Old 05-17-2019, 08:48 PM   #51
roll_the_dice
roll_the_dice's Avatar
Re: Making Keys For The ’60 -‘66 Chevy Trucks
Thanks Leon...That helps. I had no idea what the difference was. Mailing the package tomorrow. I sent tracking in a PM. I want 2 of the second key pictured. Thanks!
roll_the_dice is offline   Reply With Quote
Old 06-03-2019, 09:12 AM   #52
roll_the_dice
Thanks Leon! I received my locks a few days ago. So glad I got everything rekeyed...now a quarter can't unlock my doors or start my truck!
Old 06-03-2019, 09:45 PM   #53
LockDoc
The Older Generation
LockDoc's Avatar
Good deal. Thanks.
LockDoc
Leon
Old 06-09-2019, 11:23 AM   #54
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Leon, would you PM me your address? I’d like to send a door and ign cylinder to you for rebuild and like keys. I don’t have either key tho
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-09-2019, 10:39 PM   #55
LockDoc
LockDoc's Avatar
PM sent Clyde. No keys, No problem.....
LockDoc
Leon
Old 11-23-2019, 09:35 PM   #56
65 GMC
PM sent
65 GMC is offline   Reply With Quote
Old 11-24-2019, 08:47 PM   #57
LockDoc
LockDoc's Avatar
Originally Posted by 65 GMC View Post
PM sent
PM received & replied to.
Thanks,
LockDoc
Leon
Old 12-03-2019, 09:20 PM   #58
65 GMC
Got my drivers door lock and new key with the GM logo back today. It works great. Turn around time was very fast. Thank you for the quick service.
Old 12-09-2019, 04:34 PM   #59
LockDoc
LockDoc's Avatar
No problem. Thanks.
LockDoc
Leon
Old 01-01-2020, 11:50 AM   #60
vince1
What must one do to get the RH door keyed when there is no lock cylinder present? Does one need to buy another door handle? Thanks
vince1 is offline   Reply With Quote
Old 01-03-2020, 03:00 PM   #61
The Rocknrod
Moderator
The Rocknrod's Avatar
I received the keys you made for me, thanks.
Old 01-04-2020, 02:15 PM   #62
LockDoc
LockDoc's Avatar
The lock cylinders are universal and will fit in either handle. If you can find a lock cylinder I can key it the same as your other locks, then you can install it in your existing handle.
LockDoc
Leon
Old 01-04-2020, 02:16 PM   #63
LockDoc
LockDoc's Avatar
Good deal. Thanks for letting me know.
LockDoc
Leon
Old 01-29-2020, 12:24 PM   #64
Liz
Catchy title goes here..
Liz's Avatar
This thread has been added to the 60-66 FAQ post and unstuck. The FAQ index is there so that you can find these type of threads at anytime. Please use the report a post feature if you have a FAQ worthy thread you would like added.
Liz is offline   Reply With Quote
Old 04-14-2020, 09:19 PM   #65
tchevs
Hello Leon
Wanted to thank you for the information on this thread. Due to the covid crisis I’ve had a chance to finally work on my projects. Here is my question. I have a few ignition switches but no keys, my understanding is that you need the key to remove the tumbler. Am I out of luck with those switches? Is there a way to remove those tumblers without a key? Next question is, what is your current price to key alike ignition, 2doors and glove box lock? I don’t have a key.
Tony
tchevs is offline   Reply With Quote
Old 04-16-2020, 12:15 AM   #66
LockDoc
LockDoc's Avatar
Originally Posted by tchevs View Post
Hello Leon
Tony
Hi Tony,
I have a set of tryout keys (some people call them master keys) that I use to remove the lock cylinders from switches that have no keys. There really is no way for the average person to remove the lock cylinders without the correct key if you are trying to save them. If a person has a lot of old GM keys laying around they can sometimes get lucky and find one that will work.
The cost to re-key lock cylinders is $12.50 each except for the tailgate handles and they are $15.50. Plus how ever many keys a person wants & return postage.
The cost is determined by the number of cylinders that have to be re-keyed. For example, if the door cylinders are keyed the same then I would cut a key for them from the code number ($7.50 ea for replacement keys cut by code) and re-key the ignition and glove box to match them. @2 x $12.50
Thanks,
LockDoc
Leon
Old 04-16-2020, 09:33 AM   #67
tchevs
Sending you a pm
Old 06-29-2020, 07:59 PM   #68
motofly196
After owning my Short wide side for 16 years, I finally have keys! Thanks Leon, this project has been stalled for quite a long time. It's amazing how things start happening once you've got a set of keys!!
motofly196 is offline   Reply With Quote
Old 06-29-2020, 09:36 PM   #69
LockDoc
LockDoc's Avatar
No problem, glad I could help your project along!
LockDoc
Leon
Old 07-01-2020, 09:22 AM   #70
kens65fb
I have (2) door handles with locks, but no key.
Both door cylinders are coded 9449.
My ignition switch is coded 8074, has a working key, but the key is well worn.
Can you make the doors & ignition all work with one Key ??
What do I need to send you?
kens65fb is offline   Reply With Quote
Old 07-02-2020, 11:49 PM   #71
LockDoc
LockDoc's Avatar
Yes I can.
PM sent.
LockDoc
Leon
Old 07-03-2020, 10:16 AM   #72
Superduke
Originally Posted by LockDoc View Post
Yes I can.
PM sent.
LockDoc
Oh crap I kind of wanted to know the answer to that.
Superduke is offline   Reply With Quote
Old 07-07-2020, 08:21 AM   #73
badherb
badherb's Avatar
Nice job thanks
1960 SWB “Pops”
If you won't support our troops then stand in front of them!
badherb is offline   Reply With Quote
Old 07-08-2020, 10:56 AM   #74
LockDoc
LockDoc's Avatar
Here is my reply to him:
Hi Ken,
All you would need to send me is the ignition cylinder and key and I will change the ignition to match the door cylinders. The cost would be $15.50 + return postage (about 4 bucks) which would include 2 new keys cut to the 9449 code....
If you have trouble getting the ignition cylinder out of the switch let me know. If you wrap the ignition cylinder in some newspaper or paper towel and tape it up you can mail it in a 6x9 padded envelope by USPS First Class Mail for about 4 bucks.
LockDoc
Originally Posted by badherb View Post
Nice job thanks
Thanks.
LockDoc
Leon
Old 07-14-2020, 08:29 AM   #75
kens65fb
Hi Ken,
LockDoc
Thanks.
LockDoc
I received the re-keyed ignition cylinder, and door keys yesterday.
The keys work perfectly, and shipping was fast too.
Thanks again
