04-19-2019, 07:55 AM | #976 |
Re: "Project Orangepeel" 52 A.D
Good looking progress....The firewall looks great.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
04-24-2019, 09:00 AM | #977 |
Thanks Marc!
Pic 1. The inner fenders were painted with POR. Pic 2. The top sides as well, these will not stay shiny they will flatten out. Pic 3. Then were sprayed on top side with high build primer.
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
04-24-2019, 06:59 PM | #978 |
Nice work as always
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
04-25-2019, 07:38 AM | #979 |
Thank You!!
04-25-2019, 02:02 PM | #980 |
great work, its fun to see the vision coming together!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
04-25-2019, 04:00 PM | #981 |
Always admiring your work quality and progress Mark!
04-26-2019, 08:31 AM | #982 |
Thanks Russ, Thanks Doug!!
04-26-2019, 08:37 AM | #983 |
Here are a few shots of the fenders.
Pics 1-3 are the roughed in filler and primer, starting to take shape. Pic 4. The passenger side after being sanded and primed again, this one is really close and almost ready for paint. The fenders will be then blended and aged to hopefully match! Mark
04-26-2019, 08:39 AM | #984 |
Looking good!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
04-26-2019, 01:19 PM | #985 |
Nice work!!
As always!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
04-27-2019, 08:32 AM | #986 |
Thank you Guys!!
Mark
05-06-2019, 07:52 AM | #987 |
Back with some few more shots.
The grey primer is 202 high build reduced to 4:1:1 and lays out super smooth and is my final primer. This will be wet sanded with 600 and ready for paint. Cab corner got some work done as well and has one more round before the grey goes on. The viser....this was simply scrubbed with soapy water and scotch bright pad. Mark
05-06-2019, 08:25 AM | #988 |
Looks good.
BTW, what brake master cylinder are you using that uses 2 bolts?
05-06-2019, 06:45 PM | #989 |
8man, thank you sir!
I'm using a wilwood master.
05-10-2019, 08:18 AM | #990 |
Update:
Was able to get the front fenders sprayed with the orange. It matches pretty good, will start the aging process next. Mark
05-10-2019, 08:29 AM | #991 |
Nice fender stands. Looks good.
05-10-2019, 10:23 AM | #992 |
Looks great - fenders look like they came that way with the new buckets! Are you just spraying a flat? or base, no clear? I'm interested to see how this goes with the aging. Maybe a few brake fluid spills where there is no bondo to get the blistering!
Scott ______________ my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979 |
05-10-2019, 12:25 PM | #993 |
Post Whore
Paint color looks great Mark!!!...
A friend just did his 66 patina wagon ...he had to color match a fender,the roof and a couple patch panels....I was amazed at how well it turned out...I'm also curious to see how you do yours..
05-11-2019, 02:55 AM | #994 |
orange! man its my favorite color. looks great!
05-11-2019, 08:30 AM | #995 |
8man Thank You. Dad made the stands way back when he was building his truck!
Mark
05-11-2019, 08:39 AM | #996 |
Scott2 Thank You, I am really happy with the way the buckets came out.
The paint: I'm using is a single stage enamel I mix it 4:1 (color,reducer) and then added 25% flatting agent to the mix to get the same look of the old paint. Aging: I have some ideas floating around my head and will do some experiments before I go 100% on it. Mark
05-11-2019, 08:42 AM | #997 |
Greg and joedoh, Thank's Guy's!
05-11-2019, 08:48 AM | #998 |
After you are done, would you mind posting a picture of that fender stand?
05-12-2019, 08:53 AM | #999 |
no problem
05-12-2019, 09:51 AM | #1000 |
Fenders look great! I'm anxious to see it all back together.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
