Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 03-19-2012, 12:40 AM   #51
AusTx68
AusTx68's Avatar
Re: Hydroboost Mounting Plates
Originally Posted by Captainfab View Post
I can't say for sure if you will have to lengthen it or not. I would say more than likely you will.
How do I go about purchasing the plate? I will skip the bracket so I can keep it close to the firewall. Can you confirm the correct fittings for the hydroboost. I believe they are o-ring fittings in sizes M18-1.5 & M16-1.5
Last year I converted my existing PS lines to 6-AN TFE with flare fitting adapters. I figure all I need now is two hoses and two 0-ring to -6AN fittings.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 03-19-2012, 02:28 AM   #52
Captainfab
60-66 Nut
To make a purchase, you just need to make the payment. I will send you a PM with the details.
As for the fittings, I don't recal for sure......that sounds about right. There is a seller on ebay that sells all 3 hydroboost fittings to adapt to -6AN for about $24.00.
Old 03-19-2012, 02:43 AM   #53
mcmlxix
Collector of Projects
mcmlxix's Avatar
The company is calles Sweet Performance Products ....
From the eBay listing
"Hydroboost -6AN fitting kit"
This auction is for one compete set of 3 fittings.
This kit includes the following fittings, -6 to M16-1.5 bump tube, -6 to M18-1.5 bump tube and -6 to 5/16-24. This will allow the use of -6 AN stainless steel braided hoses including the low pressure bleed port. The fittings are steel with an attractive zink plating.
NOTE:: The pump is not included. This sale is for the fittings only.
Check our store for power steering hose kits.
We also build all kinds of custom hoses including DOT stainless steel brake hoses.
These parts were made in house by an American.
Rich
1972 K5 Blazer CST Click HERE
Old 03-19-2012, 11:26 AM   #54
El Campo
El Campo's Avatar
I am going to buy those same fittings. One thing that I do not know yet because I have not gotten them yet is about the diameter of the hole in the 5/16 fitting. This has to be the same diameter as the stock nipple had or it can lead to instability in the system from what I have read from people who have done a ton of these. It probably already is but would be something worth checking out. Otherwise it is a good idea to drill it out.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 03-19-2012, 12:47 PM   #55
AusTx68
AusTx68's Avatar
Interesting point. At a minimum, I would think the diameter matches the side being adapted (5/16). Any smaller would restrict flow. I'm betting some smart engineer designed them to support the proper flow.
I ordered the Ebay fittings this morning. I still need the TFE hose and 90 degree 6-AN fittings. I plan to flip the hydroboost so the fittings are on the bottom. I think that would make for a cleaner install. Does anyone know if flipping it will cause a problem?
Old 03-19-2012, 05:16 PM   #56
El Campo
El Campo's Avatar
Nope will not cause any problems. A lot of people flip them. Heck some of the aftermarket companies like for Corvettes ONLY have them upside down. I think that I am going to flip mine too
Hook em Horns!!!
Old 03-20-2012, 12:04 AM   #57
Captainfab
60-66 Nut
Thanks for posting more details mcmlxix
Old 04-01-2012, 12:23 PM   #58
AusTx68
AusTx68's Avatar
This morning I mounted the hydroboost using John's booster bracket and plate. I still need to reroute the high pressure line but you get an idea of how it looks. As you can see I flipped it so the fittings are on the bottom. The stainless TFE hose and ends came from Summit. I have around $300 in the setup (not including the master cylinder).
I took a test drive around the block. From the time I stepped on the pedal I could feel the difference. The brakes feel like my newer cars. It will certainly takes some getting used to.
Thanks John for an excellent product and super speedy shipping.
Old 04-01-2012, 02:02 PM   #59
RockTonka
RockTonka's Avatar
That looks good!
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 04-01-2012, 11:12 PM   #60
Captainfab
60-66 Nut
I agree, that looks real good
Thanks for posting pics of your installation Joseph
Old 05-03-2012, 04:59 PM   #61
Tmwoodall
I've got to ask, how did you piece this together for ~300?
What I am seeing:
Booster ~150
Cptn Brackets & Plate ~70
Lines ~220
Where did you save? I am planning on doing exactly as you have except painted semi glass black.
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 05-03-2012, 05:33 PM   #62
AusTx68
AusTx68's Avatar
What I am seeing:
Booster ~150
Lines ~220
Refurb Booster on Ebay ~ $120 w/shipping
Cptn Brackets & Plate ~ $70
Lines ~ $110 (includes four -6 AN TFE fittings and 6ft of TFE hose)
Hydroboost Fittings on Ebay ~$28 w/ shipping
That comes out to $328. There were other nominal cost such as a barb T fitting from Home Depot and hose clamps. To save costs I only used the teflon for the high pressure lines. The return line is regular stainless hose. I had an extra piece left over from an earlier project. That stuff is pretty cheap (6ft @ $25). You could save there by using 3/8" rubber hose. In the end I had leftover fittings. That's because I converted my PS lines to TFE last year and the high pressure line off the PS pump was long enough to reach the booster. So in all I have closer to $350 invested. That includes the fittings below.
Old 05-03-2012, 10:06 PM   #63
Tmwoodall
Awesome! Thanks. The hoses are the biggie. I have seen the reman pumps too, was just planning to buy new for the extra $20.
As it turns out if I am not mistaken I only need one line. I converted mine over to TFE on both lines due to my March kit. So I just need to T and connect the low pressure and make one more high pressure TFE for the second line.
Still need to make it to an event and see your truck.
Last edited by Tmwoodall; 05-03-2012 at 10:33 PM. Reason: Looked at plumbing diagram
Old 05-03-2012, 11:26 PM   #64
Captainfab
60-66 Nut
I am curious as to what application you guys are looking under for the rebuilt or new hydroboost units?
Old 05-03-2012, 11:29 PM   #65
Tmwoodall
I have just been searching GM or Chevy hydroboost.
Examples:
New, $145: http://www.ebay.com/itm/251050904964...#ht_500wt_1378
Reman, $120: http://www.ebay.com/itm/200726546898...#ht_500wt_1144
Old 05-04-2012, 11:38 AM   #66
AusTx68
AusTx68's Avatar
Examples:
I pretty much did the same thing and looked for mid to early 90s units. Settled on one from a 93' Chevy Truck.
Old 05-04-2012, 11:41 AM   #67
Pzary3233
I wonder if there is a huge difference between them and the ones on the newer (99+) Tahoes and Silverados? Those are much easier for me to find.
'55 3200 283 4 speed
'68 Pontiac Firebird Poncho powered with a 6 speed
Pzary3233 is offline   Reply With Quote
Old 05-04-2012, 11:44 AM   #68
Tmwoodall
IIRC from reading other Captnfab threads, the mounting hole spacing differs in later years, I could be wrong.
Old 05-04-2012, 12:36 PM   #69
mcmlxix
mcmlxix's Avatar
I have one from a 2005 GMC 2500HD, but I'm also using the master from the same truck. I picked up a Wilwood proportioning valve 260-11179. I went this route because I have a 4 wheel disc brakes with dual piston calipers on all 4 corners.
Rich
Old 05-04-2012, 12:38 PM   #70
Tmwoodall
In terms of MC and P.Valve I'll be using the MCPV-1 from CPP. Combine the two in a pretty sleek package, as seen above in AusTex68's truck.
Old 05-04-2012, 02:32 PM   #71
AusTx68
AusTx68's Avatar
I'm running 4 wheel disc brakes (95' Camaro rear calipers/stock 72' front calipers) with the CPP MCPV-1. I feel my braking is almost too good. It actually took a little getting used to. It's great now that I'm trained
I can't imagine the braking with dual piston calipers.
Old 05-04-2012, 02:58 PM   #72
Pzary3233
As far as I am aware the mounting hole spacing does not matter as you are going to take off the mount from the Silverado and use Captfab's adapter to adapt directly to the mount.
I think this is close to the route that I plan on taking. I do kind of wish that I could some how adapt all of the 1500 6 lug brake components to my C10. I know you can do that on the front... but the rear would be cool too. I might have to take some stuff apart and see what I come up with.
That is good to hear!
Old 05-04-2012, 03:02 PM   #73
Tmwoodall
Ditto, good to hear. My rear Wilwoods should be in today or Monday (front's are already installed). After learning how easy it was to do hydroboosted brakes I couldn't bring myself to let it be vacuum assisted, after putting such good components on elsewhere.
Old 05-04-2012, 11:24 PM   #74
Captainfab
60-66 Nut
That is correct. It does not matter what the factory mounting bracket is like. That can be removed and my hydroboost mounting plate installed. To my knowledge all the hydroboost units themselves have the same threaded 'stub' on the back.
If you want 4 wheel disc brakes, you can use the '88-'98 light duty C2500 front spindles and rotors, and assorted other pieces as described in the 'Disc Brake Upgrade Thread'. For the rear, you can use my 6 lug rear disc brake brackets for use with 15" wheels. These use the same calipers as would be on the front of the '88-'98 C1500 or light duty C2500.
Here's a link to those rear disc brackets
http://www.67-72chevytrucks.com/vboa...d.php?t=494411
Thanks guys for posting the links and info on your sources for the hydroboost units.
Old 05-05-2012, 12:06 PM   #75
Pzary3233
I was referring to the later 99+ brakes, but I have given that option some thought as well. I work in a late model salvage yard so those parts are easier to come by then the 98 back parts. I wonder if the 99-07 brakes fit on the 98 back spindles like the 07+ brakes work on the 99-07 spindles....? May have to mock that up but that's another thread all together.
