#826 | |
Re: Project: Recycle
You can also buy kits that allow you to install a rack and pinion steering to the old GM trucks. No need for a full swap to do that.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#827 |
I'm just glad to be here!
Progress looks good Scoti. Don't forget I would be interested in that extra LWB frame if you don't need or want it...
Looks like you could make it to C10's in the Park if you keep making progress like this...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#828 |
Bumping this one back up. Took some time off from this thing while researching plans/options. Measurements indicate my factory 12-bolt will be too wide w/my current wheel set-up & the narrower 9" I have will be too narrow. Been investigating possible wheel choices to allow using the 9". I know exactly what I want but it's hard to pull the trigger when that money can be used toward the big picture (never know when I'm going to come across that future gearhead optioned home within my budget so I have to always be ready).
So, I turned my focus to other items. I have everything set-up for bags on this thing but really have been leaning toward changing to coil-overs. Since my rear shock set-up utilizes the G-body (Monte Carlo SS) shock arrangement, that was pretty easy to solve. The front set-up is an early version of PB's Dropmember. I spoke w/PB & they don't make an upper C/O mount for my 'older' version. Of course I could update to a newer unit that is C/O ready but I'm not spending the $$ over again. I built the rear suspension set-up so I'm pretty sure I can fab a new C/O friendly upper mount for my older Dropmember. I need to reach out to Ride Tech about shock lengths/spring rates that will work for my set-up & use that info as I design the mounts so I can optimize the shock travel (I want the longest travel possible). Beyond that, I finished up the cab floor mods. With the cab now on the new chassis I could verify clearances. Everything cleared as hoped but the bellhousing was too close for my comfort level. The 2pc high hump cover allowed minimal gap @ the bell housing on the 700r4 (I couldn't slide my finger-tip through). I decided make the 2pc set-up a 1pc unit & remove the flange area where the clearance was the tightest. Then I needed to finish out the area cut out for the T/A x-member hoop extension (I'm running a 1pc drive shaft so clearance was necessary). I decided to flange the sheet metal cover & bolt it in like the 'high-hump' bellhousing cover vs welding it to the floor.....
#829 |
Now I need to rearrange things & get rid of some stuff in the shop (2nd SWB bed + 2 extra white tailgates for my 99). I need to make room for pulling the cab back off & welding up the notched cab support underneath.
#830 |
maibe mount the 9 inch with a set of spacers for now and have the 12 bolt shortened
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#831 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Everything looks good!
Glad to see you back on this cool truck.
#832 |
Nice
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
#833 |
Looking forward to seeing this one!!!
#834 | |
Rollin' Old Skool
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#835 |
Finally! Glad to see you back on this one. I might know someone that could use that extra bed and the extra LWB frame if you still have it too...
#836 | |
No extra bed. SWB frame.
#837 |
Even better for the frame...LMK
#838 |
Blowing the dust off....
No progress on the decision about swapping to C/O's. I mulled it over but haven't decided so I moved to other things on the list. I was going to get Precision Rubber to do the rebuilds on my vent windows a while back but they stopped offering the service. Then, they started up again. By the time they did this, my $$ was allocated elsewhere. I'll just do them in-house over the holidays @ this point. Lately, my time has been spent focusing on the bed layout so I can finish the SS exhaust & bed floor. Since my drop method was done via 'backyard-engineering', it took some thinking to figure out the floor & bed mounting. The dimensions for relocating the mounting points were easy. It was the mounting methods (bed structure as a whole assembly & bed floor/tubs) that took some thought. My rear wheels will be @ least 10" wide so I require stretched tubs for clearance (the current old-school set-up is ~13" wide w/no weight on the wheel/tire). Add in the fact that the bedside 'crease' (the bold, recessed bodyline on these trucks) is the top of the tire height @ ride height so the tires/wheels need to be tucked w/o being excessive & still clear during travel. My OE tubs are fairly beat up so I looked on C-list for alternatives & then to the WWW for re-pops. Like my Dually, I decided there needed to be some sort of compromise as this truck was not planned to ever be anything more than a cool driver. I adjusted my plans to keep things simpler & have moved forward. I bought aftermarket widened tubs & will roll w/them. I also purchased wood locally since I need to tweak the layout for my needs there as well. The vent assembly's staged for some finish prep, epoxy, satin black color & the stretched aftermarket tubs......
#839 |
The floor cross-sills have been mocked-up to define clearances of frame & exhaust. All as planned there. Since I was originally planning on a steel floor (remember... this project is full of recycled parts from other projects), I had to change a couple things because of the wood floor. After thinking through the adjustments, I'm moving along.
My plan is a modified version of an OE 'look'. I'm doing a GMC look for the inside of the bed vs. how Chevy did them. It keeps the floor & tubs easier & relatively worry-free vs. higher end choices. This is how Chevy did them:
#840 |
And...... GMC:
#841 |
I'll go w/the GMC scheme for simplicity, costs, & ease of upkeep.
Here is the cross-sill layout while checking clearances & verifying one of the mount location changes required because of the frame Z & raised floor.....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-13-2018 at 07:57 PM. |
#842 |
The floor 'assembly' will now mount above the bedside flange vs. how it was from GM (cross-sills & wood below the flange). I'm building front & rear 'sub-frames' for the inner bedsides that will add more structure & put the cross-sills @ the required height to align the bed to the rest of the body.
The sub-frames are started & I'm in the process of finishing them up now. I changed some things for better visual alignment & those I've shown liked the layout. We'll see.... The cross-sills are 6" higher than OE. The floor is 7" higher. I borrowed a table saw to play w/some wood for the floor & have some offers to assist there as well from others w/more experience (I'm not a wood worker). Should have more progress pics after the holidays.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-13-2018 at 07:59 PM. |
#843 |
Rollin' Old Skool
Glad to see you back at it!
#844 |
Scotti, Glad to see you back on this project. I guess I am not seeing the difference between Chevy and GMC beds in the pictures, you might have to explain it to me sometime...
#845 |
Is the difference the tub colour?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#846 | ||
GMC's had black floors/tubs. Chevy's had black floors & body colored tubs. I'm not going to try & re-create the patina of the inside of the bed. It's will be black paint on everything new (tubs, strips, & wood).
#847 |
I see now. I was looking for some type of structural difference, not paint colors...
#848 |
I've been working & trying to make progress. Seems there's not much to 'show' vs. the effort & time
![]() It was only temporary, but it's progress regardless. The bed dropped over & onto the rails w/o issue. It allowed me to get the rear bed positioning validated 100% as well as verify there were no unforeseen issues. The body lines looked good & clearances under the cross-sills looked right. I have a couple of tweaks to make that I was expecting so all in all I'm happy. Special 'Thanks' to my good friend Jeremie & his boys (No.1 & No.2) for their company & assistance! It's good to have great people in your life! The truck is mocked up @ ride height in the pics (4.5" @ the front cab mount; 5" @ the rear cab mount; hub C/L @ approx. 15"):
#849 |
Village Idiot....
Nice work Scoti!
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
#850 |
Progress is progress, no mater how much.
