Old 03-05-2015, 08:19 PM   #601
RRR18
RRR18's Avatar
Re: 1970 SWB : Porterbuilt to the Extreme "Double E"
Oooooo!
Gotta get me one too.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 03-07-2015, 03:43 PM   #602
mikeleeshields
mikeleeshields's Avatar
Got my new radiator and fan shroud assembly from Travis at azproperformance
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme
Mike
mikeleeshields is offline   Reply With Quote
Old 03-07-2015, 04:02 PM   #603
lolife99
67-72 parts collector,…
lolife99's Avatar
what brand radiator and fans are you using?
Keith
Convert to disc brakes.
Old 03-07-2015, 04:04 PM   #604
mikeleeshields
They are both Champion. They are from China so they are cheap but I've heard they are pretty reliable. It looks pretty well built.
Mike
Old 04-05-2015, 12:03 AM   #605
mikeleeshields
I have quite a few updates. I have not been on here much as I have been updating on facebook and instagram.
- I've been roughing in the rear tubs and the trying to get the bed floor designed.
- Mocked up my air box and wood floor.
- I have pulled the bed off to start work
- I have started cutting up my new bedsides to start the install of the rear tubs.
Mike
Old 04-05-2015, 12:07 AM   #606
mikeleeshields
I don't know how to rotate those pictures after they've been added, I hate that.
I got some new parts today.
New Hood, New fenders, New Bumper, and new mounting hardware.
Mike
Old 04-05-2015, 12:15 AM   #607
mikeleeshields
I also started cutting up my perfectly good bed to install tubs this weekend.
I have added 1X1 tubular bracing for the tub structure in the bed side. I am also working on getting my rear tub-bedside filler ready to weld in also.
Mike
Old 04-07-2015, 12:56 PM   #608
cooperhw
cooperhw's Avatar
Sweet build. I am subscribing so I can find my way back like leaving bread crumbs.
I am building a 68 dually now (not going in this direction) but have a 63 GMC short fleet that this is "exactly the direction" I want to go with. Love it.
Oh yeah, you guys are praying and wanting warm weather whereas here in Phoenix AZ we had 90* last weekend and we are dreading the heat that's coming.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 04-08-2015, 09:57 AM   #609
bbcmudtruck
Just spent the last two days reading through your build and all I can say is AWESOME! Thanks for taking the time to document your success as well as failures along the way. That saves guys like me frustration and heart ache. Very nice build and cant wait to see it done!
bbcmudtruck is offline   Reply With Quote
Old 04-08-2015, 10:24 AM   #610
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress Mike! Keep up the good work, you'll be cruising in no time.
mcbassin is offline   Reply With Quote
Old 04-12-2015, 11:59 PM   #611
mikeleeshields
A little update. Spent the day getting the inner rear tub skin installed and one of the rear tubs. Hope to get the other one in this week. It will be rough with two kids in baseball right now.
Mike
Old 04-13-2015, 12:06 AM   #612
mikeleeshields
I built a 1x1 inner skin support. I cut the wall on three sides and bent it to the contour of my tub cutout. I then made a cardboard template of my inner skin and cut it out with my primitive tools aka the sawsall and cutoff wheel. I welded the tube in place. The placed the inner filler inside and clamped to the tube structure. I welded it on the inside and out. I left the top open because the tub will fill in that space. The tub was installed and welded in.
Mike
Old 04-13-2015, 08:10 AM   #613
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress on the bed Mike.
Old 04-13-2015, 12:16 PM   #614
mikeleeshields
Mike
Old 04-13-2015, 11:28 PM   #615
tommys72
tommys72's Avatar
Awesome build, just read the whole thing
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 04-14-2015, 07:04 AM   #616
mikeleeshields
Thanks Tommy.
Mike
Old 04-15-2015, 01:42 PM   #617
Blown06
Blown06's Avatar
The truck has come a long way, hopping onboard to see the finished product.
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 04-16-2015, 10:07 PM   #618
mikeleeshields
Got the inner skin welded in tonight. Hope to grind it down and get the tub in by this weekend. Then I can start to square up the bed. I've also started to break out my niece new pretty sheetmetal so I can just turn around and cut them up to install my slosh tubz by Mike Losh
Mike
Old 04-27-2015, 01:09 PM   #619
mikeleeshields
I have quite a few updates to put on here. This falls behind because it is much easier to post stuff on Facebook and Instagram.
Got the inner fender welded in and the other tubbed tacked and fully welded in. Had a little helper also. My daughter wanted to watch me weld.
Mike
Old 04-27-2015, 01:10 PM   #620
mikeleeshields
Started working on some rust repair for the tailgate. I think I am actually going to fix this thing rather than buy a new one, haha.
Mike
Old 04-27-2015, 02:01 PM   #621
mikeleeshields
I made some tub extensions and got them in place also. This should help prevent and road grime from getting anywhere is shouldn't.
I also capped off my front bed support. I am actually mounting it upside down because it works better. I just didn't like the open c-channel it posed.
Mike
Old 04-27-2015, 02:04 PM   #622
mikeleeshields
Two final shots for the day.
The tubs and welded and ground down finally. I hate grinding by the way. Im prepping them to be sprayed with a coat of epoxy prior to filler.
The last shot is just one I took before leaving the garage for the night.
Mike
Old 04-27-2015, 02:47 PM   #623
jlsanborn
jlsanborn's Avatar
Nice work!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 04-27-2015, 05:47 PM   #624
mikeleeshields
Originally Posted by jlsanborn View Post
Nice work!
Thanks buddy
Mike
Old 04-27-2015, 11:53 PM   #625
1stchevy
1stchevy's Avatar
Looking good man, stay with it and you'll be done before you know it!
1stchevy is offline   Reply With Quote
