01-08-2022, 10:36 AM | #51 |
Re: Someone else's truck. '48 Chev
Coming along very nice!! Sorry about the tube nut but stuff happens. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
01-10-2022, 10:13 AM | #52 | ||
Ya I think no matter how many tubes you flair you will still forget the nut sometimes lol
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
01-10-2022, 10:19 AM | #53 |
Well over the weekend I figured out where and how to mount up the peddles. Turned out really nice, I will defiantly use the this kit again. I also got the mustang steering column installed. Now to take apart weld and paint.
01-10-2022, 10:39 AM | #54 |
you are cookin sir, they are guna love it.
01-10-2022, 01:05 PM | #55 |
Pedals look fancy. Who makes them?
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
01-11-2022, 10:47 AM | #56 |
Thank you, I'm trying.
Walton Fabrication.
01-13-2022, 06:21 AM | #57 |
6>8 Plugless........
Those pedals look really nice!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-18-2022, 12:55 AM | #58 |
Well the peddles are painted and installed, made some foot pads that thread on. Gas peddle is hooked up. You can also see how I mounted the M_stang steering column, when the steering shaft finally shows up yesterday!? it will go above the headers to the s10 box. The cooling fan/shroud are mounted it's a Derale 2400 cfm unit and today I got the AC condenser/dryer sitting in place.
01-18-2022, 09:00 AM | #59 |
Very clean looking, and I still like that radiator/fan/shroud a lot.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
01-18-2022, 11:02 AM | #60 |
Everything looking great...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
01-18-2022, 01:09 PM | #61 |
It all looks really well build. Nicely done.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
01-19-2022, 01:20 AM | #62 | |
Thanks Jim Thank you Marc It all seems to be coming together nice.
01-28-2022, 06:44 PM | #63 |
I installed the under dash ac/heater vents and got the under dash ac system mounted. Wiring has started now that all the hard parts are in place I had to move the fuse panel a bit from where the kit wanted it to clear the clutch pedal. Also got the heater core plumbed in.
01-28-2022, 06:51 PM | #64 |
Nice work. We are in about the same spot putting the trucks together.
01-28-2022, 06:52 PM | #65 |
Probably the most complicated rad support, but it works good. Here is how the steering shaft worked out using the M_$tang column.
01-28-2022, 09:31 PM | #66 |
Looking good there Bob...Jim
01-29-2022, 09:51 AM | #67 |
That steering column turned out very well. It looks a lot nicer than having an S10 unit in the cab (I know, cuz I have one and it is seriously ugly!). A few quick questions:
-What year Mustang is the column out of? -What firewall pass-thru did you use for it? |
01-31-2022, 12:17 PM | #68 |
something seams fishy ... this is going together a little too well ...
02-02-2022, 09:14 AM | #69 | |
Thank you
I have no idea what year column it is came with the truck. Fire wall pass through is just a rubber grommet, if I find it flexes whenever I get the tires I was going to use a 1" pillow block bolted to the fire wall. But tight so far. Ya I'm wondering the same
02-09-2022, 12:23 AM | #70 |
Fender and box modification has started. The owner did not want as fat of a rear fender. I'm cutting the fender width down 3", then making my own mounting flange and making the box 6" wider. It's all just mocked up for now till the tires show up then I will fine tune the box width.
02-09-2022, 12:28 AM | #71 |
Also been working on more wiring, but I did get the block that bolts to the back of the ac compressor. So then I got the hoses trimmed up ready for crimping.
If anyone is looking for a cheap driveshaft, this one you can buy pre made (Amazon)
02-09-2022, 09:59 AM | #72 |
hmmmmm... widen the box , that is an interesting mod. that I have not seen before. I enjoy seeing the ideas that you all have.
I look forward to seeing this when done, Thanks for the pics, and the workmanship looks 'top shelf'
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
02-09-2022, 12:28 PM | #73 |
NICE!! someone else to share ideas with! i've intended to leave the rear fenders as-is and widen the bed until they cover the dual's.
are you making a header plate, gap filler, or going to seam 2 together? tailgate? i've been planning at this point to buy 2 headers and 2 tailgates, none with logo, to cut and seam together. |
02-15-2022, 09:52 PM | #74 | ||
02-16-2022, 07:59 AM | #75 |
Very nice work. I was involved with making a bed wider on a 53 1.5 ton bed many years ago. It was more work than the owner thought but it fit that truck a lot better IMO.
