Old 03-06-2023, 07:32 PM   #76
Advanced Design
Advanced Design's Avatar
Re: 2wd 1977 Blazer LS swap, mild drop….escalating
I’ve been looking for dry ice blasting alternative for the bottom and am thinking I am going to have to buckle down and clean this the old fashioned way with tons of elbow grease….not looking forward to that.
Advanced Design is offline   Reply With Quote
Old 03-06-2023, 07:33 PM   #77
Advanced Design
Ordering another part tomorrow from a local business……
Old 03-11-2023, 06:13 PM   #78
Advanced Design
Made some stud mounts to weld to the firewall for HVAC mounting and drilled the holes large enough for decent surface area for plug welding.
Old 03-11-2023, 06:25 PM   #79
Advanced Design
And we had fun today, bolting parts back on the engine! Good times….
The ps return tube contacted the frame and a little downward bending resolved the interference.
Mrs A.D. handled the coil and bracket refurbishment. She remounted those and the intake, torquing the bolts to spec.
The AC bracket came with the VA Sure Fit….not a fan of the looks of either, so we will be going a different route on both of those components….. The sure fit items on the firewall and the ac bracket.
Replacement throttle body is on the “gotta order” list too.
Old 03-18-2023, 07:24 PM   #80
Ad Cam
Ad Cam's Avatar
Awesome build! Cool to see another truck from the Land of Lincoln.
Ad Cam is offline   Reply With Quote
Old 03-19-2023, 09:58 AM   #81
oldman3
oldman3's Avatar
Doug, looking good and moving along...Jim
oldman3 is offline   Reply With Quote
Old 03-20-2023, 11:29 AM   #82
youngrodder
youngrodder's Avatar
Hey a complete roller...Wont be long know..
Looks good.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 03-29-2023, 06:29 PM   #83
Advanced Design
Thank you! My office was in Naperville, so I’ve spent a lot of time in your neck of Illinois over the years.
Thanks Jim! We are trying, though the trip to FL a couple weeks ago slowed us down a bit.
Looks good.
Marc
Thanks Marc, we hope so.
The new drive shaft is in. From Inland Empire in CA.
Old 03-29-2023, 06:32 PM   #84
Advanced Design
Seat belts were restored by TKCR, and they worked some magic on them.
Here is a before and several after pictures. The belts came out extremely nice!
Old 03-29-2023, 06:41 PM   #85
Advanced Design
Ran into a young man who started a pressure washing business, and he thought he could clean the floor bottoms to my liking.
He used hot high pressure water, cleansing agents and even steam to get them clean. I am thrilled with the results!
Included a couple before and after pics too.
Old 04-04-2023, 11:58 PM   #86
lower50's
lower50's's Avatar
That's crazy, the seat belts turned out so good. That pressure was guy did a great job.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 04-05-2023, 09:27 AM   #87
youngrodder
Looking good Doug...So nice when they can come to the house. I did something similar to the bottom and interior of the suburban but with a sandblaster.
Marc
Old 04-20-2023, 04:46 PM   #88
OutlawDrifter
Very cool, my favorite color combo! And the hood stripes to boot!
Just got caught up, very cool project
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 04-20-2023, 08:59 PM   #89
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Pretty lucky with the high hump transmission tunnel. With the 6l80e, it wouldn't have unless its tilted down pretty far.
I wonder what the offset on those rotors is. When I did my Wilwood c-10 pro spindle with the same style caliper, I wound up using 12.915"x 30mm thick rotors from a 2006 jeep Cherokee. It does require taking it to the machine shop and having the center hub bored to fit. It was the same thickness as the NNBS brakes so it matched.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 09-30-2023, 04:30 PM   #90
LT7A
What's the latest? Guessing there might be some updates. What a cool rig you found. I want to do whatever I had to do to buy a rig like that if I found it. That color combo with the '77 ochre trim? Dude! I hope you guys are having fun with it.
Old 10-16-2023, 06:02 PM   #91
evan
evan's Avatar
Originally Posted by Advanced Design View Post
While I should have stayed with the factory ac system, I do like the clean look you can have with Vintage Air so we ordered the sure fit system. They make a great product, though I didn’t like the look of the plate that goes over the existing holes.
To avoid using the plate, I filled the holes with 19 gauge by butt weld and metal finishing the shrink as best as possible. It probably would have been cleaner to replace the firewall on that side and maybe less work.
I still need to drill for the ac and heater connections, fill small bolt holes and support the evap case under the dash by welding elevator bolts to the firewall.
Yeah, I should have stayed with the perfectly good factory system.
Hi Doug,
Any chance you'd like to sell the firewall cover plate that came with the Vintage Air kit? I'm doing the same thing with welded studs inside for a smooth firewall. I'm doing the bodywork now and they're estimating January delivery for the kit. I called them direct but they don't offer a digital or paper template, the firewall cover it's self is the only method they have for locating the 1/4-20 mounting bolts.
Evan B.
evan is offline   Reply With Quote
Old 10-17-2023, 12:51 PM   #92
SCOTI
SCOTI's Avatar
Just read through this build thread. Nice stuff going on here. Looks like this will be a great cruiser based on that very solid starting point.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-12-2024, 06:22 PM   #93
TotallyHucked
TotallyHucked's Avatar
Man, that was a really cool truck you guys scooped up! Hope all is well and the build is still progressing
1985 GMC Sierra Classic
Chopped down wrongbed
Cammed LH6 5.3/T56/3.90
Walker Tuned
5/8 drop
US Mags
TotallyHucked is offline   Reply With Quote
Old 01-16-2024, 04:54 PM   #94
LT7A
It appears that Elvis has exited the building. I don't know Mr. AD personally and so I don't know the circumstances but it appears he hasn't been on here since last April. It's too bad, I would like to be seeing what's happening with this rig. I hope all is well.
Old 04-11-2024, 05:59 PM   #95
Advanced Design
Originally Posted by evan View Post
Hi Doug,
Evan, I am so sorry I hadn’t responded! That is how I located the mounting location on the firewall for the HVAC case as well. If you still need it let me know. Thank you!
And guys thanks for checking on me. I’ve been on other car and property projects…plus did some traveling and vacationing. Took too much time off from Blazer build. Helped my Grandson on rear diff for his 1998 Camaro.
Enjoying life and pursuing vehicles.
Old 04-12-2024, 09:08 AM   #96
SCOTI
SCOTI's Avatar
That's Life. Good to see you're still kickin'.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-16-2024, 08:33 PM   #97
mongocanfly
Post Whore
mongocanfly's Avatar
X2..!!!!!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
