Old 02-02-2021, 12:40 PM   #576
daddyjeep
daddyjeep's Avatar
Re: Used Parts Build
Those little lights work good. I might have to get me some for under the Jeep.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 02-02-2021, 05:09 PM   #577
aggie91
I'm just glad to be here!
aggie91's Avatar
How well has that Krylon coating on the exhaust holding up?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-23-2021, 02:41 PM   #578
tinydb84
tinydb84's Avatar
For the price and the quality (at least as far as I can tell) they are really nice. Might get more if I find good spots for them.
I haven't driven it much but it seems to be holding up. The exhaust turbine is painted with the same stuff and under a blanket and its held up the same. While it scratched easily pre cured it seems to be okay now. Id try it again.
David
Instagram: myfabguy
Old 02-23-2021, 03:10 PM   #579
tinydb84
tinydb84's Avatar
My transmission was making a howling noise while in gear and stopped. It would go away in park and once driving though. After some research I figured the torque converter was bad. Bought a new one but hurt my back so it took a lot longer to get it in.
My wife got me this sticker. Hope it works through the computer so you can see it.
David
Instagram: myfabguy
Old 02-23-2021, 04:03 PM   #580
daddyjeep
daddyjeep's Avatar
Rick Astley????????????
04 1500 crew cab
Old 02-23-2021, 06:33 PM   #581
tinydb84
tinydb84's Avatar
hahahahah yep. Figured people would get a good laugh thinking it was something truck related when it is really a Rick roll.
David
Instagram: myfabguy
Old 02-24-2021, 09:50 AM   #582
daddyjeep
daddyjeep's Avatar
You can make your own custom ones so I was thinking maybe a link to your build here or something... This was better.
04 1500 crew cab
Old 02-24-2021, 02:14 PM   #583
tinydb84
tinydb84's Avatar
I'm glad someone appreciates it! I picked it for the recessional song at our wedding. She got to pick the processional song so I figured it was my time to shine.
David
Instagram: myfabguy
Old 03-08-2021, 02:01 PM   #584
tinydb84
tinydb84's Avatar
Replaced the leaking output shaft seal. Seems to be leaking a tiny bit still though from the yoke though. Any thoughts?
I have been driving it around my neighborhood a bit to get some shake down miles on it and not be to far from home if I don't make it.
Cut part of the bed mounts I made off so I can have them slotted for adjustment. Adding a bit more tube as well.
I would like to say I planned on removing the bed gap but I set my rear end to be centered at ride height and not when laid out. So I pushed the bed forward a bit to make up the difference. The black strip is primer that I need to rattle can white or something for the mean time. The bedside isnt mounted or anything since I need to tweak a few things first.
[url=https://flic.kr/p/2kJbn9C]
David
Instagram: myfabguy
Old 03-08-2021, 03:31 PM   #585
Joe Pass
Joe Pass's Avatar
Looking good.....finally comes together.....you might check the yoke center plug....knowned to leak ...several methods of repair but the most common one is JB weld coated...just a thought
Joe
Joe Pass is offline   Reply With Quote
Old 03-09-2021, 09:33 AM   #586
daddyjeep
daddyjeep's Avatar
Did you put rtv under that yoke nut? I'm not sure if it is necessary there as I don't have any 2wd stuff myself. I know I needed it on my transfer case output.
04 1500 crew cab
Old 04-06-2021, 05:29 PM   #587
tinydb84
tinydb84's Avatar
Joe
Thanks guys. It is a conversion yoke so it doesnt have the hole or anything. It doesnt leak much. I am wondering if I have it a bit too full. Ill keep an eye on it for now since I have more things to fix first.
I got the bed on and have been driving it a bit. Lots of little things to do. I need to run my airlines and valves next.
David
Instagram: myfabguy
Old 04-06-2021, 10:59 PM   #588
Joe Pass
Joe Pass's Avatar
Congrats...this is a big achievement......hard work and great results....inspiring to follow you through this and I'm looking forward to the future work...it's just the beginning lol
Joe
Old 04-07-2021, 11:51 AM   #589
daddyjeep
daddyjeep's Avatar
Looks good out there on the street... Congrats
04 1500 crew cab
Old 04-28-2021, 02:40 PM   #590
tinydb84
tinydb84's Avatar
Thanks guys. I appreciate it. Been taking care of all the little things while I drive it around.
Added a second tab to the exhaust to keep it from pivoting. The bushing came apart since the exhaust was twisting on it.
The blinkers wouldnt cancel and it felt funky when I went to signal so I replaced the cam.
Been driving it a few times a week to try to find all the bugs and break the rear end in before I get it turned and try to turn it up.
David
Instagram: myfabguy
Old 04-28-2021, 03:14 PM   #591
WilliamFd55
That last pic! Truck looks really good. Honestly giving me more motivation to finish mine.
WilliamFd55 is offline   Reply With Quote
Old 04-28-2021, 04:04 PM   #592
daddyjeep
daddyjeep's Avatar
Looks great. Glad you are putting miles on it.
04 1500 crew cab
Old 05-13-2021, 01:28 PM   #593
tinydb84
tinydb84's Avatar
Took way to long to get this done. Finally finished welding, stripped, and painted my raised bed floor.
Had to cut off my shock mount and move it down a quarter inch since my initial measurements were off and it hit the bed floor.
Finally got to play around with CAD and used Send Cut Send to make some tabs and brackets I needed.
I bought line lock because Amazon told me too... and drew up the bracket in CAD.
Need to plumb and wire it
David
Instagram: myfabguy
Old 05-13-2021, 07:37 PM   #594
Joe Pass
Joe Pass's Avatar
Great skills.....enjoying your build
Old 05-17-2021, 01:44 PM   #595
tinydb84
tinydb84's Avatar
Thanks Joe.
Got my truck back together so I could take it to a few meet ups. Did my first wash is like 8 years.
Now I need to figure out how to cover this all up.
Here is my idea. I plan on having the pivot on the forwardmost tube which means I have to pull the floor away from the cabside a bit before pivoting. I plan to run a wood floor and have maybe 3ish feet in the center that pivots. I saw this thread: https://67-72chevytrucks.com/vboard/...d.php?t=819450 and started playing with cardboard. This is roughly what I ended up with. You can click on it for the video.
I drew it up in QCAD (free software) and sent it over to Send Cut Send. Hopefully it works...I'll be out of town for the next week so hopefully I return to cool parts!
David
Instagram: myfabguy
Old 05-18-2021, 09:41 AM   #596
WilliamFd55
I drew it up in QCAD (free software) and sent it over to Send Cut Send. Hopefully it works...I'll be out of town for the next week so hopefully I return to cool parts![/QUOTE]
I see big things happening with "Send cut Send". Didn't know they existed? Thanks for the info.
Old 05-18-2021, 11:49 AM   #597
aggie91
aggie91's Avatar
I heard about Send Cut Send from another you tube account I follow. I see it as a great way for a lot of builders to step up their builds from the old methods of doing things with a cut off wheel and a drill.
From the pictures you shared, the parts looks great and come all deburred and looks like they used a surface belt sander on the face of the parts.
Karl
The LST Challenge:
Old 05-18-2021, 02:36 PM   #598
tinydb84
tinydb84's Avatar
I see big things happening with "Send cut Send". Didn't know they existed? Thanks for the info.[/QUOTE]
There is also a company called OSH Cut that does the same thing. I havent used them yet. I heard the prices are comparable. I love the cut/grind/drill but this stuff is so much cleaner and repeatable. It does get pricy though. The hinges came out to $120 to cut. Its all in stainless 1/4'' so it makes a bit more sense. The thought of cutting and drilling that much stainless makes the cost worth it though.
I hope to start learning the 3D program so I can really make cool stuff!
David
Instagram: myfabguy
Old 05-18-2021, 02:49 PM   #599
SCOTI
SCOTI's Avatar
A machine cut bracket is hands down better for repeatability vs. hand made. I go that route as much as I can when building things now.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-03-2021, 02:10 AM   #600
tinydb84
tinydb84's Avatar
Your work is probably significantly closer to machine cut than mine.
Drew up the brackets. Had them cut.
Here is a video of them in action. I think I would do them a bit different next time but they will work well enough (I hope).
Picked up this little fixture table off a company on Instagram (Dayton CNC). Was really cheap ($125) and seems to be high quality. Its small 6''x12'' but I figure Ill put it to good use some how.
Went to drive it tonight after being out of town and decided to look it all over first...
Universal coolant apparently doesnt work with dexcool. I didnt flush the engine before I hooked it all up. The rest of the system is new. I spend an hour or so flushing it with the hose. I ordered some radiator flush and will start again tomorrow. Ugh.
David
Instagram: myfabguy
