#626 |
![]() Join Date: Jul 2012
Re: My 52 GMC Build
Lower that was a nice mod. What wiper motor is that?
#627 | |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: My 52 GMC Build
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#628 |
Re: My 52 GMC Build
making it look easy
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#629 | |
Re: My 52 GMC Build
Thanks It's the rear wiper from a '97 s-10 blazer
You know it's not ![]()
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#630 |
Re: My 52 GMC Build
As of this morning I have working wipers, tail lights and brake lights. For the wiper motor arm I used 1/2"X1"X5" but 1/2"X3/4"X3" would work. The center hole is 8mm with a 10mm step 3/4 of the way through. That is the profile of the wiper motor shaft. The pivot holes are 5/16" and I used a 5/16"X 1.5" bolt so the arm will pivot on the shoulder, then double nut. 2 vids of wipers.
http://vid51.photobucket.com/albums/...psc2f1reak.mp4 http://vid51.photobucket.com/albums/...pso8qptf7g.mp4 This is my first drawing not what I ended up with exactly. It's close.
#631 |
![]() Join Date: Aug 2012
Re: My 52 GMC Build
That's slick
#632 |
Simple? What's simple?
![]() Join Date: Apr 2007
Re: My 52 GMC Build
This is great info! Is that center hole tight enough to interfere with the splines on the motor shaft, or are you just relying on the end nut to keep it tight enough?
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
#633 |
Re: My 52 GMC Build
I need to copy that instead of buying the 150 buck replacement.....hmmm, nice work amigo!
SHAKE N BAKE BABY, SHAKE N BAKE.... http://67-72chevytrucks.com/vboard/s...d.php?t=686729 |
#634 |
Re: My 52 GMC Build
That's slick! That's will help out a lot of us!
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
#635 | |
Re: My 52 GMC Build
JJorgensen52 Bit of both the 10mm hole is drilled as a pilot for the arm and the angle down to the 8mm will grip on the splines. Then the nut will hold it as well. I ground a 10mm drill so it had a bigger angle on the tip.
#636 |
![]() Join Date: May 2007
Re: My 52 GMC Build
super dope! what a great mod. I hate to admit I threw away a blazer rear gate before pulling the motor.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#637 |
Re: My 52 GMC Build
As of now I have gauges that as I can tell work and all my LED dash lights work.
I'm going to plug the block heater in tomorrow morning and fire the truck up. The only gauge that is not hooked up yet is boost.
#638 |
Re: My 52 GMC Build
Looks great man!
#639 | |
Re: My 52 GMC Build
![]() Lowers, the truck is looking great! How soon will you be rolling?
#640 |
Re: My 52 GMC Build
Thanks 4DSEVEN
[QUOTE=JJorgensen52; Lowers, the truck is looking great! How soon will you be rolling?[/QUOTE] Thanks. I think first test drive will be middle of April weather permitting. I have a 2 week holiday trip coming up in 2 weeks, so after that I should be able to pull it out of garage to the driveway for some testing.
#641 |
Re: My 52 GMC Build
On Saturday my boys came out to the garage with me and they started the truck after a coin flip. I'm happy to say all the gauges work.
![]() Here is a vid http://vid51.photobucket.com/albums/...psqaksapv7.mp4
#642 |
Re: My 52 GMC Build
congrats
#643 |
Re: My 52 GMC Build
Looking good that dash..
Nice work on the wipers
My chevy 51...... http://67-72chevytrucks.com/vboard/s...d.php?t=541148 www.knutselracing.nl |
#644 |
Re: My 52 GMC Build
Ill be looking for one of the motors. Seems like an easy way to do it.
#645 |
Re: My 52 GMC Build
Truck sounds real good.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
#646 | |
Re: My 52 GMC Build
Thanks 99
Thanks R1 I'm happy with how it turned out Quote:
Thanks I know I cant wait. I'm really hoping for an early spring.
#647 |
Re: My 52 GMC Build
I love the sound of them old 7.3's. Can't wait to hear it run by on the road.
#648 | |
Re: My 52 GMC Build
#649 |
Re: My 52 GMC Build
Great work! Is that your radio below the dash with the pic of the GMC? Also, is the pyro/boost gauge a glow shift? I've considered getting one of their fuel pressure gauges but I know they have had big issues in the past with being bad.
#650 |
Re: My 52 GMC Build
Just caught the video. Great sound and a ton of cool features in your truck!
Tags |
bagged, build, diesel, gmc, hot rod |
