Old 12-22-2012, 06:22 PM   #601
cubber
Re: Project 78 High Sierra
Lazy or not, they look good!
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 12-23-2012, 12:57 PM   #602
JRANGER
JRANGER's Avatar
Fashioned together a wiring harness for my tach this morning
JRANGER is offline   Reply With Quote
Old 12-23-2012, 01:52 PM   #603
JRANGER
JRANGER's Avatar
Well Tested out an the power and ground to the tach...Just need to go get the Distributor Wiring from the store and then it shall work!!
Looks good though
Old 12-23-2012, 04:36 PM   #604
cubber
That looks like it fit PERFECTLY!
=MATTHEW
Old 12-23-2012, 06:13 PM   #605
JRANGER
JRANGER's Avatar
Well got the tach all hooked up.....She fires up at 1600RPM when cold....Once she calms down idles about 1050RPPM...Is that high for my engine? Turned the idle screw a bit but it wouldnt go lower
Also the Radiator hose wasnt extremely tight on the block so it squirted out a bit on the block and valve covers...BOOO! Lol
Old 12-23-2012, 06:53 PM   #606
cubber
Seems a bit high, but not too bad. Does it sound like its idling high? It also might idle slightly higher till it warms up, then will drop to like 8-900. I don't know though. The rest of your guages look like everything's good. I think idle is a little bit a matter of opinion, as far as how low to go.
=MATTHEW
Old 12-23-2012, 06:57 PM   #607
JRANGER
JRANGER's Avatar
I heard its suppose idle around 700 but i dont know for sure on an 82 305....It was warm when idling warm....It idles much higher when cold almost 2000RPM
Old 12-23-2012, 06:58 PM   #608
JRANGER
JRANGER's Avatar
New CD Player means more adjusting....Had to trim the bezel some more and then trim the CD player ring to get it to fit better with out trimming the red border on the bezel
Old 12-23-2012, 07:00 PM   #609
cubber
Hmmm. I remember it was idling high when we were up there, but then after your test drive it sounded pretty good. Does it sound high now? I've always adjusted idle by hearing, so Idk much about the range. You might just need to drive it awhile and see if it settles down.
=MATTHEW
Old 12-23-2012, 07:04 PM   #610
JRANGER
JRANGER's Avatar
Yeah it sounds fine to me except when cold...Then it sounds high and i have to let it warm up and rev it a few times to get it to idle down.....Im clueless haha
Old 12-23-2012, 07:29 PM   #611
cubber
They are supposed to idle high for a few mins. Idk about 2000, though.
=MATTHEW
Old 12-23-2012, 07:31 PM   #612
JRANGER
JRANGER's Avatar
LOL im wondering if my choke needs to be turned back a little gotta look at it...Rus was talking about checking something but i forgot what he said...lol
Old 12-23-2012, 07:37 PM   #613
Rusbuilt
Rusbuilt's Avatar
Haha you're too young to be having memory problems, you better be using head gear practicing for your fight! lol
I'll help you with it when I get back. I think your idle is normal, it could be a fuzz high.
Rusbuilt is offline   Reply With Quote
Old 12-23-2012, 08:02 PM   #614
JRANGER
JRANGER's Avatar
Ok im thinking it has something to do with a fast idle screw that i cant find to save my life...So basically its something to do with the choke
Old 12-23-2012, 08:03 PM   #615
JRANGER
JRANGER's Avatar
I think i have it starting better be turn back the choke thing a bit...Will have to try again in the morning to know for sure....lol
Just cant find "Said" screw you mentioned
Yes I wear head gear...But its my sparring partner that need to make sure they wear head gear baha
Old 12-23-2012, 08:19 PM   #616
Rusbuilt
Rusbuilt's Avatar
haha yeah! Yours may not have the screw I was referring to.
Old 12-23-2012, 10:07 PM   #617
JRANGER
JRANGER's Avatar
OK finally i found the fast idle screw...I have the fast idle down to 1750 or so...And ive gotten the idle down to high 800s....May need a better spring as it was 900 and i pulled the throttle back so not sure it will last with my spring in place
Old 12-24-2012, 12:10 AM   #618
JRANGER
JRANGER's Avatar
Ordered dual throttle return springs from Advanced for store pickup tomorrow...Gotta love 20% discount lol
Old 12-24-2012, 12:35 AM   #619
JRANGER
JRANGER's Avatar
yeah one on each side but that doesnt really change my idle at all
Just curb idle and fast idle screws
Old 12-24-2012, 01:35 AM   #620
cubber
I bet if you keep foolin with it you'll figure it out.
=MATTHEW
Old 12-24-2012, 01:36 AM   #621
cubber
Thats what she said.
=MATTHEW
Old 12-24-2012, 01:36 AM   #622
JRANGER
JRANGER's Avatar
Eventually.....Im starting to catch on a bit
Old 12-27-2012, 03:17 AM   #623
chevybuilder18
chevybuilder18's Avatar
looking good jeff. i like your panel idea. will you update the rest of the dash also? i was also curious. what the heck you skipped out on the bumper? lol
Her name is Quicksilver
1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER
gotta pay $$ if you wanna play
chevybuilder18 is offline   Reply With Quote
Old 12-27-2012, 10:00 AM   #624
JRANGER
JRANGER's Avatar
Yeah, Ive been thinking up a fiberglass design for the dash actually...I have most of the stuff ready but the cold weather wont work until i get my workshop done...
The bumper....yeah ill be getting a new one of those lol
Old 12-27-2012, 07:37 PM   #625
chevybuilder18
why change it? white and orange rust design looks sick jeff
