic things on mine and some windshield sealer. Did it all from under the dash.
married to TARA, that makes me the TARA-fied1
tarafied1 is offline   Reply With Quote
Old 05-25-2014, 09:42 PM   #577
JRANGER
JRANGER's Avatar
yeah i bought a set of those but when i took the air vent off so came that half of the cowl. So i cut that hole and fit enough in to cover. I was thinking i may be able to get it from the inside. Just gonna be hard to see and do that..
JRANGER is offline   Reply With Quote
Old 05-25-2014, 10:44 PM   #578
tarafied1
tarafied1's Avatar
Originally Posted by JRANGER View Post
yeah i bought a set of those but when i took the air vent off so came that half of the cowl...
ouch!
Old 05-25-2014, 10:59 PM   #579
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
I feel your pain... We took a different approach to the same issue on the 67. If I were to do it again, I'd simply shave the cowl vents, and pull air from a different source.
screamin_c10 is offline   Reply With Quote
Old 05-26-2014, 09:49 PM   #580
tarafied1
tarafied1's Avatar
looks like a pretty cool way to do it
Old 05-27-2014, 12:07 PM   #581
JRANGER
JRANGER's Avatar
Only reason i havent went that route is i have the car painted already lol
Old 05-27-2014, 09:10 PM   #582
tarafied1
tarafied1's Avatar
well, the cowl would be an easy repaint with hood and fenders off...
Old 05-28-2014, 10:05 AM   #583
JRANGER
JRANGER's Avatar
that is true...but id rather not..Plus cutting and welding on top is just iffy...Dont want to rove the windshield or burn stuff... But that is an option if this doesnt work out
Old 05-31-2014, 08:55 PM   #584
JRANGER
JRANGER's Avatar
Well my brushable seam sealer didnt show up today so i couldnt work on the cowl. So I decided to cut out and start working on the frame rail...
It was interesting..I originally cut it fit into the rad support beam but it was too far gone and i had to cut the edge of it back. So i moved the inner section back and welded to the rad support. I left a little bit hang over and cut it off after and banged it agaisnt it a little tigther.
Cut weld, cut weld, fit all sorts off stuff but the main focus was get the bolt for the bumper right. So i had a center line sharpy mark above everything to make sure i had it in the right spot. Eitherway, long day, ugly welds but its all in. Painted on the inside even and it was nice that it was in front of the angle support.
Just need to make a bit of an end cap for it
Old 06-01-2014, 01:03 PM   #585
cubber
I admire your motivation. That's a big job to tackle, but it looks like you have it under control.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 06-01-2014, 09:31 PM   #586
Rusbuilt
Rusbuilt's Avatar
Good job buddy!
Rusbuilt is offline   Reply With Quote
Old 06-01-2014, 11:38 PM   #587
JRANGER
JRANGER's Avatar
Thanks guys!
Old 06-02-2014, 12:04 AM   #588
thelonerife
thelonerife's Avatar
Glad your making progress. Looks good.
thelonerife is offline   Reply With Quote
Old 06-08-2014, 01:31 PM   #589
JRANGER
JRANGER's Avatar
Well bent the lip just a little but more and i was able to reach around the cowl and get it all gunked up. It is officially sealed on the drivers side. I ran a lot of water and no leaks. Even came out the drain hole properly lol
Once i get the passenger side done i can install interior!!!!!!!!
Old 06-15-2014, 07:29 PM   #590
JRANGER
JRANGER's Avatar
aint pretty but i welded it back together. Painted it, seam sealed it, and painted it again. I may have gone a bit nuts with seam sealer
Old 06-15-2014, 08:08 PM   #591
Rusbuilt
Rusbuilt's Avatar
Hey bro as long as it doesn't leak!!!
Old 06-15-2014, 08:29 PM   #592
JRANGER
JRANGER's Avatar
Exactly!! Tomorrow I start the passenger side
Old 06-16-2014, 09:05 AM   #593
67ChevyRedneck
67ChevyRedneck's Avatar
I spent my weekend pulling transmissions out of 3 different junkyard cars! I wish LKQ parts weren't so cheap sometimes... I pulled an entire T5 to get to an ~$8 clutch fork so I didn't have to buy a $65 one. It also worked out too. After I got my T5 home, the gears look GREAT in it, but the 1-2 shift fork was cracked. The car I pulled the clutch fork out on Saturday had a bad trans (all the gears looked like hell inside of it, otherwise I would have taken it home too!) so I took the shift forks from that. Girl couldn't find them in the computer so she gave me both for a $5 "bracket" price. I was back home in under 2 hours. It's easy to pull stuff when you don't care about the stuff around it!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-16-2014, 07:25 PM   #594
JRANGER
JRANGER's Avatar
Chopped open the passenger side and it was about the same as the drivers side. The cowl hood wasnt even attached and i was able to use my hand to pull a ton out Managed to squeeze the angle grinder in and do a straight cut along the one side and bent the rest out. Have to remove a little more and order the pass side replacement panel
Old 11-06-2014, 12:38 PM   #595
InitialBoss
Any progress on this or has the weather not been good to work on it?
1978 C-10 Custom Deluxe | I6 250 | SWB | Stepside
InitialBoss is offline   Reply With Quote
Old 11-06-2014, 12:43 PM   #596
JRANGER
JRANGER's Avatar
Ive got the piece fitted but thats about it. Ive been working on the truck trying to get it a little better and ready for winter. Its my "Bad roads" driving vehicle. So I have been welding on it instead of the mustang. Plus this side is a little more difficult because im trying to line it up with the heater box.
Old 12-23-2014, 10:30 AM   #597
JRANGER
JRANGER's Avatar
Well between the truck and the cold weather i let her sit too long. So i went out and she took forever to start but she started! Ohh the glorious sound of the v8.....Ive really got to get back to work on her
Old 12-23-2014, 12:11 PM   #598
Kerry P
It's alway good to hear them one in a while. I've missed the updates.
Kerry P is offline   Reply With Quote
Old 12-23-2014, 02:08 PM   #599
flashed
I went out to my shop the other evening after work and cranked my babies up and let them run a good long while .Its the first time in a while that I have felt like it ,been a bit under the weather but I do miss hearing and driving them.
flashed is offline   Reply With Quote
Old 01-10-2015, 05:37 PM   #600
JRANGER
JRANGER's Avatar
The passenger side is finally ready to weld in. I put a bolt in it to pull it down on the inside and will need to weld it all up. Its TOO freaking cold though, i went out and did 1 thing at a time for like 5 mins before going in for like 30.
Its suppose to be almost 50 tomorrow so i plan to try to weld it in then
