Old 09-11-2008, 06:41 PM   #51
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Project Slo-Go 67
Awesome job. Looks like your getting the hang of it.
Alan's Classic is offline   Reply With Quote
Old 09-27-2008, 10:48 PM   #52
my67chevytruck
Under Construction
my67chevytruck's Avatar
Had a pretty productive day. pulled the coresupport, and radiator to get ready for the crossmember swap. Pulled the cab as well, since the PO has the ebrake cables wired to the frame and trans crossmember. I will have to figure out how the ebrake get mounted to the frame properly. Tomorrow i will power wash the frame and engine/trans, hopefully i can get the engine/trans pulled as well.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 09-27-2008, 10:49 PM   #53
my67chevytruck
Under Construction
one more
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 09-29-2008, 08:30 AM   #54
gcburdic
Restoration Virgin!
gcburdic's Avatar
looks good....here's a pic of the ebrake setup that may help you!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 09-29-2008, 11:34 AM   #55
my67chevytruck
Under Construction
Thanks GCBURDIC that graphic will help alot.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 10-06-2008, 10:15 PM   #56
my67chevytruck
Under Construction
we made some progress over the last couple of days. we have the frame stripped down. we have sprayed it with oven cleaner, power washed it, and are in the final process of finishing it up with the wire wheel. The 15 yo is really getting into the teardown and rebuild, so i will try to keep it going at a good pace. My youngest son is also lending a hand.
There is no turning back now!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 10-06-2008, 10:21 PM   #57
my67chevytruck
Under Construction
we are also expecting our 2/4 drop from ECE shortly.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 10-09-2008, 05:17 PM   #58
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
Nice progress... can't wait to see this comming together.
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 10-10-2008, 09:55 AM   #59
my67chevytruck
Under Construction
Appreciate it Don.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 10-15-2008, 08:54 PM   #60
my67chevytruck
Under Construction
I made a little progress. need a couple coats of chassis black now.
I got sidetracked working on my old indian 50cc (MM5A) for my youngest who will turn 2 Friday.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 10-15-2008, 10:13 PM   #61
Richard8971
Love the bike! I think it's great that your sons are helping you. Frame is looking good too! Hopefully as your oldest (I have no idea how many you have...) will want an older truck instead of a newer "dur-dur" Honda when he gets old enough to drive!
Don
Sherlock Holmes
Old 10-29-2008, 06:09 PM   #62
my67chevytruck
Under Construction
well, i made some progress. 3 coats of chasis black on the frame, trailing arms, crossmember, 1 inner fender, and UCA/LCA's
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 11-05-2008, 11:26 AM   #63
my67chevytruck
Under Construction
well, we have the rear suspension in and all bolted up now. I need to run the brake line and make a mount for the brake junction to mount on the rear crossmember. we have the front crossmember mounted as well. We need to clean up the rotors and springs, then paint the rotors, spindles, and springs so we can continue the front install.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 11-17-2008, 01:27 PM   #64
my67chevytruck
Under Construction
We Have a Roller We have installed the ECE 2 1/2 spindles( spring compressor was fun!!), new rotors. installed the brake caliper. the still need to button up the inner/outer tie rods etc. but we are making progress.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 11-17-2008, 01:32 PM   #65
gcburdic
Restoration Virgin!
gcburdic's Avatar
NICE!!!....keep at it man!!!
Geoff with a G
Old 11-24-2008, 10:24 AM   #66
my67chevytruck
Under Construction
we painted the tie rods and the idler arm etc. we should be able to mount later today then the front of the chasis will be buttoned up. then we need to clean and prep the motor for paint and serpentine belt setup.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 11-24-2008, 05:29 PM   #67
kyull67
kyull67's Avatar
Frame looks sweet, keep at it! Also nice job with the Indian!
kyull67 is offline   Reply With Quote
Old 11-24-2008, 05:39 PM   #68
my67chevytruck
Under Construction
Thanks Kyull, it's been fun.we are already thinking about another project when the 67 is done. my wife thinks we are crazy.....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 11-24-2008, 09:59 PM   #69
Alan's Classic
Lookin' awesome!! You are a tad bit futher on your frame than I am. It's alot of fun when you can work on something without getting dirty.. When you get done for the day you can look at it and see that you have got something done. Keep it up.
Old 11-26-2008, 05:18 PM   #70
my67chevytruck
Under Construction
Thanks for the comments guys! Im trying to keep it interested so my 15 yo doesnt get burnt out but he's doing pretty good thus far.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 11-26-2008, 05:33 PM   #71
nuke1
nuke1's Avatar
Excellent project, i am sure he will stay interested, just don't bust his arse too much, otherwise, but honestly i am sure he will want to be the first one to drive it.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 11-26-2008, 06:17 PM   #72
my67chevytruck
Under Construction
Thanks. we are doing this as a father/son build and this will be his. he gets his license in Feb'09 and this will be his DD when complete.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 11-26-2008, 07:12 PM   #73
68 short step
looks great,yall keep up the good work
68 short step is offline   Reply With Quote
Old 11-26-2008, 10:08 PM   #74
my67chevytruck
Under Construction
Thanks Don! I want to have your skills when i growup!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 12-08-2008, 11:11 PM   #75
my67chevytruck
Under Construction
we made a little more progress the front end is complete. we mocked up the gas tank, installed the sending unit and mounted it to the frame. we also installed the SBC mount in the frame. the last pic is when a 15 yo has too much free time with the power washer!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
