02-09-2017, 08:55 AM | #826 |
Happy to be here
Re: 85 GMC Sierra "Scarlett"
Chris came over last night and we got a few more things accomplished. We worked on the wiring harness for the A/C and cleaned it up quite a bit. I still have to adjust the length on some wires but is almost ready for loom.
02-09-2017, 09:00 AM | #827 |
Happy to be here
We worked on the harness together, then Chris started on the power steering pump. He cleaned all the bolts and mocked it up while I cut and soldered ground wires.
Once his bolts were dry we unraveled the puzzle of brackets and got the new pump in place. We have to hang the compressor before we can tighten everything down.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-09-2017 at 10:53 AM. |
02-09-2017, 09:10 AM | #828 |
Happy to be here
My buddy Jared dropped by with a big box full of goodness from Mike Losh at @slosh_tubz. He has been diligently working on a new version of his Tubz called Mild Tubz.
These were designed with input from myself and Eric Miller from Squarebody Specialists. They were specifically made to clear the stock a/c components of a 73_87 GM truck. He used an actual front clip toensure they are a bolt in design it has very minor trimming to the inner fender. This area will be covered once the tub is installed and should not affect the structural integrity. Thank you Mike Losh for bringing these to market .
02-09-2017, 09:19 AM | #829 |
Happy to be here
Earlier in the day the weather had improved and the humidity had dropped. I took advantage of this and got another coat of dye on the Brothers truck parts arm rest pads and map pockets. My original attempts had failed due to weather change and blushing.
This time I had success and they come out great. The map pockets look so much better now. I will install the pads later
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-09-2017 at 10:55 AM. |
02-09-2017, 10:45 AM | #830 |
My door panels have been mounted for over a month and I still can't make myself pull the plastic protection from the brushed aluminum panel...
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
02-09-2017, 10:50 AM | #831 |
This is some of the highest quality, most practical, truck porn I've seen in a while.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
02-09-2017, 10:58 AM | #832 | |
Happy to be here
02-09-2017, 11:24 AM | #833 |
Uhh . . .... Who? What? Where?
02-09-2017, 12:30 PM | #834 |
I think he was talking about a astonished, speechless placement of both hands on his cheeks an a hearty "Well, I do decla-ah"
...I'm sure that was it...
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
02-09-2017, 01:19 PM | #835 |
67-72 parts collector,…
Thank you. I will check them out.
02-09-2017, 01:31 PM | #836 | |
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
02-09-2017, 02:46 PM | #837 | |
02-09-2017, 07:58 PM | #838 |
Happy to be here
Things are heating up at @americanracing custom shop. Scarlett is getting new shoes and they are smoking hot.
02-10-2017, 09:10 AM | #839 |
Happy to be here
Last night I focused on mocking up the a/c compressor. You would think I could just bolt it back in place. I thought so too till I started looking at the bolts that we bagged and tagged.
Many of the bolts were not correct. Some were too long with extra washers, and others didn't have the built to on flange so I spent a lot of time to resolve that issue. Once the compressor was in place I tweaked the hardlines and rerouted them a bit for better flow.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-10-2017 at 10:41 AM. |
02-10-2017, 04:39 PM | #840 | |
02-10-2017, 11:26 PM | #841 | |
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
02-11-2017, 01:40 AM | #842 | ||
Happy to be here
That's a dual snorkel base from an 85 F body. Since Scarletts motor is a 305 HO I thought the breather was only fitting. It was once mounted on a Suburban so it will clear my set up just fine. No, I don't have any intentions of running the fresh air ducting.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-11-2017 at 08:43 AM. |
02-11-2017, 02:51 AM | #843 |
Will this require fender removal or can it still be done with them installed?
02-11-2017, 03:02 AM | #844 | |
What are the specs on the wheels and tires you're gonna run with those VF506s?
02-11-2017, 08:48 AM | #845 | |
Happy to be here
The fronts will be 22x8.5 with 5.25" backspace and the rears will be 22x10.5 with 5" backspace. We haven't made the final decision on tire sizes. The front will probably be a 265/35 with a 315/35 rear. I really want as wide as tire as possible on back with a moderate sidewall
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-11-2017 at 08:56 AM. |
02-11-2017, 09:06 AM | #846 |
Happy to be here
Last night I mocked up rest of the a/c and the cooling system. I hate to do all of this twice, but I know that I need to fine tune the fit. This also allowed me to add correct bolts or replace with button heads where possible.
Today Chris and I will tear some of this down to touch up and make the final installment.
02-11-2017, 09:10 AM | #847 |
Happy to be here
I got a text from Chris at American Racing wheels. My wheels are shipping out and will be here soon. He said expect 5 boxes. I wonder what that means? Here's a teaser pic from production before final polish and assembly
02-11-2017, 10:03 AM | #848 | |
BTW, you can defer these questions 'til after LST, ha. I know you guys are crankin to wrap things up. |
02-11-2017, 10:04 AM | #849 | |
Happy to be here
Through researchI was able to determine hat the motor is an 85 305 HO L69 with the factory mid rise aluminum intake. When I pulled the pan I saw that the cylinders had been honed, but no marking on the pistons to indicate an overbore. I know it has an aftermarket cam, but no idea what the specs are.
02-11-2017, 10:26 AM | #850 | |
