Old 11-11-2016, 10:21 AM   #701
knomadd
knomadd's Avatar
Re: Knomadd '71 SWB C-10
Originally Posted by Advanced Design View Post
Nice work on the firewall and gutter....going to look good when done!
Thanks Doug, I agree.
Originally Posted by Dieselwrencher View Post
Sweet work on the gutter! After I saw a cab done up like that I really wished I would have done mine that way. They look so clean and sleek IMO!
Thanks Ryan! I've seen several done like this and just knew that I had to do it when I got to this point. I think it will be worth the effort.
Originally Posted by MMcMasters View Post
Very nice work on the firewall!
Thanks Mike!
Originally Posted by mcbassin View Post
Nice work on the firewall Duane.
Thanks Mike!
I've got a little more done:
I really need to move that fuel line out of my way. After seeing it in these pictures, I'm a bit surprised I haven't put it back down by the frame rails yet.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 11-11-2016, 11:05 AM   #702
Bennett68C10
Bennett68C10's Avatar
Awesome job on the firewall Duane, I really like the shaved wire gutter!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 11-14-2016, 01:28 PM   #703
Vic1947
Vic1947's Avatar
Nice clean look, Duane. Looks like you've almost got it whipped.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 11-14-2016, 05:33 PM   #704
knomadd
knomadd's Avatar
Thanks Keith!
Thanks Vic! It's taking me longer than I'd like, but it's coming along.
Well, I didn't take final pics of the passenger side, but here is one of the drivers side and another of the passenger side with the A/C fittings mocked up.
I've started sanding down the rest of the firewall and will be filling in some unnecessary extra holes, relocating some others for some wiring to hide a little better, and start body work. Hopefully I'll get it ready for paint around Thanksgiving.
Oh, and my wire harness should be here tomorrow!!!
-Duane
Old 11-15-2016, 04:55 PM   #705
RRR18
RRR18's Avatar
Damn. Good work. Looks great.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 11-16-2016, 09:21 AM   #706
mcbassin
Still Learning
mcbassin's Avatar
Excellent work on the channel Duane!
mcbassin is offline   Reply With Quote
Old 11-16-2016, 10:25 AM   #707
knomadd
knomadd's Avatar
Thanks guys!
I went out to the garage last night to keep plugging holes, got two done, but noticed it was welding really strange. It took me until the 2nd hole was filled to check my gas level... it was empty, again! Now I know I don't weld often, but that tank sure seemed to go empty rather quickly.
So, no more progress with the welds, but I did take a picture of the passenger side finished.
And...
MY HARNESS CAME IN!!!
Now I just need to finish the firewall, get it off to paint and I can start cutting it down and building my own stand alone harness!
-Duane
Old 11-16-2016, 04:13 PM   #708
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by knomadd View Post
Thanks guys!
And...
Sucks when you run out of gas, it always happens to me on the weekend too it seems.....
Nice harness! where'd you end up buying it?
Old 11-16-2016, 04:52 PM   #709
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Your firewall is looking awesome!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-16-2016, 07:08 PM   #710
knomadd
knomadd's Avatar
That happened last time! Luckily, it wasn't the weekend this time, but still when the welding supply place was closed. Got my refill today at lunch though, so welding continues tonight! As for the harness, it's a factory piece. Since mine was damaged in shipping, the seller sourced a brand new one. Apparently, the factory harness that came with my engine wasn't available anymore, so it had to be built. We had to wait for GM to commission this harness for the 2017 vans in order to get one. I'm now at "ground zero" where I should have been when I received my engine back in July.
Thanks Ryan!
-Duane
Old 11-21-2016, 11:32 AM   #711
knomadd
knomadd's Avatar
More progress... the metal work is almost complete!
Started with these holes
made a plug
two holes down, square plug set in place
end result (keeping rear body harness hole since I wired the truck already)
Clutch hole before
and after
started stripping the undercoating/bedliner crap and surface rust that was hiding under it
Final product, with some rust converter on the drivers side. Just to keep it at bay. Once I'm ready to cut out and replace the fuse block butcher job, I'll sand it all off again and start filler work.
-Duane
Old 11-21-2016, 11:43 AM   #712
Mikem_72
Wow that looks really good man. Great job
-Mike
1970 C10 Stepside 350/700r4
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632707
Mikem_72 is offline   Reply With Quote
Old 11-21-2016, 04:24 PM   #713
Dieselwrencher
That looks really nice. Great work!
Ryan
Old 11-21-2016, 07:17 PM   #714
Vic1947
Vic1947's Avatar
Nice work, Duane. I like the a/c line hole layout better than mine which is all inline. The rain gutter turned out slick.
Victor
Old 11-22-2016, 09:54 AM   #715
knomadd
knomadd's Avatar
Thanks guys!
The last piece of the firewall... The butchered fuse block hole... old overlayed onto new.
And the finished product, finally!
Oh, and my e-level reprogrammed and resurfaced accuair parts came in yesterday. These were my old switchspeed parts sent back in to accuair for the upgrade.
-Duane
Old 11-22-2016, 10:43 AM   #716
Advanced Design
Advanced Design's Avatar
Very nice work on the firewall...well done!
Advanced Design is offline   Reply With Quote
Old 11-22-2016, 01:34 PM   #717
GAc10boy
GAc10boy's Avatar
Looks great! Killer progress.
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 11-22-2016, 01:52 PM   #718
boostedc10
boostedc10's Avatar
Nice work Duane. Hope those pinouts help you out on that harness too!
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 12-05-2016, 06:53 PM   #719
knomadd
knomadd's Avatar
Apparently I've forgotten to update this thread for a little while. Time to remedy that...
Metal work finished, rolled it outside to blow it all of and give it a good grease and wax remover clean up.
I then started with some filler...
First coat done and sanded...
After a little more filler, it was time to do a polyester filler (final filler).
I've almost got it finished, but still some sanding and a couple touch up spots to hit again... more pictures later.
-Duane
Old 12-07-2016, 11:11 AM   #720
knomadd
knomadd's Avatar
Got a bit more done last night. Hopefully this is the last time I'm putting on more filler...
-Duane
Old 12-07-2016, 01:45 PM   #721
ChuckLee
awesome work!
what are you using to sand down your firewall?
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579
ChuckLee is offline   Reply With Quote
Old 12-07-2016, 02:34 PM   #722
mcbassin
Still Learning
mcbassin's Avatar
Looks great Duane!
Old 12-07-2016, 02:42 PM   #723
MMcMasters
MMcMasters's Avatar
Keep plugging away, your almost there..it looks great man!
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 12-07-2016, 06:20 PM   #724
gringoloco
A guy with a truck
gringoloco's Avatar
Smooooooth
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-09-2016, 01:03 PM   #725
knomadd
knomadd's Avatar
Originally Posted by ChuckLee View Post
awesome work!
I start with 36 grit, move to 80, then 220. Once I apply the polyester filler I use 220 grit, unless it's too thick then I'll start with 80 to get it close then finish it with 220. I do all of it with hard blocks. I have used an electric orbital to get excess filler knocked down to a manageable shape quickly, but it's pretty risky if you aren't careful with it.
Looks great Duane!
Originally Posted by gringoloco View Post
Smooooooth
Thanks guys! I'm excited to say that I finished the filler work on the firewall. It's going to be delivered to a friends house this evening to have some color put on it. Hopefully I did the work to his satisfaction (not just mine) and he'll get some primer and color on it this weekend.
Here's the final shot before it gets covered up.
-Duane
