03-02-2010, 09:09 PM | #51 | |
Re: blazer roll bar and roll cage pics please
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
03-03-2010, 12:55 AM | #52 |
03-05-2010, 12:38 AM | #53 |
[QUOTE=Monte Carlo Man;3832771]
But I also reminded him of the safety factor. Unless the bars are welded to a steel pad, welded to the frame of the vehicle, the roll bar does absolutely nothing to protect the occupants in a roll over. /[QUOTE] I disagree... There are issues with welding the cage directly to the frame. The body is not, for good reason. If you insist at least figure out a way to attach it to the frame using bushings. It would be hard to preserve the stock look. The seat/seatbelts are not, if the body is that weak what good is it if the cage holds up but the body that you are strapped to does not? A well built cage attached to the body will work fine for 99% of our blazers. consider attaching it using plates to spread the energy over a larger area, consider attaching it in addtional locations (IE the bed floor & the bedsides) you get the idea. I do know a bit about this, heres a pic of the truck I helped my brother build to race in WSORR (I know, I know... but it's powered by a Chevy )
Dustin '97 Dodge Ram (daily driver) '71 Blazer (supposed to be a toy... insists on being a project) '85 Monte Carlo SS (project) |
03-05-2010, 10:38 AM | #54 |
we are going to have a thick steel plate run from side to side with the roll bars welded to it, then bolt the plate to the frame. when i carpet the floor i will cover the plate. it should work. man looking at the roll over pics are a little scary.
03-05-2010, 11:41 PM | #55 |
The point of putting them up is that these are all stock Jeep roll bars, fairly thin wall thickness tubing only attached to the body and they hold up fine in some pretty serious accidents.
if you want to attach your plate to the frame I would recommend using some type of bushing. Or better yet just tie it to a body mount. There isn't much benefit in going with an overly thick plate, more importantly use gussets. Even small gussets will multiply the strength of the cage. Here are some cool ones... http://bluetorchfab.com/store/index....ath=58&&page=1 Dustin
03-06-2010, 05:41 PM | #57 | |
******************************************** In-work on my 5.3L/4L65E/NP208 case conversion into a 1972 GMC JImmy 4x4... Not as simple as it looks folks.. |
03-11-2010, 11:08 AM | #58 |
It's mounted with plates, so not a real cage...
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
10-03-2010, 12:49 AM | #60 |
my roll bar aint best but i got it durt cheap from a 85 blazer hopefuly one day
ill finish it and have a buddy tig it up and rechromed but heres mines..
1972 gmc jimmy project comin soon ( jus a sin ) 1959 chevy apache shortbed fleetside (brsgrm) 1966 Chevy c30 duallie 2wd (big chief) Last edited by joemacho; 10-03-2010 at 01:05 AM. Reason: forgot the pics |
