Old 09-04-2021, 07:27 PM   #51
3757chevy
3757chevy's Avatar
Re: 1968 C10 Suburban
Thanks! I still think it needs a little "altitude" adjustment. Maybe a couple three inches lower ?
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 09-12-2021, 07:54 PM   #52
3757chevy
3757chevy's Avatar
I used a 71-72 TH400 kickdown switch by making a bracket for the firewall side of my accelerator pedal assy.
MIKE
Old 09-24-2021, 01:01 AM   #53
3757chevy
3757chevy's Avatar
Originally Posted by Dieselwrencher View Post
Where did you get your tank from? This late spring I tried buying one but all the burb specific ones were not available. Great fun. I'm half tempted to put a F*rd tank in it from my brother's 99 F350 he parted out. It's a 40gal or something.
Originally Posted by 3757chevy View Post
Thanks. But I haven't replaced the fuel tank YET.
I got a stock replacement tank kit from Classic Industries today.
MIKE
Old 10-17-2021, 01:12 AM   #54
3757chevy
3757chevy's Avatar
I replaced the heater core and blower motor with wheel this week.
MIKE
Old 10-17-2021, 01:16 AM   #55
3757chevy
3757chevy's Avatar
I just replaced the water pump , thermostat and hoses three weeks ago.
MIKE
Old 10-17-2021, 01:22 AM   #56
3757chevy
3757chevy's Avatar
I bought a set of rear springs to lower a pickup two inches, I think with the added weight of a suburban it may lower it more. Anyone have any experience or opinions ?
MIKE
Old 10-17-2021, 10:01 AM   #57
HO455
Post Whore
HO455's Avatar
A C10 Suburban is 800 to 1200 lbs more than a comparable pickup depending on options. So my guess is that it should sit about 1 inch lower than a pickup with the same springs would.
RIP Bob Parks.
Old 10-17-2021, 11:16 PM   #58
3757chevy
3757chevy's Avatar
Thanks , That's what I was hoping for . My 67 Step side had 4" drop springs and it would bottom out sometimes. I would like to avoid that if I can.
MIKE
Old 11-11-2021, 02:14 AM   #59
3757chevy
3757chevy's Avatar
I installed some Jeep JK headlights I found at a yard sale . Now I can replace the bulb instead of the whole headlamp.
MIKE
Old 11-11-2021, 10:40 AM   #60
LockDoc
The Older Generation
LockDoc's Avatar
I used those in my '67 Panel Truck with the relay upgrade. They work good.
LockDoc
Leon
Old 11-11-2021, 12:55 PM   #61
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Do those have glass lenses? They look really nice.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 11-11-2021, 02:00 PM   #62
3757chevy
3757chevy's Avatar
LockDoc
Thanks. What does the relay upgrade do?
They are Lexan.
MIKE
Old 11-11-2021, 07:24 PM   #63
LockDoc
LockDoc's Avatar
They are Lexan.
Read through this thread.....
http://67-72chevytrucks.com/vboard/s...d.php?t=173230
LockDoc
Leon
Old 11-12-2021, 09:21 AM   #64
BigBird05
Those look really nice. Do you know what year they are for?
BigBird05 is offline   Reply With Quote
Old 11-12-2021, 02:22 PM   #65
LockDoc
LockDoc's Avatar
I used Jeep Wrangler headlights in my '67 Panel Truck. Jeep JK Wrangler headlights ('07-up) are a direct bolt in swap for the old sealed beam headlights in our trucks. They even have the 3 lugs on the back for alignment and use the stock '67-'72 trim rings. I went ahead and bought the headlight conversion pigtails for the swap too.
I bought both on e-Bay. Here are the actual pigtails I bought and the headlights I bought were from a private seller that changed his over to something different. They are in excellent condition. You have to be careful because there are a lot of look alikes. They do make exact replacements too but you have to watch, some of them come with bulbs and some don't. The easy way to tell the OEM's are by the back. I think the lights are the same from 2007-2015.
https://www.ebay.com/itm/13094045132...78.m1438.l2649
Sorry about the hijack.....
LockDoc
Leon
Old 11-12-2021, 11:27 PM   #66
3757chevy
3757chevy's Avatar
Thanks. I bought mine at a yard sale from a guy that said they came out of his 2010 Jeep JK.
LockDoc
No problem Leon .I learn a lot that way . And yeah mine have the Mopar pentastar on the back. I bought the same adapters on Amazon. I've ordered relay/pigtails.
MIKE
Old 11-21-2021, 11:57 AM   #67
uppster
Dont take it apart.
uppster is offline   Reply With Quote
Old 12-17-2021, 01:52 PM   #68
3757chevy
3757chevy's Avatar
Question Re: 1968 C10 Suburban
Originally Posted by uppster View Post
Dont take it apart.
MIKE
Old 12-27-2021, 09:03 AM   #69
04ls1gto
I had truck lowering springs at first and it drove terrible, rear of truck was very soft. Switched to cpp 4.5" hd springs meant for the suburban and it drives awesome now
04ls1gto is offline   Reply With Quote
Old 03-02-2022, 01:57 AM   #70
3757chevy
3757chevy's Avatar
I had a backup light acting up. I figured out it was the socket connector. What I was sent from LMC would not work so I modified my light with a sleeve to hold it and it works well . I did not change anything that can't be fixed correctly if I do find the correct part(in picture 2 ,which is part of a harness).
MIKE
Old 03-14-2022, 01:23 AM   #71
3757chevy
3757chevy's Avatar
My oldest Granddaughter helped sand and prep the brackets for the new mirrors I will be installing.
MIKE
Old 03-14-2022, 09:26 AM   #72
LockDoc
LockDoc's Avatar
Well, tell her she did a great job! With the paint on there they look like new.
LockDoc
Leon
Old 03-16-2022, 12:52 AM   #73
3757chevy
3757chevy's Avatar
LockDoc
Thanks, I will let her know. I put them on , they look like they belong there.
MIKE
Old 03-16-2022, 12:53 AM   #74
3757chevy
3757chevy's Avatar
Now I need to get the holes from all the other mirrors patched up.
MIKE
Old 03-16-2022, 12:58 AM   #75
3757chevy
3757chevy's Avatar
I need to get a lot of things done this spring . I'm running out of storage for the parts I have to install .
MIKE
