#601 | |
Re: 1958 Apache 38 Dually Dump Project
![]() Thanks for the props! ![]() Cool, glad ya like...thanks Kim! Not much more to add, but finished the lower pivot mounts. There will be 3/8" rubber strips between the frame and bed feet, hence the gap between feet and frame/gusset...hope to quiet some of the rattling.
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
#602 |
6>8 Plugless........
![]() Join Date: Sep 2007
Great work guys! That should be able to lift more than you can haul!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#603 | |
My Build: 57 Chevy Pro-Street |
#604 | ||
![]() Quote:
We finished up the lift mounts today (upper pivots)...boxed the front two feet of the bed frame and welded in sleeves. The pins slid right in and the scissor part of the lift is done!
#605 |
As always very nice clean work.
Kim |
#606 |
Nice thanks for the info.... just may do that with mine so I can run electric cut-outs too. For track days I want to just run straight "FIRE" out the sides behind the front tires like a zoomie !!!!!
#607 | |
Appreciate that Kim.
![]() ![]() We added a bit more tonight, welding in a support bar for the back of the lift which is also the upper rear shock mount...then had to fit the sway bar in before figuring out where the shocks would lay, but we like how it all fell into place.
#608 |
![]() Join Date: Jul 2012
Nice, heavy duty, useful and cool looking all at the same time!
#609 |
Very nice! Those shocks are sweet!
#610 | |
#611 |
Working out sway bar details...apparently a 1 9/16" bar is unheard of, couldn't find replacement bushings anywhere. We ended up ordering some 1 1/2" bushings...should be fine.
Made the sway bar links/tabs tonight...baby steps. ![]()
#612 |
That sure looks nice.
Kim |
#613 |
Thanks Kim.
Fab work on the bed is done. We pulled it off for deburring and final smoothing, hope to get it into the sand blasters this next week. Now, we'll jump back into the cab again.
#614 |
It,s going to have a great stance.
Kim |
#615 |
Chassis work is incredible guys!.... very nice job! ]
Ive got a friend that is doing a bunch of fab-work for CDF right now. I know our firefighters would love to have a fleet of trucks looking like this!!! ![]()
#616 | |
We hope so Kim. Kinda tall in the last pic, it sits a fair amount higher with the bed off the chassis...we're making bets over here on how much this is going to end up weighing.
![]() Quote:
![]() While welding/smoothing some seams on the front of the bed, we had to torch just a few more holes. ![]()
#617 |
Got the bed and scissors cleaned up...knocking off dingleberries, and a bit of smoothing.
We hauled those to the sand blasters today for both cleaning and painting...blast to white metal, primer, and heavy gloss black paint (industrial level, these guys do alot of oil field stuff). We decided to go ahead and prep and paint the rear of the frame next (more de-dingleberrying and smoothing right now), in preparation for the finished bed coming back...maybe within this next week.
#618 |
Good progress! Is that your yard? Nice...great tow Burb too.
#619 |
Real nice.
Kim |
#620 | |
![]() Trying to get there...thanks!
#621 |
Checked in on progress with the bed today...parts are blasted, should be painted within a day or two.
#622 |
Nice and clean.
Kim |
#623 |
Yea, the blasters did a great job.
While we're waiting on the bed to be painted (should pick it up Sat.), my son smoothed some glaze into the low spots and laid the first coat of black onto the rear frame rails...
#624 |
Picked up the bed and scissors today, very happy with the work done.
Primer coat+couple coats of black+clear coat= ![]() ![]() We'll let it sit for a couple days to fully cure before fooling with it too much.
#625 |
Looks great.
Kim |
