07-18-2017, 06:21 PM | #676 |
Re: 1956 Chevy Pro-Street Build
Looking good.
Kim |
07-20-2017, 01:38 PM | #677 |
I just have to say that God blesses us all with people in our travels and lives that come along and just do good things... it's amazing and very humbling at the same time when the good nature of people comes out towards others - perfect strangers, yet somehow God let our paths cross for some reason only he knows.
Many of the people on this board are just that... people that I have now crossed paths with for no other reason than Gods good will. A huge THANK YOU to those that have helped me with this project of mine (you know who you are are) and thanks doesnt go far enough..... Hope we all meet up face to face someday soon.
My Build: 57 Chevy Pro-Street |
07-20-2017, 07:37 PM | #678 |
^^^ I consider a lot of guys here, "Friends I haven't met yet"^^^
We all have out separate political beliefs, economic ability whether hig or low to finance our projects and no one is ever judgemental, unkind or unhelpful. This is miraculous all by itself.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
07-20-2017, 09:47 PM | #679 |
Truck is really coming together, would have thought like you that the SB springs would do it, good thing you know ahead of time, sure love the stance and the tire wheel combo, classy by mean looking at the same time.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
07-23-2017, 01:03 AM | #680 | |
07-23-2017, 01:32 AM | #681 | |
I did get mine changed out today and they sit perfect now, I have the coil-over set at about 2" off the bottom of the shock to start with. I have a brand new set of SBC springs for sale for a GEN1/GEN2 Camaro front end. Summit wont take them back now that it has been 2 years. Door panels are done - came out decent, they will have power window boxes over the front circle and the second circle has a plug welded into it to make it flush and will have a 19mm pushbutton for the door popper. Thinking of putting a black arm rest/grab handle on them too ??? what do you guys think? Kind of plain as is.... Got the dash holes all cut out for gauges, switches, idiot lights, and everything going in it so I can wrap the dash in leather.... next. I also got my driveline all installed... ready to roll! almost....
07-23-2017, 01:34 AM | #682 |
where i come from ---''thats how we rock'' -----''thats how we roll ''
lookin good !!! |
07-23-2017, 01:42 AM | #683 |
Heres a shot of the 350 lb spring setup on the QA-1 coilover shock - this is good for an SBC, or any of the LS motor setups.
07-23-2017, 09:31 AM | #684 |
Truck is looking good. Is it just the picture on the driveline but is the shaft not centered in the loop and rubbing on the right side?
Getting close to driving. Are you going to make the car show in August, I believe, you were wanting to make?
1950 3100 5 window |
07-23-2017, 10:30 AM | #685 | |
Took a pic before we were all done with it, the 4-link was not all connected and I scratched the paint while getting the driveshaft into that stupid hoop!.... Thanks for pointing that out though Mike!
07-23-2017, 11:22 AM | #686 | |
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
07-25-2017, 12:33 AM | #687 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
07-29-2017, 01:22 AM | #688 |
Ok so getting it back together again and again... do I sound tired yet?
and I thought "Final Assembly" MEANT FINAL!!!! --- Truck progress this week; got the electrical pretty much completed with all the relays, CDI ignition and main fuse block. Door panels with PW switches and popper buttons. waiting on arm rests. The rear bed panels are gonna be made out of stainless steel and hopefully be done next week. And the doors ... well they are still being worked on.... ENGINE is ready to RUN! So a few hiccups and landmines for you guys to watch out for here: 1. Relays can be your friend or your enemy depending upon where they are located. 2. Door jamb Wire looms made by Autoloc do not fit very many wires! 3. Will have to re-invent where the PW relays are located or the PW switches which I have already installed int the door panels.... Whoops! 4. Dont cut wires for plugs at the far end of the truck until you have landed the front end of the truck... you'll be doing it again. 5. Dont rely on Summit Racing, Speedway Racing, or any other company that has "racing" in their name for technical support.... 6. Bondo doesnt harden in 110 degree weather..... and needs to be scraped off and done again.... 6. And finally when welding on really hot days above 110 degrees - dont wear flips flops.... wear your boots!!!! ---- Burnt feet hurt! We are almost getting there ..... Note: both the electrical pictures are suppose to be vertical - rotate clockwise.... the relay/terminal strips are in the drivers side kick panel area that has been gutted of all air vents. The CDI/Fuse Panel is up under the dash to the left of the steering wheel.
My Build: 57 Chevy Pro-Street Last edited by ptc; 09-17-2019 at 08:14 AM. |
07-29-2017, 09:14 AM | #689 |
Looking good.
A lot closer than I am to a finished truck. Kim |
07-29-2017, 10:56 AM | #690 |
ptc - Everything is looking great - congrats.
Maybe I missed it and apologies if I did but what's going on with the roof color?
07-29-2017, 01:08 PM | #691 |
Very nice work PTC!
07-30-2017, 12:39 AM | #692 |
Sounds like it's progressing fairly well and your learning a lot even the flip flop part. Sure respect the quality of work done, nice.
Mudman.
07-30-2017, 04:31 PM | #693 |
Thanks so much Dan - Nope didnt miss a thing.... theres a bit of body work to get done on it and the weather has been so ungratefully hot here that the bondo just doesnt like it much. and I hate doing bodywork once - more less twice! ... So Ive just been delaying the inevtiable.... -- But cant find a local guy that wants to do side work for cheap, everybody's busy. My doors need finishing too, then they can be assembled. The top will be white but the inset around the side and back window will be the metallic maroon red of my boat color. With the smoke tinted side and back windows it should look real good.
07-30-2017, 04:32 PM | #694 |
You're doing ALOT more body work than I am.... Im just getting mine on the road!!!! the body will come later... maybe
07-30-2017, 04:43 PM | #695 | |
07-31-2017, 12:19 AM | #696 | |
Thanks so much... its been fun... ????
YEa me too --- like you said "Im jonesing to drive it" !!
07-31-2017, 03:25 AM | #697 |
ptc
Flip flops, welding? Please tell me when "old enough to know better" kicks in? I'm missing the orange frame. Looking great, strong work. I love pushing your leg! Keep on keepin on NC
Been there, wrecked that |
07-31-2017, 06:51 PM | #698 |
Those are some great words to live by. Your wiring job looks amazing, it takes so much thinking to get it neat.
08-04-2017, 02:10 PM | #699 |
Rolled the truck out and got it into the sunlight for the first time in months.
Its got some color now, - the bed is done now, Rhino-lined inside and trim pieces put on, and the tailgate is on too. - waiting for the bed panels being fabricated. The front end parts should be getting done (by me) next week. Suppose to only be in the 90's. The interior is getting a center console with the glove box, cup holders, shifter, and all the GO GO Switches will there instead of in the the dash... and maybe a stereo, AC controls, blah blah blah in the future.
My Build: 57 Chevy Pro-Street Last edited by ptc; 09-17-2019 at 08:24 AM. Reason: photos |
08-04-2017, 05:27 PM | #700 |
Looks really good.
Kim |
