Old 08-31-2018, 03:03 PM   #76
RADustin
Re: 1976 CCSB Duramax Project #trucknamedsue
Originally Posted by Low Elco View Post
Fantastic update! I love this build.
stay tuned, more to come!
1949 Chevy 3100 P/U
http://67-72chevytrucks.com/vboard/s...d.php?t=302780
1976 GMC Sierra Classic C35 CCSB
http://67-72chevytrucks.com/vboard/s...25#post8188825
RADustin is offline   Reply With Quote
Old 08-31-2018, 03:26 PM   #77
RADustin
Time for a update! Way over due as usual!
Finished up some final suspension/frame pieces.
first up was a little spreader bar between the 4-link mounts.
then I worked on the spare tire carrier and rear frame supports. I wanted to tie the hitch in well, and have a spare tire winch. I designed around the 2014 donor truck winch.
finally found the set of wheels I've been looking for. 20x10 Weld Racing Cheyenne wheels. in 8 on 170 pattern. I will convert the rear to work, front will remain stock. This is due to the rear hubs being a non-wear item but the front unit bearings are. I just peaked in the wheel boxes and put them in storage.
finished out front crossmember and steering box supports. This will give me a ton more lower radiator clearance and be stronger than the OEM piece. It also integrates and shares a bolt with the sway bar mounts.
notched the tie bar in the front to clear the master.
then I started the massive journey of the exhaust and hangers and such. I did a 3" out the turbo and merged to 4" along side the transmission. 20" magnaflow muffler and a 5" dual wall tip. The dual wall tip is not just for looks but also so the tip doesn't drone and magnify the exhaust note. I don't want a loud truck, but some good sound should be nice. Used all the rubber hangers from the donor truck to hold the exhaust firm in place, but let it live.
started at the front using a stainless ebay downpipe. Cut off the 9th injector bung and fabricated a new lower downpipe mount since I rotated the downpipe in from factory position. also cut off the factory bubble flange.
making my way rearward-
welding out-
bent up a front hanger-
hung muffler up tight-
exhaust hanger bent up-
exhaust hanger on the muffler, ready for welding
hung
final rear section over the axle-
welding out the rear-
rear hanger
1949 Chevy 3100 P/U
Old 08-31-2018, 03:41 PM   #78
RADustin
The steering column finally came in. Beware ordering from IDIDIT. It will take WEEEEKS. but it does look nice when it comes in.
planning out my steering wheel angle sensor-
got the brake position sensor mounted in. studied the stock setup from the 2014 and mimicked it.
machined a pin for the brake arm.
welded to a plate to bolt to the arm.
everything fit up-
welded-
in the truck, clears the column and brake arm well.
and it works-
then I started working on the front fenders. I wanted to knock out some body work to keep it from piling up at the end.
I decided it was best to pull the fenders apart and take the skins off. Then I can fully blast and prime every surface and fix all the damage much easier.
separated-
nasty inside, and lots of damage.
fixed-
inside of the inner/outer, primed and blacked out with weld thru on the edges.
back together- took about 3 hrs to take apart, 3 hours to put back together, about 2 hours to fix all the damage plus blast and prime work. So no small feat.
I'm currently working on the passenger fender. Got it ripped apart and ready for blasting. And I'll be working on body work for the drivers.
Hope yall enjoy
1949 Chevy 3100 P/U
Old 08-31-2018, 06:08 PM   #79
SBTork
Garage wrench
SBTork's Avatar
I really like your exhaust work and usage of oem type hangers. Phenomenal work!
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 08-31-2018, 07:36 PM   #80
Devilman
Oh man soooooo much awesome fab work!!! Please hurry up and get done so you can build replica parts for me!! LOL but seriously
Devilman is offline   Reply With Quote
Old 09-01-2018, 10:19 AM   #81
LT7A
Man. So methodical and precise. But great progress as well. Thank you for taking pictures in little steps along the way and posting them.
Old 09-04-2018, 09:07 AM   #82
RADustin
thanks! yeah I really think the OEM hangers are the best available. I cut all the forged stems off the frame as well before it was scrapped, so I could use them. Worked well.
I'm rolling just about as fast as I can. I'm long ready for this truck to be on the road.
yep- I have more pictures than I post as well. Let me know if you want to see something in more detail.
This truck was on the drawing board for a long time before any metal was cut. I think that's one reason for steady progress. I never go to work on it and sit and scratch my head- its usually already planned and I just have to do it. I keep my planning and part ordering about 2wks ahead of my actual progress.
1949 Chevy 3100 P/U
Old 09-05-2018, 05:53 PM   #83
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice work! There are many, many hours in these pics! The exhaust turned out awesome! You have some skills sir!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 09-06-2018, 10:14 AM   #84
RADustin
thanks! it is crazy how a single picture can represent so much effort.
BTW- I'm still working on getting the picture sizes to work correct. photobucket was so easy but since their screw ups I been trying to use imgur.
1949 Chevy 3100 P/U
Old 09-06-2018, 01:50 PM   #85
BIGglaSS
BIGglaSS's Avatar
Nice work on the exhaust!
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30
BIGglaSS is offline   Reply With Quote
Old 09-10-2018, 01:04 PM   #86
daddyjeep
daddyjeep's Avatar
I think your picture size is just fine.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 09-10-2018, 01:07 PM   #87
Dads79GMC
Dads79GMC's Avatar
Awesome build!!!
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 09-21-2018, 02:42 PM   #88
RADustin
thanks guys. I figure I'm due for an update.
got the fender body worked and shot in poly primer, followed by blocking it back out and getting it shot in some urethane.
sent a couple days getting the bed straighter than it was, blocked out and primed twice more. It now awaits final block and paint.
got the gooseneck holes cut. it was hard to cut into a perfect bedfloor.
front brake lines came in from crowne. They are stainless but I had them covered in a black rubber slip. That way they aren't too bling bling.
then I started working on the column. First order of business was to move the mounts up 1-7/8" to shorten it.
where I started-
housing marked with tape and cut
I cut off one mount at a time, welded up any cut-off tool grooves and ground back flat, then used the stock mounting bracket to realign the mount 1-7/8" forward.
eventually got both moved up forward.
I've been working on the steering wheel angle sensor for a while now.
this is the general idea. to split the column tube to house the sensor.
sent the housings out to get made. they are cut from stainless.
the machine that cut them . a 5axis dmg mori.
sensor fitted in housings
I had models 3d printed that are split in half so I can slip around the OD of the column to find the best spot for the sensor.
I can tuck it right in up top in the dash. so it should be unnoticeable.
with the location figured I got the model built out will all the lengths figured.
cut the column housing. also hard to do, these things aren't cheap.
and cut the lower column shaft. and weld preped it for a full-pen. I will machine a slug to go on the inside to line everything up and add in some plug welds.
getting the sensor fitted to the column housing. used the big lathe and a dial indicator to set run out.
also worked on the sensor key in the bridgeport. This piece will key the sensor to the steering column shaft.
for the turn signal I am using late model GM parts to gain the 7 position wipers and cruise control. I bought a few stalks and figured out how to take them apart with breaking them. Then I measured up the OEM parts and redrew them to interface with the IDIDIT column. printed some test parts out of ABS.
here is the stock stalk and the one I made with the pieces on the end. I will have the final one professionally printed.
that's about where I'm at right now. Have some more work on the column then I'll prime the housings and put it all back together. Getting closer to knocking out some of these smaller projects and then it'll be time to paint the frame and all the components.
1949 Chevy 3100 P/U
Old 09-21-2018, 05:19 PM   #89
Ofnaman1
Incredible work!
Ofnaman1 is offline   Reply With Quote
Old 09-24-2018, 09:53 AM   #90
aggie91
I'm just glad to be here!
aggie91's Avatar
Wow, just WOW...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 09-24-2018, 01:20 PM   #91
Low Elco
Daaaaaannnnnng! That's some high end stuff! This is gonna be cool.
Low Elco is offline   Reply With Quote
Old 09-24-2018, 02:30 PM   #92
83GMCK2500
I can't tell you how great it is to catch updates here and on IG. Someday I hope to be able to put this much time & detail into a build. Great work!
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 09-25-2018, 12:19 PM   #93
daddyjeep
daddyjeep's Avatar
Steering wheel position sensor... in a square body. I assume that you are going to adapt all of the ABS stuff and even ESC?
04 1500 crew cab
Old 09-25-2018, 01:25 PM   #94
RADustin
Originally Posted by Ofnaman1 View Post
Incredible work!
Originally Posted by aggie91 View Post
Wow, just WOW...
Thanks guys! It's yalls support that keeps me moving.
yes I am keeping all the GMT900 BCM, EBCM and the pitch/yaw sensor. So the truck will have ABS, stabilitrak, integrated trailer brakes with trailer sway control and anything else a 2014 has. I will be keeping onstar as well and using the newer style rearview mirror with backup camera in the glass.
One of the reasons I chose the LML duramax was the body electronics side of things. I could have much easier and cheaper used the LBZ but the older ABS was crap compared to the GMT900 LML.
This truck I'm building will have all the safety features a new truck has minus airbags and restraints control. The goal is to stuff all this new technology under the cover of the '76. I want the dash to remain as stock appearing as I can. This is why I worked to hide the wheel angle sensor, and the brake position sensor. If the average person doesn't notice anything out of place, that would be perfect.
If later I feel like drilling the bumpers for the sonar systems I can custom flash the BCM and do adaptive cruise like the tahoes have. That would be pretty cool as well.
1949 Chevy 3100 P/U
Old 09-25-2018, 02:05 PM   #95
83GMCK2500
With your desire to have a stock looking interior will you be painting/coating that shiny steering column? What was the reasoning behind using that aftermarket column as opposed to a late square column with the wiper controls on the lever?
What are you doing for the dash bezel with regard to wiper switch hole?
Devin
New Daily, the '96
Old 09-25-2018, 02:28 PM   #96
RADustin
yes I'm either painting the column black like factory or maybe an alternative interior color.
The factory column is made of pot metal and not easily modified. I needed the aftermarket column so I had materials that can be cut, welded, modified, etc. I also wanted to start with new parts. The IDIDIT is based on 70s-80s technology/design anyways, so its a 1 for 1 swap.
I'm using the late model turn signal stalk for several reasons. First it gives me cruise control that will interface my BCM, as they are resistor ladder. They aren't discrete switches. The wiper controls are on the stalk as well, which again will work with the LML BCM and the LML wiper motor, which I also will be using.
The previous location in the dash for the wiper switch will probably become the integrated trailer brake controller, which can look very similar at first glance.
1949 Chevy 3100 P/U
Old 09-25-2018, 03:15 PM   #97
83GMCK2500
I love heavily modified builds that look as OEM as possible, I figured the column would be black...but now that you mention a custom interior color I dig it.
Makes sense, I haven't looked into or seen anyone analyze the materials used in the earlier columns.
The electronic needs make sense. In the original GMT900 column was high beam push forward on the lever with a momentary pull back to flash? It's been a while since I was in a 900, I don't think my dad's '11 is but I can't remember.
Oh, the ITBC...that is f***ing genius. I bet a billet slider (or stainless (easy polishing)) could be machined for the controller that looked like the wiper switch. Know anyone with some tiny end mills?
Devin
New Daily, the '96
Old 09-25-2018, 03:37 PM   #98
RADustin
I'm not settled on steering column colors yet. But I am thinking about it. I'll have a billet steering wheel and a lokar floor shifter for the allison, so the interior won't be completely stock...but I want it to be pretty close. It's a fine line to walk.
I've thought about doing a medium tan leather seats and wrapped dash cover with a matching painted dash/column. But then I wonder what to do on the doors. With the smaller door panels, much of the door is left visible to the interior. I need to search around and look at some more pictures of the early trucks with different interiors and make some decisions. This is something I want to do sooner than later so I can paint the column and finish it out. Right now it is primed though.
the original turn stalk did go forwards/back for high beams. I thought about making mine do that, but gave up on. I'll keep the stock foot high beam switch or I've thought about redesigning the factory headlight switch to have a 3rd detent and high beams be there.
The trailer brake controller should be fun. Haven't started on that at all and won't for a while. Not until after the truck is driving anyways.
1949 Chevy 3100 P/U
Old 10-01-2018, 06:53 PM   #99
tinydb84
tinydb84's Avatar
I hope I have skills like you one day...
David
Instagram: myfabguy
Old 10-04-2018, 12:20 PM   #100
Feel the 'Pane
Incredible build!! ������
Ever have any thoughts on going solo & building aftermarket parts for John Q. Public?
76' GMC K25 Sierra Classic Camper Special: propane powered 350ci/NV4500/205/D44/SRW 14B/4:10/tach,tilt,a/c - daily driver
77' GMC K35 Sierra Grande C/C: 350ci/SM465/205/D60/narrow 14B DRW/4:10
Flatbed
82' Chevrolet K30 C/C: 454ci/SM465/205/D60/narrow 14B DRW/4:56
Flatbed, 6"Rancho, Alcoa's
Feel the 'Pane is offline   Reply With Quote
