Old 06-26-2008, 01:31 AM   #76
PBFAB.COM
PBFAB.COM's Avatar
Re: Dropmember Rear 63-72 Spy Pic
Originally Posted by RunninLo View Post
I don't have any trouble setting pinion angle myself but, Will there be some sort of locator once the old perches are removed or will this be a get out the measurin' stick and angle finder type of set-up?
just curious cause the magnet on my angle guage fell off and broke the guage so I'll get another if need.
Josh
Just eyeball it and get it close!
Yes, protractor and tape measure will NOT be optional!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 06-26-2008, 01:46 AM   #77
jasonb72
PorterBuilt Man Crush
ALL I CAN SAY IS
There will be a party in my garage when it get's installed.
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 06-26-2008, 01:49 AM   #78
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
From the looks of things that Porterbuilt 100% natural 2x4 yoke shim is all I'll need. just go ahead and toss that into the box when you ship!
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 06-26-2008, 02:02 AM   #79
PBFAB.COM
PBFAB.COM's Avatar
Be careful what you ask for!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-26-2008, 09:39 AM   #80
gringoloco
A guy with a truck
gringoloco's Avatar
Gangster! When does production start? I need to know when to start selling spare organs...
How tall is the notch externally- i.e; how far will the bed floor need to be raised?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-26-2008, 10:55 AM   #81
jlaird
jlaird's Avatar
so freakin cool!
jlaird is offline   Reply With Quote
Old 06-26-2008, 10:59 AM   #82
PBFAB.COM
PBFAB.COM's Avatar
The highest point of the assembly measures 12.5" taller than the top of the factory frame-rail at the axle centerline. It is definitely a beast.
Also, the front four-link mounts and upper link bar will require bed floor clearancing.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-26-2008, 11:07 AM   #83
gringoloco
A guy with a truck
gringoloco's Avatar
How 'bout a shot of the carrier bearing crossmember?
-Chris
Old 06-30-2008, 03:00 AM   #84
RunninLo
RunninLo's Avatar
while you're at it those pics of the front DM upper shock mounts never materialized yet either.
Josh
88 4x4 crew DD
Old 06-30-2008, 03:04 AM   #85
Primer70
Superbad
Primer70's Avatar
The kit looks bad ass. My only dislike is mounting the bags over the axle, rides too rough. Making a rear mounted lift bar set up with the bags mounted half way down the bars would make a lot smother ride, just my thoughts.
Primer70 is offline   Reply With Quote
Old 06-30-2008, 09:19 AM   #86
azfab
azfab's Avatar
porter what do you guys offer for the rear of and 86? thanx
azfab is offline   Reply With Quote
Old 06-30-2008, 02:51 PM   #87
98L150
///Relaxed Atmosphere
98L150's Avatar
azfab,
the answer to you question in inthe attached link.
http://67-72chevytrucks.com/vboard/s...ght=dropmember
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
Old 06-30-2008, 03:36 PM   #88
PBFAB.COM
PBFAB.COM's Avatar
I have heard this rumor of "rough ride" with the bags mounted over the axle.... I have never had this experience, and have been mounting sleeved bags like this since I first got started. I prefer a rolling sleeve over a double convoluted on the rear hands down. There are pros and cons to both, but in my experience, ride quality is not a con for mounting a sleeved bag over the axle.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-01-2008, 02:37 AM   #89
Chevysdominate
Chevysdominate's Avatar
Why do you prefer a sleeve bag over a convoluted bag in the rear? Ride quality?
Chevysdominate is offline   Reply With Quote
Old 07-01-2008, 10:53 AM   #90
fastbagged68
fastbagged68's Avatar
Sleeve bags ride good in a 1:1 ratio, better then double convulated bags. But they can only be ran 1:1. The problem with them is you can not let them over extended themselves. You either need to run limit straps or use your shocks as the limiters. This is no problem if you know what you are doing. Another issue with the sleeve bag is the most popular one is an F9000. The travel on that bag is only 7.5". So if you set your car up to layout when the bag is deflated, then your ride height should be about 3-3/4" off the ground. Some might not like it that low. Also your ride will only get 7.5" off the ground then, if your laid out
fastbagged68 is offline   Reply With Quote
Old 07-01-2008, 01:56 PM   #91
PBFAB.COM
PBFAB.COM's Avatar
The sleeve bag displaces the air as it compreses, while a double convoluted bag compresses the air. This gives the rolling sleeve an advantage on ride quality in my opinion. The cons are travel limitations, and the fact that a sleeved bag will tear itself apart if not properly limited (by shocks or straps... just as fastbagged stated). We asre getting just under 8" of travel on our rear kits, and the ride quality is exceptional.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-02-2008, 10:56 PM   #92
DA INFERNO
DA INFERNO's Avatar
X2 I would like to see the above stated set up for 2 reasons, ride quality and for suspension travel. (More then 8") Any chance of a non "over the axle" set up.
1964 CHEVY LB, 20" WHEELS, BAGGED
DA INFERNO is offline   Reply With Quote
Old 07-03-2008, 01:04 AM   #93
PBFAB.COM
PBFAB.COM's Avatar
I have no current plans of altering the design from the current over-the-axle to a levered double convoluted. This current set-up is my preference,and is the way I would do it on my personal vehicle (if I had the time to put one together... soon.) The travel isn't a big issue to me either, the Dropmember front gets the same amount... so their would be no reason for the rear to get more lift.
I do however, understand that others tastes/preferences/opinions will not all be the same as mine. I will be offering the notch seperately so those who would wish to change it up a bit could do so.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-03-2008, 11:28 AM   #94
DA INFERNO
DA INFERNO's Avatar
Thank you.
Old 07-05-2008, 08:48 AM   #95
chevy6guy9
any idea on cost of rear setup yet?. id be interested in it ya have one. also can the insert sections of the step notch area be welded in plates instead of bolted incovers?. think it might look a cleaner if your having to weld brackets anyway. thanks
chevy6guy9 is offline   Reply With Quote
Old 07-15-2008, 07:25 PM   #96
jkade
jkade's Avatar
All I can say is some dang fine work you have done there!!!!! You will sell the crap out of these I am sure.
jkade is offline   Reply With Quote
Old 07-27-2008, 09:29 AM   #97
yesman
as always your work is amazing
yesman is offline   Reply With Quote
Old 07-28-2008, 05:33 PM   #98
Project SIKty-5
Project SIKty-5's Avatar
Hey Da Inferno, do you work over off of Cherry/Jensen by any chance??
Project SIKty-5 is offline   Reply With Quote
Old 07-28-2008, 06:44 PM   #99
DA INFERNO
DA INFERNO's Avatar
I have worked over there in the past but that is not my normal place.
Old 08-04-2008, 05:25 PM   #100
Project SIKty-5
I thought i've seen your truck over there before....with the rear dumped and the front aired up
