Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 11-04-2010, 05:21 PM   #76
Fat Mike
Fat Mike's Avatar
Re: butt fit butt welded marker lamp install....
Looks outstanding. Hope you can possibly take a picture of the backside. (behind it in the fender wheel to see the pentration). What gauge of metal is that?
Fat Mike is offline   Reply With Quote
Old 11-04-2010, 07:41 PM   #77
greystoke
very neat and clean, I'm sure that really helps with the finishing process. Great job Earl
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline   Reply With Quote
Old 11-04-2010, 08:15 PM   #78
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Originally Posted by ebfabman View Post
No gap needed for penetration. We are welding sheetmetal. Try this, run a small short tack on a piece of scrap. Turn it over and look at it. Did the weld penetrate? How much penetration do you need on thin sheetmetal body panels?
Please don't take me to try to be a smart azz, I don't want to come across that way. I see a lot of guys sort of being lead by by what they're told or what they read and not putting the thought and time in on really how they can improve.
If you read the description of what those little panel camps do, they always say "so and so" gap for good penetration.....well if there is gap and you're filling that gap with weld, you aren't "penetrating" right? I mean, yes you will need some "penetration" to fuse the material together but worry about penetration when you are welding structural stuff and don't worry so much about what it looks like.
Lets stay focused on sheetmetal. I think you should strive for "appearance" as well as a good solid joint. I feel like if you try to concentrate on keeping your work very neat and clean it also helps to control the movement of the panels as you weld. Remember that when you weld the heat expands things, when it cools it contracts but the contraction is more than the expansion. So if there is a gap, you weld across it, with the contraction won't the gap get smaller? If we are concerned with appearance then we will have to deal with the shrinking gap.
Anyway, I'm no expert. I don't even know any metallurgy guys. I do what works for me. I worry about what things look like as well as how they perform. I want to be the best I can be, so I don't care so much what others say. I will continue to refine my skill so that my goals are meant then set new ones.
Please keep practicing and keep trying different things. Set goals. Always work toward getting better and don't compromise.
I am here if any of you need help, but just remember I can only tell you what works for me.
Again, thanks for looking. I will be putting more pics on here as I get things done.....eb
Good info and well said. I'm one of those that was taught to leave a gap the thickness of the metal. At times that doesn't always happen. Being in the collision repair for about 15 years, I haven't taken much time to learn metal finishing. I play with it at times, but the insurance companies just want the work pumped out. My skills are better than most, but I definately have a ways to go to reach your caliber. Keep up the awesome work. I'll be paying more attention to your post.
Alan's Classic is offline   Reply With Quote
Old 11-05-2010, 03:43 PM   #79
ebfabman
Here is what it looks like when its ground down. I have to move some things out of the way to get inside shots but I will get some.
ebfabman is offline   Reply With Quote
Old 11-05-2010, 03:45 PM   #80
ebfabman
sorry here.
Old 11-05-2010, 03:55 PM   #81
my67chevytruck
Under Construction
my67chevytruck's Avatar
nice work Earl
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 11-05-2010, 05:30 PM   #82
67cheby
67cheby
67cheby's Avatar
beautiful work
67cheby is offline   Reply With Quote
Old 11-05-2010, 06:44 PM   #83
Fat Mike
Fat Mike's Avatar
You are definetly one of the best patch panel men around that I have seen. Your attention to detail is outstanding!
Old 11-05-2010, 07:49 PM   #84
primrrd
primrrd's Avatar
eb, this is beautiful stuff.
I aspire to your caliber of work, but am only OK with a welder, excellent with a grinder and hurry up and put a skim coat on it....(:
On your hobart are you gas shielded?
What are your thoughts on flux core wire welders. I've never used one!
Are they:
- ok, just not as good as a gas shielded welder,
- or are they run away and never look back?
In a fit of desperation I sold my beautiful miller 240 mig years ago and now need another welder.
primrrd is offline   Reply With Quote
Old 11-05-2010, 08:22 PM   #85
ebfabman
The mig I use here is a lincoln with a mix shield gas of CO2/argon. I would not try to use flux core wire. The miller would be a good welder. Skim coats are not bad but there are instances where its not needed. I like to make repairs where there is no filler if possible.
Old 11-05-2010, 08:36 PM   #86
lakeroadster
We are not worthy! I love this thread.
lakeroadster is offline   Reply With Quote
Old 11-05-2010, 08:42 PM   #87
kev2809
low n' slo
kev2809's Avatar
amazing, could never guess there was metal work done there. how much time does it usually take to completely tack around that area? i feel like i rush mine too much which is causing a little warpage
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 11-05-2010, 09:12 PM   #88
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice work as always Earl! You definitely have this down pat!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-09-2010, 01:22 AM   #89
denny5625
denny5625's Avatar
Great work. The best I've seen.
66 el Camino
70 1/2 RS Z-28
71 C10 2wd
72 2 wd Blazer
(2) 72 4 x 4 Blazers
88 24' Mirage 70 mph+
08 Harley Night Train
08 Silverado 4d 4 x 4
denny5625 is offline   Reply With Quote
Old 11-09-2010, 06:29 PM   #90
bad6772
Official Site Guitar Shredder
bad6772's Avatar
awesome Job
bad6772 is offline   Reply With Quote
Old 11-09-2010, 10:29 PM   #91
ebfabman
Thanks guys. Always trying to get better. Not able to do as much bodywork as I'd like because the shop I've been building for the last year needs finished before the winter weather starts. Looking forward to getting to the point where I can really concentrate on metalworking as much as possible. I very much appreciate smitty letting work on his burb, it will be straight and solid.
Old 11-09-2010, 11:10 PM   #92
gcburdic
Restoration Virgin!
gcburdic's Avatar
Come on Earl....get that building insulated....must have more metal work seminars!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 11-10-2010, 03:10 AM   #93
71gmcburb
71gmcburb's Avatar
man you do beautiful work! if i get 1/3 as good as you I'd be happy gonna have to try that butt welding trick out
a wise man once said "There are only two real rules to life...
1 - Don't sweat the small stuff
2 - Everything is small stuff
71gmcburb is offline   Reply With Quote
Old 12-19-2010, 11:12 PM   #94
ebfabman
trying to get the shop insulated now......its ccccold outside........
Old 12-19-2010, 11:42 PM   #95
craazy22
craazy22's Avatar
man earl... just read the thread and all i can say is WOW.... wish i was near your hometown to help insulate and get on with the metalwork...lol
81 chevy stepside 6.0/t56 swap in progress....
81 chevy silverado k5 2wd 350 tpi and 700r4.. SOLD
07 chevy colorado "work truck" SOLD
02 chevy silverado z71 off road package
craazy22 is offline   Reply With Quote
Old 12-20-2010, 10:08 AM   #96
gcburdic
Restoration Virgin!
gcburdic's Avatar
You said you were gonna do that months ago...come on Earl!!!
Geoff with a G
Old 12-21-2010, 05:03 PM   #97
onequickchevy
onequickchevy's Avatar
All I can say is WOW! You are truly a craftsman, and I can honestly say that I learned alot just by seeing you technique. Thank you for sharing you knowledge with all of us.
Slowly but surely getting it done.
onequickchevy is offline   Reply With Quote
Old 12-22-2010, 12:37 AM   #98
swamp rat
swamp rat's Avatar
>>>You said you were gonna do that months ago...come on Earl!!! <<<
Now come on there, don't try to distract Earl from getting out the christmas orders he's recived for his metal repair CD.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-22-2010, 04:00 AM   #99
skoffice
skoffice's Avatar
WOW. This is inspirational. Now I feel like I have let my truck down with my horrible sheet metal work BEAUTIFUL!!!
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 12-22-2010, 09:12 AM   #100
ebfabman
^^^ha ha ha........hey its just sheetmetal.....you can always hack it off and melt some more on
butt weld butt welding, metal finishing
