Old 03-08-2015, 07:20 PM   #51
Az. Hank
Az. Hank's Avatar
Re: 55 Chevy C-4
Well got the weekend off so I've gotten a little bit done. It's just clamped it together to get an idea of the ride height. I think I'm going to notch the rear frame to get the rockers to lay flat.
My 55 Build 55 C-4
Az. Hank is offline   Reply With Quote
Old 03-08-2015, 08:24 PM   #52
Kim57
Kim57's Avatar
Re: 55 Chevy C-4
Looks pretty slick on the ground.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-09-2015, 01:50 AM   #53
Az. Hank
Az. Hank's Avatar
Re: 55 Chevy C-4
Threw on a fender to get an idea what it will look like.
My 55 Build 55 C-4
Old 03-09-2015, 09:32 PM   #54
Az. Hank
Az. Hank's Avatar
Re: 55 Chevy C-4
Hey Nut Case, I just measured for you 31 inches from the center of the cab bolt to the center of the front cross member not the spindle center.
My 55 Build 55 C-4
Old 03-10-2015, 02:41 AM   #55
Az. Hank
Az. Hank's Avatar
Re: 55 Chevy C-4
Got the frame notch done. It's just tacked in. I wanted to be able to push it off the lift if we need to use it. Oh well back to work.
My 55 Build 55 C-4
Old 03-10-2015, 02:43 AM   #56
Az. Hank
Az. Hank's Avatar
Re: 55 Chevy C-4
A few more. That's it for this go around.
My 55 Build 55 C-4
Old 03-10-2015, 08:33 AM   #57
Kim57
Kim57's Avatar
Re: 55 Chevy C-4
Looks real good.
Kim
My build thread
Old 03-10-2015, 09:32 AM   #58
Az. Hank
Az. Hank's Avatar
Re: 55 Chevy C-4
Thanks Kim
My 55 Build 55 C-4
Old 03-10-2015, 02:35 PM   #59
lv2tri2
Re: 55 Chevy C-4
I have to ask. What are the benefits of such a long frame notch?
lv2tri2 is offline   Reply With Quote
Old 03-10-2015, 02:44 PM   #60
Az. Hank
Az. Hank's Avatar
Re: 55 Chevy C-4
I wasn't sure if I needed the room or not so I just made it that big. The frame I started with was kind of butchered. Now looking back, the rear section was sort of pointing up on a slight rake so I didn't want to change that. I think it is supposed to be strait not going up. I might just cut it off and weld in new metal. The more I think about it I might just build a new set of rails I'm almost there now.
My 55 Build 55 C-4
Old 03-10-2015, 03:14 PM   #61
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: 55 Chevy C-4
Nice work!
ChuckDriver is offline   Reply With Quote
Old 03-19-2015, 02:34 PM   #62
knomadd
knomadd's Avatar
Re: 55 Chevy C-4
I just found your thread and read everything. I want to see you finish this so I'll be following along. Nice work thus far. Not many people would go through the fine adjustments you are, like the front cross member placement. Keep it up!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-20-2015, 01:15 AM   #63
Az. Hank
Az. Hank's Avatar
Re: 55 Chevy C-4
I'm not happy with this frame it still looks butchered sooooo.
Building a new frame. I took a bunch of measurements and got out the factory assembly manual, picked up some iron here we go.
My 55 Build 55 C-4
Old 03-20-2015, 01:19 AM   #64
Az. Hank
Az. Hank's Avatar
Re: 55 Chevy C-4
Oh, it's nice to have a lift. Took the cab off once I got everything worked out. Thats it for this goaround have to load in Wittmann in the morning.
My 55 Build 55 C-4
Old 03-20-2015, 08:21 AM   #65
Kim57
Kim57's Avatar
Re: 55 Chevy C-4
Very interesting.
Kim
My build thread
Old 03-20-2015, 09:11 AM   #66
Advanced Design
Advanced Design's Avatar
Re: 55 Chevy C-4
Nice progress. I love my lift too and still am amazed you can use yours outside. Dumb question...is it pretty hot there in the summer? Good luck with your load.
Advanced Design is offline   Reply With Quote
Old 03-20-2015, 01:17 PM   #67
ptc
ptc's Avatar
Re: 55 Chevy C-4
Nice '55 project you got going on here, will be checking in on it.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 03-20-2015, 11:35 PM   #68
Az. Hank
Az. Hank's Avatar
Re: 55 Chevy C-4
Yup not much goes on in the summer, we will hit 120 degrees. I can't stay out in the heat to long. Most of this week it was around the 90s.
My 55 Build 55 C-4
Old 03-20-2015, 11:35 PM   #69
Az. Hank
Az. Hank's Avatar
Re: 55 Chevy C-4
Thanks ptc.
My 55 Build 55 C-4
Old 03-22-2015, 10:46 PM   #70
BIGglaSS
BIGglaSS's Avatar
Re: 55 Chevy C-4
Looks good, keep at it. I'm threatening to start over with new frame rails, also. I think it would be easier in the long run to start over.
BIGglaSS is offline   Reply With Quote
Old 03-23-2015, 01:43 AM   #71
Nut Case
Nut Case's Avatar
Re: 55 Chevy C-4
Master Hank, Thanks for the information on the location of the center line on the front axle. You are a pathfinder for me. I'm going to be doing the same things that you are right now. When you have a chance, what is the center line of the rear axle from the rear cab mount? It looks from the pic's, which are great, that the batwing is mounted flush with the under side of the frame. How much travel are you hoping to have in the front and rear shocks? What Shockwave's are you looking to use? Thanks in advance Nut Case. Keep on keeping on.
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 03-23-2015, 02:09 AM   #72
Nut Case
Nut Case's Avatar
Re: 55 Chevy C-4
Master Hank, what size rims, width? and off set are you hoping to use front and rear. Thanks in advance, Nut Case
Old 03-23-2015, 11:31 AM   #73
BIGglaSS
BIGglaSS's Avatar
Re: 55 Chevy C-4
Nut Case, if you haven't already seen HP1957's build, check out post #121. He gives the part numbers for the shockwaves.
http://67-72chevytrucks.com/vboard/s...=535686&page=5
Hank has the batwing mounted above the top of frame level. And, Harvey "z"'d his frame. This gets the truck body lower than the Flat-out and Progressive kits. Those kits put the mounting points under the frame. Which, is why I'm also leaning towards building a custom frame, but using the Flat-out front crossmember.
Also for ideas, check out Newman's : http://www.newmancarcreations.com/trucks/
His mounting points look like they are higher than the other mentioned kits, but not as high as Hank or Harvey are going. But, they use the stock mono-spring.
And for wheels, I suspect nearly any modern wheel combo with high positive offset will work in. Check out this calculator: http://tri-5.chevyrides.com/rear_tire.php
The rear fender width on our 55-59 Task Force stepside trucks is just over 72" at the narrowest point. Enter 72" for the fender width in the calculator. For the fronts, plan on at least one inch narrower, but caution, I haven't measured the front yet, and I'm also not using a C4 front end.
I'm hesitant to give the offset numbers I have calculated, because I haven't tested or mounted them yet. I'm trying to mount C6 corvette wheels, which have very high positive offset and I will have to use spacers. This will be approximately 30 mm positive to fit in the rear. The problem with high positive offset wheels, is that they are made for metric cars with the 5 x 120mm bolt pattern. And corvettes have even more high positive offset. Our C4 hubs are 5 x 4.75 (120.65mm). Some people will interchange them, but to me, it's not right!
Old 03-23-2015, 11:03 PM   #74
Az. Hank
Az. Hank's Avatar
Re: 55 Chevy C-4
I'm back on the road so I'll get you those measurements when I get back home. The Shock waves I was looking at travel 3.5 and 4 inches. I don't remember which one was which. The wheels I haven't figured out yet.Those Vette wheels that are on there leave alot of room. I used the 84 setup because there is more room for different wheels.
Hope this helps.
Hank
My 55 Build 55 C-4
Old 03-24-2015, 01:49 AM   #75
Nut Case
Nut Case's Avatar
Re: 55 Chevy C-4
Master Hank, when your back, and have minute that would be great, this is not a time sensitive issue. I have already got my shockwaves, I would just like to compare them and get data on why you chose this shock? I know that the c-4 front and rear are from a 93 vette so the rim size will be 17" to clear the calipers, so I'm told. Which is no problem. I trying to figure out the off set to size my tire with the least amount of modification as possible.
Hey BIGglaSS the data that you gave me is great! Any more treasures feel free to send a private mesage, by chance do you have a project that you're working or going to work? Let me know Nut Case
