#1201 |
Re: Slosh Tubz SEMA 2015 Build "BOOSTED BERTHA"
Bar, One notch higher is set it is.
#1202 | |||||
67cheby
![]() Join Date: Sep 2008
thanks man Quote:
thanks Bomp ! |
#1203 |
67cheby
This interior is kicking my butt and wasting a lot of valuable time, I am trying to come up with a clean / custom door panel and like I said before I am certainly no interior design guy !
#1204 |
those panels are huge and its realy hard to make sumtin that makes it look less bulky
been thinking about mine for a while ('86 squarebody doors ) , i think the best option would be to use google pictures and just look wat will work too bad the dash is not comming intoo the interior or else you couldve shaped it intoo the doorpanels and have them flow down intoo doorholds and intoo armrests making cardholders in the bottom might break it up a little too , if theres room below the window mecanism you could have the pockets inside the doors
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#1205 |
![]() Join Date: Jan 2015
BOY! am I late to the party!!! looks feakin awsome!
#1206 | |
67cheby
Thanks man ! |
#1207 |
I think a door pocket in the bottom would break it up a bit . The one in my work van is handy . You could also trim it like the dash to tie it all in . But I am sure whatever you do will look great .
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=611614 |
#1208 |
67cheby
how about some weekend progress I started by working on the kick panels to house the Kicker mids and highs. I first stretched and glued on the fleece next applied a coat of resin once that was dry I sanded it down and knocked off the high spots to get it ready for a second coat of resin. When the second coat dried I knocked that down and added some fiberglass filler to the low spots.....next will be covering them with that beautiful Relicate Leather.....if I am brave enough to attempt it ! LOL
#1209 |
67cheby
next I did a little work starting to get the dash padded and the dash cover fitted. I also started installing the custom made defrost vents that Trique Mfg made to match several of the other interior patterns !
#1210 |
67cheby
the last project that I was able to work on for the weekend was shortening the factory tilt column, I had a beautiful aftermarket column but it pushed the steering wheel way to close to the driver. I took the factory column and thanks to the forum I was able to figure out how to disassemble and it and then I took 3 1/2 inches out of the column shaft , shifter tube and steering shaft. The only other thing to do was to figure out how to make it go though my firewall ball mount with the shifting arm attached.....obviously that would work so I made the shifting arm removable from the shifting shaft. A couple new parts and some body and paint work and we should be good to go !
#1211 |
![]() Join Date: Oct 2009
thats some good noodling there... guess i'll keep the columns around for another build but i still really like Mexican food. maybe a trip your way needs to be planned...
#1212 |
67cheby
I do still need that one column nut....just sayin
#1213 |
Dang, choppin down a factory tilt column.
That takes guts, Thats what I love about your style. Nothing holds you back. |
#1214 |
67cheby
I am to dumb for anything to scare me ! LOL.....although I have never been brave enough to stretch my doors...just sayin !
#1215 |
found 3 later model columns but only 1 tilt... any help?
#1216 |
67cheby
There is the one nut that holds on the steering wheel and then about 1 1/2 inches further down the shaft is one more nut that has fine thread that is the one that I need
#1217 |
dont know if it works on the older trucks :
http://www.gmt400.com/threads/xj-ste...page-31.12087/
#1218 |
67cheby
Boosted Bertha is going to be set up with Kicker Audio at Lonestar ThrowDown so I have been trying to make sure that we have this system setup nice and clean. That being said making a trim panel to fit around everything that it must fit around and getting the right contours was quite a job....but it is done now and ready to go to upholstery.
#1219 |
I'm just glad to be here!
Can't wait to see here there!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#1220 |
just found this build this morning just got done reading 49 pages. very nice build! love seeing this interior coming together. very nice work!
#1221 |
67cheby
its going to be a great show, last year was Awesome !
WOW, thanks man ! |
#1222 |
6>8 Plugless........
![]() Join Date: Sep 2007
Great work! That interior is goign to be awesome!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#1223 |
67cheby
Well.....we are still plugging away at this interior ! I built a couple mdf frames to go around the areas that I wanted to insert then stretched fleece over it. The next step was laying down a couple coats of resin, sanding that smooth and starting back over with body filler. Once again I state that I am no interior guy there is probably a much better way to do this but I am just doing what I know.
#1224 |
looks good , maibe if they come out looking realy nice you can have moulds taken of them and sell them along with the slosh tubs
you could have them vacuum moulded out of 1 mm sheet abs plastic wish is available in different colours too https://www.youtube.com/watch?v=I3LVPRHmkcU this one is small but you can make the vacuumbox as big as you need and add some of those paintshop heatlamps or electric oven elements to soften the plastic or go professional https://www.youtube.com/watch?v=VFQ6R85puS0
#1225 |
Sorry Mike but you ARE officially an "interior guy". Looks like fun and I'm sure it'll look fantastic when you're done.
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 ![]() |
