Old 12-04-2016, 06:28 PM   #951
oldman3
oldman3's Avatar
Re: My 50 roadster pickup build
Well, this really isn't with posting, but I got to use the shop for a few hours yesterday. I removed the inner fender, after removing the wiring for horn and cruise control.
Pic 1 shows the tire side of inner cleaned up.
Pic 2 shows the engine side of inner cleaned up.
Pic 3 shows were the fender was bent.
Pic 4 shows another view.
I plan on cutting this bent part off, and adding a new piece from the repop inner fender. Hope it will come out looking good.
oldman3 is offline   Reply With Quote
Old 12-04-2016, 06:38 PM   #952
oldman3
oldman3's Avatar
I spent the rest of my time cleaning up the frame and front suspension.
Pic 1 Before shot
Pic 2 and 3 after shot.
The paint has really held up good, for the past 12 years and 25,000 miles.
Till next time...Jim
Old 12-04-2016, 06:49 PM   #953
Advanced Design
Advanced Design's Avatar
Truck cleaned up well Jim. Anticipate when you finish sectioning the inner fender no one will be able to tell.
Advanced Design is offline   Reply With Quote
Old 12-04-2016, 08:40 PM   #954
DeanTX
DeanTX's Avatar
Looks like new. Can't believe it has 25000 miles on it. My trucks get dirtier than that after a couple of months sitting in the shop.
DeanTX is offline   Reply With Quote
Old 12-04-2016, 11:45 PM   #955
oldman3
oldman3's Avatar
Thanks Doug, thats what I'm hoping for, I'll let Mark do the welding, and I do the finish work...Jim
Old 12-04-2016, 11:47 PM   #956
oldman3
oldman3's Avatar
Thanks DeanTX, I used good primers and paint, it has paid off in the long run...Jim
Old 12-05-2016, 01:18 PM   #957
RockinKees
RockinKees's Avatar
Looks great after so many years of use Jim!
It will look fabulous when it's ready again!!
Nice repairs so far.
Keep it going
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 12-05-2016, 06:05 PM   #958
oldman3
oldman3's Avatar
Keep it going
Thanks Kees, appreciate you checking it out...Jim
Old 12-06-2016, 03:04 PM   #959
Indian113
Indian113's Avatar
Jim, Thanks for keeping us in the loop. Can't wait to see that Good Looking Rod back on the STREET!
Indian113 is offline   Reply With Quote
Old 12-06-2016, 08:35 PM   #960
oldman3
oldman3's Avatar
Thanks Ray. Waiting for parts to come in, and then wait for some room in the shop...Jim
Old 12-06-2016, 08:50 PM   #961
Indian113
Indian113's Avatar
Shop room is a Premium for your Son. You may have to build another shop
Old 01-05-2017, 12:14 AM   #962
oldman3
oldman3's Avatar
Well people the reason for no update on my truck, is I've been busy painting in the house. Plus I have agreed to help a friend install a Lokar shifter and indicator; and FiTech efi; and cruise control on his 71 Olds Cutlass. There are a few electrical things that also need attention. Plus I've been changing over my florescent tubes to LED tubes. I did a right up on what I had to do, if you want to check it out, heres the link; http://67-72chevytrucks.com/vboard/s...d.php?t=726577 I will get started on mine soon I promise...Jim
Old 01-05-2017, 12:42 AM   #963
Henry50
Henry50's Avatar
What paint and primer did you originally use on the truck?
Henry50 is offline   Reply With Quote
Old 01-05-2017, 05:12 AM   #964
RockinKees
RockinKees's Avatar
Well Jim, we are in off-season so take your time
I read your light change in your shop.
Good write up, Thanks!!
Cheers!! Kees.
Kool Guyz CC
Old 01-05-2017, 11:12 AM   #965
oldman3
oldman3's Avatar
All my paint products were PPG. Epoxy primer, high build primer, and sealable primer. Top coat is single stage Acrylic Urethane, no clear...Jim
Old 01-05-2017, 11:13 AM   #966
oldman3
oldman3's Avatar
Thanks Kees for checking it out...Jim
Old 01-05-2017, 11:49 AM   #967
lv2tri2
Thumbs up Re: My 50 roadster pickup build
Jim, I read your LED conversion, well done. I'm tired of failed lighting and will convert about 15 fixtures. Thanks.
lv2tri2 is offline   Reply With Quote
Old 01-05-2017, 04:17 PM   #968
oldman3
oldman3's Avatar
Glad I could help...Jim
Old 01-05-2017, 09:29 PM   #969
strider621
strider621's Avatar
Your truck is still looking great after the 25,000 miles Jim. I just hope mine will look as good when I reach that many. Looking forward to seeing you get it back together.
Keith
strider621 is offline   Reply With Quote
Old 01-06-2017, 12:15 AM   #970
oldman3
oldman3's Avatar
Keith, thank you, I appreciate the kind words. Hope to get started on it soon...Jim
Old 01-06-2017, 02:36 AM   #971
joedoh
joedoh's Avatar
looking good, hope you are ready for the spring and some cruisin!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 01-06-2017, 10:56 AM   #972
oldman3
oldman3's Avatar
You and me both, should not be a problem, but.....Jim
Old 01-06-2017, 08:39 PM   #973
oldman3
oldman3's Avatar
Well, was finally able to get out to the shop for a little work on the inner fender.
Pic 1 Thought about cutting in the bend for more strength and less warping, but Mark pointed out that the fender was also tweaked behind the fender brace, so I cut it back farther where it was OK.
Old 01-06-2017, 08:41 PM   #974
oldman3
oldman3's Avatar
Pic 1 New inner fender, marked for cutting back farther, so it can be trimmed to fit the old inner.
Pic 2 Have a good 3/4 section of left inner fender.
Old 01-06-2017, 08:46 PM   #975
oldman3
oldman3's Avatar
Dummy forgot the pics
