Old 10-24-2013, 02:18 PM   #676
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 72 Cheyenne Super Plain Jane
Originally Posted by Graham57a View Post
I'll probably do lower trim to start and if it works I'll leave it at that. Its probably the hardest decision I've had to make on the entire truck haha. That one chrome strip can completely change the attitude of the truck !
if you were going to 2 tone it the upper trim is mandatory. Since its a solid color lower trim is just right.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-24-2013, 08:52 PM   #677
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I agree with Keith and ken. Lower wood grain trim would be awesome.
3m adhesive tape... I'm jut sayin.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-25-2013, 01:00 PM   #678
Graham57a
Graham57a's Avatar
Originally Posted by knomadd View Post
Are they ever really "finished"? Mine aren't, I know that. Most people think my GTO is done, but I've been working on it while I drive it ever since I bought it. I will be doing the same thing with my 71. I've got grand plans for both and not enough money or skill for either.
Sounds like you need a second project truck. Leave this one and do your phase 2 on a second truck... We're all addicted to building killer rides, or we wouldn't be on here all the time.
Yea what I'll probably do is take the frame from this truck and put a patina body on it and make it a daily driver and then use the body from Jane and put it on a new frame. That way I'll have a solid 5/7 drop daily driver on a powdercoated frame and a frame laying show truck with my Intros and all the fancy stuff. Who knows tho, that's probably ten or so years down the road. Right now I have this thing to finish and enjoy
Originally Posted by 67ChevNut View Post
How did you make the rear wheels fit inside the bed? Do you have a shorter rearend, or what is the offset of those wheels? Love the truck, looks awesome.
Thanks man. The wheels just cleared the inside of the bed on accident. I'm gonna put 1" wheel spacers on both sides to bring the wheels out a little more. The rear is a f*rd 9" built to width, 59" face to face. And I'm pretty sure the back wheels have 4" of BS. I didn't go the conventional route on the rearend, wanted to do something a little different.
If it was two tone I would definitely have upper trim but there's a soft spot in my heart for solid color cheyennes with full trim. And it's not something you see every day like the hugger orange and white two tone
We'll see how the trim goes, I have a pretty long list of to dos before I am gonna worry about it. I want it to be driving and dialed mechanically before I drop 500-1000 on side trim. I am definitely using adhesive tape when I do, it seems a million times easier and holds just as well. Is there any specific 3M tape I should look for?
ANDREW
1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072
1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827
1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315
1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788
1972 Chevy SWB Highlander OLIVE Build thread coming
Graham57a is offline   Reply With Quote
Old 10-25-2013, 07:37 PM   #679
jeffg1010
jeffg1010's Avatar
I say give it a shot on upper and lower trim. Mock it up and if it works, run with it! Best thing about these trucks is they all don't have to look alike to be awesome.
Jeff
1972 Blazer CST 2wd- My son Sam's Project "S" Project "S"
1970 Suburban - SOLD "One Bad Burb" Photobucket Album
1986 C30 Crewcab - 63K original miles, original paint
Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP...
jeffg1010 is offline   Reply With Quote
Old 10-31-2013, 06:28 PM   #680
Graham57a
Graham57a's Avatar
Alright guys I need some help. I've been chasing a wiring issue on the truck for a while now and I think I found the issue but I don't know how to fix it. The problem was the battery kept draining over and over and I couldn't find the source for the life of me. I unplugged the tach power from the fuse box and the battery has kept enough charge to crank after sitting for 3 days so I'm pretty sure that was the issue. Now the confusing part, I used a test light on my fuse box to try and find an open fuse that got power when I turn the key but is dead when the key is off. All my open fuses are either hot all the time or don't come on at all. Is my fuse box bad?
Also ran a test light on the back of my ignition switch where I tapped in the power for the hei and it's hot when I turn the key halfway but it looses power when I turn the key in crank mode. It did this before and I was able to start it but it only tried to start when I was backing off the key. I tested the wire before I tapped into it and it was hot in crank so I'm not sure what happened. The ignition switch is new but maybe I got a bad one. Any input would be greatly appreciated, I really wanna settle this wiring issue while I'm waiting to rebuild my savings account
ANDREW
Old 11-01-2013, 01:52 AM   #681
sublime1996525
Amazing looking truck man!
sublime1996525 is offline   Reply With Quote
Old 11-01-2013, 06:33 AM   #682
Rusbuilt
Rusbuilt's Avatar
I would try the new ignition switch first.
Rusbuilt is offline   Reply With Quote
Old 11-01-2013, 10:20 AM   #683
knomadd
knomadd's Avatar
I agree with Rus. If you've got an old one still, try to swap it. I've got a new one from my American Auto Wire harness kit if you need one. I kept my original in it.
What kind of wire harness do you have, stock, stock style replacement, painless, AAW, etc? I'm more curious about the fuse block than the actual wires.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 11-01-2013, 11:15 AM   #684
Graham57a
Graham57a's Avatar
Thanks man!!
I'll try getting a new switch and see if that helps. I'm pretty sure I still have my receipt from orielly so I'll see if I can exchange this one for another.
It has a new ignition switch in it, not sure what brand just whatever the parts house sells. The harness is all original, just cleaned it up and rewrapped it. The harness was in decent shape when I took it out, still had the original tape on it. The annoying part is the hei was hooked up and worked before I tore the truck apart but that was 4 years ago and I don't remember how it was done
ANDREW
Old 11-01-2013, 02:00 PM   #685
RCbowtie69
RCbowtie69's Avatar
Just got back on my computer.It's raining today & checking up on your build.The paint looks SWEET!!!!!! Keep on Truckin''.
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 11-01-2013, 09:32 PM   #686
Grip
Grip's Avatar
Hey Andrew. Lookin good! You should wire in a relay to power your HEI. That way you can get some of the load off of the old school ignition switch and still get a full 12V+ to the distributor.
Grip is offline   Reply With Quote
Old 11-01-2013, 09:37 PM   #687
Grip
Grip's Avatar
http://i1147.photobucket.com/albums/...o_mfg_info.gif
Old 11-01-2013, 09:42 PM   #688
Grip
Grip's Avatar
http://www.lxforums.com/board/f70/ho...h-relay-98071/
This should help your ign switch last longer and get you 12V power to your HEI.
Old 11-02-2013, 11:24 PM   #689
jlaird
jlaird's Avatar
Another vote for lower trim only...and those wheels are KILLER!
jlaird is offline   Reply With Quote
Old 12-04-2013, 08:52 PM   #690
Graham57a
Graham57a's Avatar
Alright guys, haven't been doin too much to the truck lately. Between the semester ending up at school and the freezing cold weather it's been hard finding time to spend in the garage. The top of my list is sealing the cab up. I ordered some new windshield trim on Monday so once that gets here I can put the windshield in. When I was in mooresville over thanksgiving I picked up my side glass but I need to take the channels off the glass, sand and paint them, and then put them back on. Once that's done the cab will be sealed up and ready to go. I have a couple pictures of my tailgate and wheel tubs from the painter, everything turned out really sweet!!
ANDREW
Old 12-04-2013, 08:53 PM   #691
Graham57a
Graham57a's Avatar
ANDREW
Old 12-04-2013, 08:54 PM   #692
Graham57a
Graham57a's Avatar
Just need to get some stainless hardware and I can put the tailgate on
ANDREW
Old 12-04-2013, 08:56 PM   #693
Graham57a
Graham57a's Avatar
Also had a little free time in the construction lab after class today so I built a set of poor mans elephant stands so I can actually fit underneath this thing
ANDREW
Old 12-04-2013, 09:01 PM   #694
Graham57a
Graham57a's Avatar
Last one. Realized I never posted a pic of the front hub/brake combo so here it is.
ANDREW
Old 12-05-2013, 12:36 AM   #695
Grip
Grip's Avatar
Looking good Andrew! Windows, exhaust, bed liner, and ???
Old 12-05-2013, 01:07 AM   #696
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Andrew you have done a tremondous job on your build and that is one beautiful truck.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 12-05-2013, 10:08 AM   #697
knomadd
knomadd's Avatar
Moving right along. Looking better and better. I'll be needing to make those stands myself when it comes time to do a transmission swap. Not sure which car I'll do first, but I won't be able to get to the GTO without some of those.
I really like your truck. everything looks good. Keep it up!
-Duane
Old 12-05-2013, 12:25 PM   #698
CC69Rat
CC69Rat's Avatar
Your truck is awesome buddy, keep at it !
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-05-2013, 12:35 PM   #699
Bhelton
Bhelton's Avatar
looking good!!!!
Bhelton is offline   Reply With Quote
Old 12-05-2013, 01:00 PM   #700
Graham57a
Graham57a's Avatar
Thanks!!! The list is windows, new bags for the rear, new front springs, shorten and tap the tie rods, wheel spacer for the rear, get anodized plugs for the rearend and fill it with oil, driveshaft, get a new willwood master cylinder and plumb the rest of the stainless lines, bed liner, bumpers, exhaust, and new ignition switch.
Thank you sir, I have learned a lot building this thing. It's been an extremely rewarding process
Thanks Knomadd, the stands were really easy to make and very sturdy. Definitely worth the time!!
Thanks Chad, can't wait to see your big block truck come together!!!
Originally Posted by Bhelton View Post
looking good!!!!
Thanks Bhelton, I'm finishing up my last couple days of class and then I have two exams next week and then I'll be free for a month to work full time and earn some money to get this thing moving!!!
ANDREW
