Old 04-08-2017, 07:01 PM   #876
youngrodder
youngrodder's Avatar
Re: 53 Surburban "Family Truckster"
Originally Posted by Iceburgh View Post
Very nice....but HD in Harley really stands for Hundred Dollar.
They look spendy.
Not bad at all. $24.00 shipped for the pair.
Marc
Originally Posted by Nut Case View Post
Youngrodder
Great idea for a re-purpose, if there pricey I think that maybe a fab could be done.
Keep on keepin on
NC
I hear ya, most things can be fabricated. I choose to spend a little more on things that are all ready thought out and clean. $24 for the pair shipped I didn't think was too bad. I could have done something with zip ties for 17 cents but not the look I was going for....ha ha
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 04-09-2017, 11:42 AM   #877
ptc
ptc's Avatar
Looking really nice! --- great idea on the brake line holders. Also look into Longacre and Allstar racing parts. They have rollbar clamp (different diameters) style parts like that to hold all kinds of things and their prices are better than HD stuff....
racers are poor!!! I wonder why?
Keep up the good work!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 04-09-2017, 12:30 PM   #878
Flysocal
I really like the idea of a HD pop up gas cap. Bought one about a year ago but decided to go with a conventional fuel door in fender.
Flysocal is offline   Reply With Quote
Old 04-10-2017, 01:07 AM   #879
CanadianKid
Thumbs up Re: 53 Surburban "Family Truckster"
Youngrodder your burban is awesome, enjoying the thread.
CanadianKid
CanadianKid is offline   Reply With Quote
Old 04-10-2017, 10:19 PM   #880
youngrodder
Thanks, I'm familiar with Allstar. They are a brand that Lane Automotive carries. They are like Summit only smaller but local to me.
This has been my plan for a gas filler for quite some time. I did a quick mock up and it will work. The only negative is that I need to modify the filler neck of the tank. Currently it is at an angle. The idea is that I will mount this in the wood floor just inside the rear doors slightly off center. I also placed the 3rd row seat in place to make sure that the seat would not interfere with fill ups. I will get pics soon.
CanadianKid
Thanks man I appreciate it.
Marc
Old 04-12-2017, 12:12 PM   #881
ptc
ptc's Avatar
Marc
Yea Summit carries alot of their stuff or you can shop direct.
https://www.allstarperformance.com/catagories.htm
Old 04-23-2017, 11:08 PM   #882
youngrodder
Ok I need to come clean.....I have been sand baggin a little. I have been working on the Suburban pretty steady for the past few weeks but I haven't been updating my build thread so I will warn you this update will be picture and text heavy as I attempt to catch this up to real life...ha ha
Ok about 3 weeks ago I realized that something needed to be done with my Porterbuilt rear bag mounts as they didn't allow the bag when fully deflated to collapse enough to lay the running boards flat. I was about 2" short. To most this probably seems like I'm being picky. To me I have come this far and I want what I want. Nate at Porterbuilt was super accommodating in getting me new reworked bag plates. Full disclosure when trouble shooting this with Nate, he informed me that I installed the plates upside down. He took the blame as I never really had install directions. The new set of bag mounts did the trick (see the instructions provided....ha ha)
While I had the rearend out to cut off the old bag plates, I fixed my disc brake issue. If you recall my calipers hit my frame rail when fully aired out. so what I did was index the backing plate to place the calipers/brackets closer to the ground and clearing the notch. Other than making a slight clearance on the frame rails this corrected this challenge.
Ok some pics
Old 04-23-2017, 11:19 PM   #883
youngrodder
The next thing I shifted my attention to was to start mocking up the middle and rear seat for placement since my wheel tubs where welded in place. when I placed the middle seat I saw that the wheel tub in its new location and size limited how far back I could mount this seat. In an effort to maximize leg room for the middle seat, I cut away the wheel tub to clearance an area so the seat frame would not interfere. Then I needed to come up with a way to add metal back an try to make it look decent. I'm happy with how it turned out considering I don't have an English wheel to make it the right way.
Pics
Old 04-23-2017, 11:25 PM   #884
youngrodder
So on the rear seat if you recall I narrowed it already 3" to fit between the wheel tubs. I also removed the legs. While tying to fit this rear seat with the new tubs, the side supports of the seat hit the tubs. So I needed to cut them and move them slightly to clear. I wanted to retain the factory look. When I'm done I will be surprised if anyone will know the amount of work that I have put into the factory seat too fit and still look factory.
Pics
Old 04-23-2017, 11:30 PM   #885
youngrodder
Ok, here is the fruits of my labor. I welded in the new bag plates and after more cutting I was able to clearance more metal for wheel clearance.
I'm liking how it looks laid out flat...
Marc
Old 04-23-2017, 11:43 PM   #886
mongocanfly
Post Whore
mongocanfly's Avatar
Dang Marc..you have been busy..looking good as always...I wonder if Doug's been hiding in the bushes as well..
Old 04-24-2017, 08:52 AM   #887
lower50's
lower50's's Avatar
OH YA that looks great, lays out just right.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 04-24-2017, 09:41 AM   #888
99 to Life
99 to Life's Avatar
sweet. nice when them hurdles get cleared. at first they always seem so daunting. and really no need for fancy tools. I'v went years without even the most basic handy tools, so if I can do it anyone can. the seats look rad, makes me want one even more. Forget the family belair i'v been wanting to do, I want to do a family burb!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 04-24-2017, 10:00 AM   #889
oldman3
oldman3's Avatar
Marc, great work as always. Anyone with a burb will catch the change, most lookers won't...Jim
oldman3 is offline   Reply With Quote
Old 04-24-2017, 05:47 PM   #890
MIKESAD50
Marc, It is looking Awesome and making great progress.
Build it the way you want the first time.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 04-24-2017, 09:25 PM   #891
Advanced Design
Advanced Design's Avatar
Good work Marc, lots of cool and resourceful modifications!
Advanced Design is offline   Reply With Quote
Old 04-24-2017, 10:12 PM   #892
youngrodder
Thanks...I'm sure Doug is getting stuff done...
Thanks it has been a chore.
Yes, I have more confidence figuring stuff out as I go. This was not the case when I built the green 48.
Thanks Jim
Thanks. Yes, I am taking time on this one to figure out the little snags.
Thanks Doug...
Old 04-25-2017, 06:50 AM   #893
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Looks awesome layed out!
ChuckDriver is offline   Reply With Quote
Old 04-25-2017, 12:11 PM   #894
69CST-V
69CST-V's Avatar
Nice work....Looks like its coming together nicely.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 04-25-2017, 10:56 PM   #895
youngrodder
Thanks I like the look, I'm glad I went the extra mile.
Thanks, I will be happy when I'm done cutting the welding. I needed to clearance some frame rail for caliper clearance once fully aired out....2 steps forward.....3 back. Ha ha
Old 04-25-2017, 11:12 PM   #896
Scott2
Looks really great layed out! nice job going bit by bit until you got it right!
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 04-26-2017, 10:38 AM   #897
69CST-V
69CST-V's Avatar
Yes but they were big steps forward and only little steps back...Great progress.
Bryce
Company Trucks
Old 04-26-2017, 09:52 PM   #898
youngrodder
Thank you
Thanks man...
Old 04-27-2017, 02:54 AM   #899
BIGglaSS
BIGglaSS's Avatar
Those pics just put a laid out 'burb on my bucket list of builds.
BIGglaSS is offline   Reply With Quote
Old 04-27-2017, 03:36 PM   #900
youngrodder
Careful what you wish for.....it is a ton more work to layout a suburban over large diameter wheels while keeping decent seating inside. I found this out the hard way...ha ha
I'm just about done cutting. The cool thing is I can just put enough air in the bags to get it off the ground and it rolls nice and smooth. My 48 truck does not..
Marc
