Old 03-16-2010, 02:06 PM   #76
WillieloRidez
WillieloRidez's Avatar
Re: Buildin my 88 Crew Cab long bed AKA STRETCH!
The ones i bought are c-56s gun metal. And the clearence issue is with the 3inch drop spindles and a coil and a half cut. The bottom of the wheel is hitting the lower a-arm when ever you turn. Hopefully the 18s will solve that problem
WillieloRidez Drive em in Drag em out!
Projects:
1956 Chevrolet 210 2dr post
58 chevrolet 2dr delray
58 chevrolet belair 4dr hardtop
1965 Chevelle big block 4spd
88 crewcab 1/2 ton long bed aka STRETCH Lt1-4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=388445
WillieloRidez is offline   Reply With Quote
Old 03-16-2010, 02:33 PM   #77
lolife99
67-72 parts collector,…
lolife99's Avatar
What's the backspacing on the wheels that have the clearance problem?
Anything over 4" will give you problems.
Your 3" spindle and 1-1/2 coil removed putrs the front around a 6" drop. That alot!
How close are the a-arm u-bolts to the ground?
Keith
Convert to disc brakes.
Old 03-16-2010, 03:36 PM   #78
Tow Me
Glen
Tow Me's Avatar
I wonder if that only for the 3" spindle. I have 2.5" spindle and airbags and I don't have those issues. have ran 15s, 18s and 20s. I did have grind a little off on the lower a-arm with the 15s. Hope that 18s do the trick... should look nice too!
Glen Simpson
Severed Ties - Oregon
Roseburg, Oregon
  • 1983 Chevrolet C10 - Ginger
    Photos
Past Trucks
Tow Me is offline   Reply With Quote
Old 03-16-2010, 10:08 PM   #79
WillieloRidez
I dont know what the backspacing is without measuring its probably more than 4 inches and The a-arm bolts are about 3inches off the ground. It looks sweet and seems to have plenty of travel im sure it will have the normal square body a arms dragging though. Im hoping the 18s will clear it too cant wait to get them!!
Projects:
Old 03-16-2010, 10:12 PM   #80
slammed longbed84
This is not ad space
slammed longbed84's Avatar
Kool, hey billie thats my ol truck i sold it to jim!! Good luck with it
slammed longbed84 is offline   Reply With Quote
Old 03-18-2010, 10:52 AM   #81
p_rubottom
p_rubottom's Avatar
Where you at on this Willie? Still sitting with that rear end "mocking up"? How are you going to replace the c notch for the half ton location?? Im with Larry GOOD LUCK!
p_rubottom is offline   Reply With Quote
Old 03-18-2010, 12:26 PM   #82
WillieloRidez
I should hopefully have the rearend bolted in and the truck sitting on the ground either tonight or tomorrow so i can set the pinion angle and shock mounts then tack everything depending on what my girl has planned lol. As far as the c-knotch being located wrong im toying with the idea of making it a shortbed with another rear frame section and z'ing the rear frame and taking the bed off my body dropped truck for it. Thats just in contiplating mode though right now. I would of been nice if the c knotch would of been located in the right place before hand lol. Tours looks good now that its lowered being a shortbed so i dont know
Projects:
Old 03-18-2010, 06:20 PM   #83
WillieloRidez
Had a present when i got home!!! The wheels have arrived and even better looking in person
Projects:
Old 03-19-2010, 07:40 PM   #84
WillieloRidez
Well here is an update. I got the wheels and tires on it and the truck sitting on the ground. Now i can build shock mounts and set the pinion angle. After that back apart she comes for final welding and paint.
Also my clearence issues are fixed up front
Projects:
Old 03-20-2010, 06:32 PM   #85
bharrison1
bharrison1's Avatar
Lovin the wheels!!I personally hope it stays a longbed but im partial to longbeds!!
bharrison1 is offline   Reply With Quote
Old 03-20-2010, 06:33 PM   #86
slammed longbed84
lookin good
Old 03-22-2010, 10:12 AM   #87
WillieloRidez
Projects:
Old 03-23-2010, 09:59 PM   #88
WillieloRidez
Well here is a picture of it finally done Enjoy
Projects:
Old 03-24-2010, 10:56 AM   #89
bharrison1
bharrison1's Avatar
Old 03-24-2010, 12:47 PM   #90
p_rubottom
p_rubottom's Avatar
Short bed that thing!!
it does look good though.
Old 03-24-2010, 03:34 PM   #91
GODFATHER
Kansass Fire Starter!
GODFATHER's Avatar
Shoulda kept the 20's.... Only way your going to get as low as you want and still drive is to put the 20's back on and bag it....
GODFATHER is offline   Reply With Quote
Old 03-24-2010, 03:50 PM   #92
tswore
built not bought
tswore's Avatar
Great lookin truck! CUT IT!!!!!
MY BUILD THREAD "project: what you doin that for?"
http://67-72chevytrucks.com/vboard/s...d.php?t=382503
tswore is offline   Reply With Quote
Old 03-24-2010, 04:23 PM   #93
GODFATHER
GODFATHER's Avatar
looks better outside will say that. The inside pic looked like that front wheel was just way too small.... Im not a fan of the staggered look either but looks aaaaaaaaaaaight
Old 03-25-2010, 10:02 AM   #94
bharrison1
bharrison1's Avatar
Ha Ha wow haten like its got a Batman painted on the front !!
Old 03-25-2010, 10:04 AM   #95
WillieloRidez
If i could of fit 20s on the front with static drop i would of put 20s on the front and 22s on the back. I am not wanting this truck bagged i want it to tow bagged ****! lol It rides and drives good the way it is now. I think i might be able to clear 20s with a low pro tire but then you sacrifice ride. Ill drive it like this for a while and see if i like it. I am with you though 18s look to small on this big of a truck
Projects:
Old 03-25-2010, 10:26 AM   #96
GODFATHER
GODFATHER's Avatar
Yeah and 18's aint small by any bit of the imagination LOL!!!! Did you find out about that stuff from your junk yard buddy. I should have the money this weekend if he still has the stuff. I might even get the a-arms if they are dropped ones....
Old 03-25-2010, 12:30 PM   #97
WillieloRidez
What all are you needing besides the control arms?
Projects:
Old 03-25-2010, 01:13 PM   #98
GODFATHER
GODFATHER's Avatar
Spindles
Old 03-25-2010, 04:56 PM   #99
justpball
justpball's Avatar
Looks killer! i am running 18s and 20s as well, but I am bagged, and its a burb.
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 03-26-2010, 08:41 AM   #100
WillieloRidez
That burb looks sweet man you dont see them very often on the ground around here. Props!
Projects:
