11-12-2009, 09:27 PM | #776 |
Re: LFD's 4dr Tahoe Build
11-13-2009, 01:34 AM | #777 |
. The Nip is a rotary style and the veins have some type of wear coating on them and the friction is down to almost zero. If this is true I really don't know. What I do know is this one came from the pick-n-pull and was bolted to my rock crawler and used for 2 seasons with out oil ever being added and will keep a 1/4" die grinder full throttle with the motor at 1200 rpm's.
Kevin LFD Inc.[/QUOTE] Kevin, what pressure readings do you think you'll be getting with that "vein compressor" in your tanks? I've heard "vein compressors" are known for air volume but not for pressure, what can you tell us about this? |
11-13-2009, 01:48 AM | #778 |
That model Denso is has a swash plate and double ended pistons. No veins. The valves are reed valves. Yes, the swash plate is tin coated as that is where the piston shoes ride. I have done testing on this model many times. They are very reliable pumps and hold oil very well. In fact, dumping the oil to measure it is a time consuming job. And there are millions of them in the bone yards. The Ford FS6 compressor is a near copy and there are even more of them in the yards.
Man! I miss that job!
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
11-13-2009, 02:45 AM | #779 |
Enjoying left field
What did these pumps come on? Both the Denso and the ford one. Is there a thread somewhere about how to convert one to an air ride compressor?
11-13-2009, 11:50 AM | #780 | |||
Here is some good reading that EDFLORES posted up for me. http://www.s10forum.com/forum/f125/o...thread-215865/ Kevin LFD Inc. Last edited by Rokcrln; 11-13-2009 at 11:53 AM. |
11-13-2009, 01:09 PM | #781 |
Enjoying left field
Cool. Thanks Kevin.
What about the smaller AC Delco compressors? Will they work? They are alot more compact. Last edited by woodwright; 11-13-2009 at 01:26 PM. |
11-13-2009, 01:42 PM | #782 |
Rods
There is a oiler for shop tools that you can use that will oil inline... That should work..
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
11-13-2009, 05:31 PM | #783 | ||
Kevin LFD Inc. |
11-13-2009, 08:47 PM | #784 |
67-72 parts collector,…
Do you really want an inline oiler?
Won't that screw up the valves? The air needs to be dry.
11-13-2009, 08:53 PM | #785 | |
Kevin LFD Inc. |
11-13-2009, 09:37 PM | #786 |
Thanks for the compressor link, it is really informative. Do you think the compressor that comes with the 5.3 vortech can do the same job? If I ever do my 5.3 conversion I wont be using the A/C, so it would be great to be able to use it for air supply.
11-13-2009, 10:46 PM | #787 | |
Kevin LFD Inc. |
11-17-2009, 08:58 PM | #788 |
Small progress but still progress. I narrowed my rear floor 4" to match the 2" per seat I had to do for wheel tub clearance. Then I trimmed the body for the tubs to slide in and tack weld. Once the body comes off I will finish the inner wheel wells and seal it all off. When aired out I have 1/2" from the top of the tire and 5/8" from the side wall to inner tub side. Also my seats clear the tub by about 5/8" as well just enough for upholstery to clear. The second row seats will need to go forward 2" so everything clears with them as well.
Kevin LFD Inc. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
11-18-2009, 12:31 AM | #789 |
Luv the Crewcabs
Just a Couple of ??? for You
(1)Do u ever Sleep? Between Customer Builds, Your Own Builds, Constantly Coming up with New Improvements for our Trucks & Also Working a Regular JoB???????????? (2)Just out of Curiosty Do u always use the same tape measure When doing work with as close tolerances as u do? Not much Room for error with this type work?????? Anyhow, Many Thanks for Taking the Time to share with us, It Give's Hope & Inspiration to Many of us............... Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
11-18-2009, 10:38 AM | #790 |
Restoring a 68 SWB
Great work Kevin. I can't believe you aren't doing this for a living yet. Mucho talent brother.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
11-18-2009, 12:38 PM | #791 | ||
Kevin LFD Inc. Last edited by Rokcrln; 11-18-2009 at 12:39 PM. |
11-18-2009, 01:16 PM | #792 |
Under Construction
great progress Kevin!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
11-18-2009, 04:02 PM | #793 |
I'M TRUCK CRAZY!
Lookin good Kevin. I really like how you are using the newer seats and floor. It is neat that the second row will fold down.
11-18-2009, 05:11 PM | #794 |
I did a bit more work on the rear floor. I shaved about 1 1/4" off the under side of the floor where it was limiting my mounting height because it sitting on the rear diff tube work. I then plated it with some 1/8" steel for reinforcement. Now by doing this my rear floor will only be 2 1/4" higher then stock but still able to lay out on a 31" tall tire
Kevin LFD Inc. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] Last edited by Rokcrln; 11-18-2009 at 05:12 PM. |
11-18-2009, 08:14 PM | #795 |
So what's cheaper.. Buying a Brand new tahoe or building one with a classic body style?
Very nice!!!
1990 Dodge Ram D250 Cummins |
11-18-2009, 08:36 PM | #796 | |
Did some more work today on the passenger side wheel tub. Now I just need to make one to match for the drivers side. Kevin LFD Inc. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
11-19-2009, 10:27 AM | #797 |
Gearhead
That is just amazing craftsmanship, keep it up, I wanna see that thing in paint!
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
11-19-2009, 11:46 AM | #798 |
Thanks it has been fun (at times) but now I get to figure out where and how to put shocks on the rear. I need 9" of travel so the over all length will be about 23". My plan is they will fit between the wheel tub and floor just behind the second row seat. I will add to the front of the wheel tub to incorporate them in once I figure it all out. I wanted to get the seats and tubs in first to really see just how little space I have to work with. Should be fun
Kevin LFD Inc. |
11-19-2009, 11:56 AM | #799 |
How did you do the lip at the bottom of that filler panel? Is it a angle bent in the brake, stretch/shrink, then welded on or how did you get it like that?
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
11-19-2009, 12:02 PM | #800 | |
Kevin LFD Inc. |
