12-29-2016, 11:04 AM | #576 |
Happy to be here
Re: 85 GMC Sierra "Scarlett"
American Racing says 5-6 weeks build time.
12-29-2016, 11:16 AM | #577 |
Happy to be here
Last night I continued my search for wet spots. I started by pulling the cooling system and inspecting it's condition. The radiator looks clean inside, so a good flush should be all it needs.
Once that was removed I got a better view of the front of the motor. The alternator is fresh, so it's going to stay. The a/c compressor is an AC Delco and is dry at the seals so it's staying too. The power steering pump has been growling due to low fluid. Everything is wet so I will check the lines and pump to determine what's the source of the leak. Everything is bagged and tagged waiting for the clean up process.
12-29-2016, 12:36 PM | #578 |
What a beautiful truck! You do amazing work sir!
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original. View Project Pops HERE Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig View Project Cletus HERE - SOLD DD--2008 Duramax CCSB |
12-30-2016, 08:09 AM | #579 |
Happy to be here
Thanks for the kind words
12-30-2016, 08:11 AM | #580 |
Happy to be here
Countdown to Throwdown! When your bent over the core support stripping parts off the front of the block and you can't stop looking at the carburetor. How many things do you see that are wrong. Ignore the a/c compressor.
12-30-2016, 08:27 AM | #581 |
Happy to be here
Continuing on with stripping the front of the motor. I removed the rest of the a/c bracket and found some unique components to fit around the headers, and a few loose bolts. I pulled the alternator and related brackets, and discovered a patch of bare wires. From there I worked my way down to the water pump. Once again, some of the bolts were loose.
Whoever replaced the water pump must have thought snug was close enough. That will change as we clean, painted, and reassemble everything properly.
12-31-2016, 02:02 AM | #582 | |
I've heard that before......
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
12-31-2016, 09:14 AM | #583 | |
Happy to be here
At this point I'm always encouragedown to pull the clip, it's only 8 more bolts. Then it's like "The clip is off, may as well pull the motor" followed by " why don't you do an LSX swap " Trust me it's all I can do to restrain myself from all of the above. Then reality takes hold and I know that time and budget constraints won't permit any of that.
12-31-2016, 09:31 AM | #584 |
Happy to be here
Friday night is usually date night and with the holidays my wife and I haven't had any quality I me. She was kind enough to allow me to mock one side of the new carpeted panels I got in to replace the originals.
The previous owner told me the carpet kit came from LMC so I ordered the panels from them to ensure they would match. I later discovered LMC uses ACC brand carpet. Had I known that I would have bought through my buddy Chris Lucas at www.73-87chevytrucks.come I prefer to buy from Chris when possible because he only sells product that he would actually use himself. He's not always the cheapest, but he is very competitive and you know your getting enthusiast approved products. I made the mistake of using the old panels as a template to mark the new panels for holes. What I didn't realize was the original panels weren't on straight. I installed the new panels in the original holes on the door and they were way off. Unfortunately I was forced to drill some new holes in the doors to make it right. I wasn't happy with the method required but the end result is a kick panel that's straight. I plan to dye the air vents to match, so I will paint and seal the old holes later. I finished one side and called it done for the night. Momma had popcorn and a movie waiting.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-02-2017 at 10:38 AM. |
12-31-2016, 10:40 AM | #585 |
That interior looks great! Been steadily watching your extensive refresh of this truck and it's quite amazing. Nice wheel choice as well.
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
12-31-2016, 12:30 PM | #586 | |
01-01-2017, 09:56 AM | #587 | |
Happy to be here
01-01-2017, 10:05 AM | #588 |
Happy to be here
Sometimes you have to do shop improvements so you can be more productive on your truck project. Today we installed a new Harbor Freight vacuum system to my blasting cabinet. I had originally used a 5hp shop vac and it worked well till it burnt up. It was extremely loud and got louder before it gave up so I don't miss it.
Be forewarned this unit is very heavy even before it gets filled with media. We mounted it to a piece of plywood so we could be sure to hit a stud with our anchors. It's not going anywhere. I also took the opportunity to upgrad to black diamond media. Turns out the medium grit is too course for my system to flow well so I'm changing to fine. Hopefully hat will improve the flow.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-02-2017 at 10:40 AM. |
01-01-2017, 10:14 AM | #589 |
Happy to be here
After we finished the blasting cabinet update we got the drivers side kick panel installed. Having an extra set of eyes and hands really helped. Chris adjusted the rear of window track and it works correctly again. Thanks to Chris Lucas at @7387chevytrucks for the advice.
Unfortunately I managed to scratch my freshly installed window tint. I'm going to dread calling my buddy Nelson to come fix it.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-02-2017 at 10:41 AM. |
01-01-2017, 11:10 PM | #590 |
Happy to be here
Yesterday we started on a neat addition to the build. The guys at @wamrods have designed a cool kit for 81-91 Squarebody trucks. In my quest to clean up under the hood Chris and I installed one of their kits.
The kit comes with everything needed to replace the stock hinges with gas struts, and very detailed directions. The install is very straightforward as long as you follow the instructions. For more information contact Justin Wallace @wamrods
01-01-2017, 11:23 PM | #591 | |
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
01-01-2017, 11:49 PM | #592 |
67-72 parts collector,…
Ken is the Wamrod strut kit required with your new wheel tubs?
Or is it just to change things up a little?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-02-2017 at 11:14 AM. |
01-02-2017, 01:05 AM | #593 |
Slick addition, but I'd miss the characteristic spring scrunching noise on the later square bodies :-)
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
01-02-2017, 10:47 AM | #594 |
I'm just glad to be here!
Changes are looking good on Scarlet. I started my own LST challenge over the holidays too. Hope to see you at LST with my project...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-02-2017, 11:47 AM | #595 | |||
Happy to be here
01-02-2017, 11:56 AM | #596 |
Happy to be here
Sunday Chris and I finished up small details on the WAM rod install then removed the hood. With it safely stored, it was time to get serious. We pulled the remaining fender liner and masked off the fenders to protect the paint.
I started stripping the top of the motor while Chris focused on wiring and vacuum lines. We took tons of pics, and bagged and tagged bolts and small parts. We tagged lines and hoses too. Its easy to remember where things go when they look the same as when you took them off. Once they are cleaned and painted not so much. I worked my way down to the intake, sealing holes as I went. Chris got the firewall stripped fairly clean so we called it a day.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-02-2017 at 12:02 PM. |
01-02-2017, 12:14 PM | #597 |
So you're in on the design with Mike? When will they be released? I've been holding out on ordering the slosh tubz until I see the mild tubz.
01-02-2017, 02:14 PM | #598 | |
Happy to be here
Eric Miller and I had a lengthy conversation last year at LST and both agreed that the squarebody trend was growing strongly towards static dropped trucks on 22s or 22/24s. I sent Mike lots of pics and measurements from my 77 and my 85, and Eric shared his experience and knowledge gained while building Casper. Together we were able to convince Mike to take the leap of faith, and here we are. Lets hope he sells enough to justify his expense. The plan is to have a set in time for me to debut them at LST on Scarlett along with his fender and core support filler panels. Once he gets them ready for production, he will start taking pre-sale orders. If you order now, and your going to LST he might be able to deliver them at the show.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-02-2017 at 02:31 PM. |
01-02-2017, 04:13 PM | #599 | |
01-02-2017, 07:34 PM | #600 |
wow is all I can say, attention to detail at its finest. I went cheap with my blast cabinet dust collection, I installed a pc fan on the back after opening up the hole. I tapped the switch for power. I then made a blocking shield similar to whats on the back for over the 2" port & installed a vacuum cleaner bag there. I just got it done yesterday & ran it briefly seems to work well.
