04-05-2020, 01:13 PM | #926 |
Re: Project: Recycle
Clearance @ the a-arm/upper bag mount is about the same. Each side can be trimmed back as well but it appears it won't take much if necessary:
04-05-2020, 11:54 PM | #927 |
Nice work here sir. Precise.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
04-10-2020, 03:03 PM | #928 | |
Looks like I'll just remake my template & make them by hand like usual. Frustrating.
04-10-2020, 03:50 PM | #929 |
You have the patience required But I certainly understand that frustration...
04-11-2020, 11:50 AM | #930 |
Cant you run that cross shaft bolt from the outside? You’ll have some alignment shims there too.
04-13-2020, 02:17 PM | #931 |
chevy truck fan
very nice scotti,
so did you check the internals on that engine that N2TRUX gave you... I wouldn't be surprised if he pulled all the guts out!!…. !!! nice beginning on this ...I will try to follow along.... |
04-13-2020, 02:27 PM | #932 |
LoL…. He didn't mess w/anything on this one. I pulled it apart to correct the worn items & although there was significant carbon build-up on the pistons, it was about what you would expect for a 70k mile motor.
04-13-2020, 02:32 PM | #933 |
I guess I'll update quickly while I'm here & just edited the pics.
I got my brackets from the contractor @ my work that uses a guy that knows a guy.....
04-13-2020, 02:34 PM | #934 |
Quick test fit after I picked them up. They're cut from .250" material:
04-14-2020, 09:46 AM | #935 |
I'm just glad to be here!
Nice. Brackets look good.
Do you think you will have this truck at C10's in the Park later this year?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
04-14-2020, 10:45 AM | #936 | |
I know you know how it is when you're doing these builds on a tight budget. I am pushing forward & try to do something toward the build every day to keep my momentum. My goal is to get it finished how I want it vs. by a set date (which impacts decisions). Timelines don't seem to ever work how I want so I stopped focusing on them. Besides.... I wouldn't be able to get it in anyway & it would just be parked in some random spectator lot.
04-15-2020, 09:09 AM | #937 | |
04-15-2020, 09:37 AM | #938 | |
04-21-2020, 07:35 PM | #939 |
Got the e-mail w/tracking number info today from PB Fab. Arms are on their way as scheduled.
04-29-2020, 10:02 AM | #940 |
Porterbuilt narrowed arms mocked up in place to make sure the C/O's still clear despite the reduction of width. They clear.
I have the drivers side mocked up. The lowers fit w/o fuss. Once in place & secured w/the hardware (not final torque but enough to compress a split lock washer), the arm can easily be rotated up/down. The uppers have what I feel is an alignment issue between the shaft/bushings & the barrels they seat into. The bushings go into the barrels. The bushings slide over the shafts properly. But the alignment is off when assembling the combination of parts. I forced the driver side together to allow verifying I could still move forward. With the arm in place & no hardware to limit it's movement, they require a lot of force to pivot them up/down.
04-29-2020, 10:06 AM | #941 |
And here is what I need to correct w/the uppers....
04-29-2020, 05:05 PM | #942 |
Well that doesn't look right. Is Porterbuilt going to send you replacements?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
04-29-2020, 07:06 PM | #943 | |
I forced the driver side upper together so I could just do the physical mock-up. I staged the pass side upper just for pics to show a buddy which confirmed both upper arms if installed 'as is' will be in a bind. Two people I discussed the topic with (both owners of PB Delrin bushed arms) said there were assembly struggles & that the arms were hard to pivot but that everything worked out ok w/full vehicle weight. We have a thing in my group that's a regular TAG line for me: "ScotLuck". I'll be the one crossing fingers that "everything works ok" & won't get the same positive result. Or.... I expect more out of the sum total of parts I research & decide to use. I suppose when things don't work it makes me a PITA in situations like this (because of my expectations). My thoughts are that a quality Delrin bushed a-arm should be bind-free & easily pivot (not pivot like it's on needle bearings but pivot smoothly w/o any serious bind). After assembling the lower arm, installing it, & seeing/feeling how easily it pivots..... it TELLS me the uppers definitely are not alike. I've always had a good relationship w/Mr. P. so I'll get my ducks in a row & go from there. I'm going to disassemble the drivers side & get some measurements. I'm thinking maybe some tweaking in the hydraulic press can possibly align things better. Once I have some dimensions, I'll reach out to Nate & see what he thinks the best approach is for a positive outcome.
04-29-2020, 10:20 PM | #944 |
I think it would warp like that if the balljoint mount was welded to the arms after the pivots were welded on.
It should warp less if the balljoint plate is welded first, and then the pivots welded on after.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
04-29-2020, 11:52 PM | #945 | |
Just a curve in the road
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-30-2020 at 03:48 PM. |
04-30-2020, 08:31 PM | #946 |
Had a second set of eyes look @ the arms today for his thoughts. My co-worker has a machinist background so after I explained my issue/concern the first thing he did was grab a straight edge he uses on equipment @ the plant & checked alignment between the 2 bushing housings. They are not aligned. It does appear one end pulled away as a result of heat.
We then did some measuring on a 'special' machined-flat ceramic/granite block they use just for measuring. Shim stock indicated .115"; dial gauge was a little higher @ .131". The shim stock was slid under @ the center of the barrel; the dial gauge was close to the outer edge so the variance makes sense. I also brought another set of C10 upper arms (from a different manufacturer) that utilize Delrin bushings to compare pivot resistance @ the shaft for both sets. He agrees there is definite bind from misalignment. He confirmed we can probably tweak the arms so alignment is better between the 2 bushing barrels/housings. But, since tweaking them could also possibly damage them (doubtful but possible), I e-mailed PB to get their thoughts before I do anything.
04-30-2020, 10:53 PM | #947 |
Hydraulic press them back into alignment. Upper arms aren't that heavily stressed anyway.
04-30-2020, 11:30 PM | #948 | |
If anything goes wrong, I'm not eating the cost because I shouldn't have to mess w/correcting anything. I'm confident I can get things where they need but again just crossing my T's & dotting my I's.
05-03-2020, 02:36 PM | #949 |
Nate responded w/acknowledgement that he could see what I was talking about from my pictures. He asked me for some additional specific info & requested that I try tightening the partially assembled Driver side arm to spec since I only zapped it w/my cordless impact.
I torqued the Driver side arm from 100ftlbs up to 140ftlbs. While it did improve the alignment @ the bushing housings the rotational drag was still significant. I responded Friday w/the additional info & will see what the next step is once he replys.
05-04-2020, 05:51 PM | #950 |
I got a follow-up phone call today & will be moving forward. Based on measurements & numbers discussed, the amount the arm is off is related to some stretch from building & consistent w/what he's seen. Once torqued, the alignment is better. He say these arms do start off tighter than others by design but work fine w/the full truck weight.
I'm good w/moving forward. He offered to work w/me if I'm not ok w/things (as I get farther along w/the assembly). Nate is always great to work & talk with concerning this stuff.
