Old 05-03-2016, 07:54 PM   #101
hevymetl
Re: HOW TO: Split the brake lines (many have asked)
So I finally got to doing my swap over today. Took me a good hour of driving around getting more fittings to make it happen. Couldn't find the proper plug for the T so I just eliminated it and used a union. Anyway, I got everything in and bench bled the new master with no problems. I measured the new master and the depth of where the pushrod goes in and it was identical to old one. So I assumed I didn't need to mess with pushrod. I didn't get a chance to bleed the brakes yet but currently have no pedal whatsoever. Is this a bad sign?
hevymetl is offline   Reply With Quote
Old 05-03-2016, 08:04 PM   #102
padresag
an unbled system will have no pedal
ron
padresag is offline   Reply With Quote
Old 05-03-2016, 08:15 PM   #103
hevymetl
That's what I was hoping to hear. I'll report back once I've bled it all out. Thank you for the response.
Old 05-03-2016, 10:15 PM   #104
reed62
reed62's Avatar
Originally Posted by ChiefRocka View Post
These reference pics show clearance of lines using a SB and Huggers:
The new crossmember line can be installed with engine installed...these shot were taken when engine was out.
The front feed line was installed after the engine was in:
The second line (pictured above) was ran down to the original first tee.
The push rod was also modified for this MC.
Pics to follow...
Chief,
Did you use bed liner on your inner fenders? It looks really nice. Great idea.
reed62 is offline   Reply With Quote
Old 05-11-2016, 09:55 PM   #105
hevymetl
A big thanks to all the contributors to this thread. I bled everything and it works great! On to the next mission.
Old 05-12-2016, 04:17 PM   #106
truckeroy
truckeroy's Avatar
I did this conversion to a 64 a few years ago and last year to my current 64. I hooked everything up like in the thread mentioned. I never did get the pedal height I like. I have done a little research and in my 1971 Chilton manual under the Camaro/Chevelle section there is a drawing of a "typical" 67-70 master cylinder. It shows the front port to the front wheels and the rear port to the rear wheels. It states- "Since 1967, a dual type master cylinder is used. The front portion of the master cylinder supplies hydraulic pressure for the front wheels. Pressure for the rear wheel brake application is supplied from the rear portion of the master cylinder." I just switched my lines and have more pedal now. I still have to re bleed the lines because I may have gotten some air in while switching the lines. I'm using a 70 truck booster/mc set up.
1948 Chevy 1/2T
1964 Chevy 1/2T stepside short bed
1939 Pontiac coupe Street Rod
2005 GMC 1/2T short bed
truckeroy is offline   Reply With Quote
Old 05-12-2016, 10:06 PM   #107
jayoldschool
Moderator
That's what Captainfab has always posted, too.
jayoldschool is offline   Reply With Quote
Old 05-12-2016, 10:11 PM   #108
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I'll have to try switching mine.
My pedal height isn't what I'd like it to be.
66 C20 Service Truck:
Old 06-11-2016, 04:25 AM   #109
La Zona Imagery
What size fittings are needed? I read this thread 3 times, but I must have missed it?
1965 Chevy C-10 350 V8
2003 GMC Sierra Crew Cab 6.0L 4x4
La Zona Imagery is offline   Reply With Quote
Old 06-11-2016, 04:41 AM   #110
padresag
different fittings for different places. depends on what size line etc
ron
Old 06-11-2016, 12:15 PM   #111
jayoldschool
Moderator
I did this on Friday. Brought my master in to the parts place, sat on the floor for an hour digging through bins to get the fittings perfect without adapters.
Old 06-11-2016, 12:52 PM   #112
kippnidaho
kippnidaho's Avatar
Just to clarify..
The front of the master cylinder goes to the front brakes and rear to rear brakes?
KippnIdaho
Twin Lakes, Idaho
1966 K10 SWB Stepside
2003 Jeep Rubicon
2011 Camaro SS Rag Top
kippnidaho is offline   Reply With Quote
Old 06-11-2016, 01:20 PM   #113
notsolo
notsolo's Avatar
Nope Other way....... The REAR PORT, closest to the PUSHROD is the main, or "primary" chamber.
This port is for the FRONT brakes....
The FRONT PORT, furthest from the PUSHROD is the secondary chamber....supplying the REAR brakes.
Attached Imageshttp://67-72chevytrucks.com/vboard/attachment.php?attachmentid=796539&stc=1&d=1315233781
notsolo is offline   Reply With Quote
Old 06-11-2016, 03:04 PM   #114
jayoldschool
Moderator
On later disc brake systems, that is correct. On our drum/drum setup, the front port is for the front wheels.
See post #106
Old 06-11-2016, 06:34 PM   #115
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
3/16" and 1/4" inverted flare....unless your going with 37, then -3/-4
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 06-11-2016, 07:01 PM   #116
jayoldschool
Moderator
Yes, my 65 C10 was 1/4 to the fronts, then 3/16 to the rear from the T. So, I ran 1/4 from the master to the fronts, and 3/16 all the way to the back
Can't wait to drive it again! I'm doing a bathroom reno, and I need my truck!
Old 06-11-2016, 07:17 PM   #117
jayoldschool
Moderator
Here we go. This should settle it once and for all. For DRUM/DRUM applications, using a dual master (like the 67 C10/Impala unit), the FRONT port goes to the FRONT brakes.
Old 06-17-2016, 04:01 AM   #118
La Zona Imagery
I am confused about the push rod issue. I have a 65 C10 with the original MC.
Is there something I have to do with the push rod? I am confused.
Old 06-17-2016, 06:06 AM   #119
Mike Wessinger
Mike Wessinger's Avatar
If you do not add a power booster you should not need to do anything with the push rod. I changed my single to a dual, no booster, and it bolted right up and used the original push rod.
1965 Chevy C10 Stepside Shortbed--2012 370Z Base Gun Metallic--2020 Chevy Silverado RST Crew Cab
Mike Wessinger is offline   Reply With Quote
Old 06-17-2016, 01:21 PM   #120
La Zona Imagery
Oh ok thanks, that's what I plan to do this weekend. Just wanted to make sure before I start therjob.
Old 06-17-2016, 07:33 PM   #121
jayoldschool
Moderator
I did not do anything with my push rod.
Drove my truck a lot yesterday, including urban rush hour, and the brakes are great. Don't hesitate, do this swap.
Old 07-02-2016, 11:57 AM   #122
La Zona Imagery
Yea I am safer now! Thanks for the infos everybody!
Old 07-02-2016, 02:14 PM   #123
jayoldschool
Moderator
Looks like that front port line is smaller. Do you have that going to the rear wheels? If so, you need to swap it to the rear port.
Old 07-02-2016, 05:46 PM   #124
La Zona Imagery
My front port goes to the front brakes.
Old 08-14-2016, 04:39 PM   #125
Brim
Brim's Avatar
What's going on everyone? Got a question, Im installing a dual m/c on my 64 c10 with booster and I have taken off my m/c a couple of times, each time I do the push rod and brake pedal moves in out freely. Once installed (the lines are not connected) the pedal does not move downward to bleed my brakes...? Even if the lines are connected I get the same results.
Im using a doorman part #M76162, with the original single jar push rod. The m/c has been bench bled. I noticed when installing it I have to push the m/c piston in against the rod in able for it to reach the bolts before I can screw the nuts on. I think my piston is bottoming out and acting like the brake pedal is engaged. This is why the brake pedal will not travel. Am I on the right track with this assumption and if so how can it be fixed?
Also I replaced all my lines with a kit from inline tube. Keeping the exact original setup. I then realized I cannot run both lines into the same tee. Looks like I will have to add an additional line just for the brake line that feeds the rear ones and cap off a tee somewhere. So that the lines can be connected properly (Rear bowl to Front Brake Line - Front bowl to Rear Brake Line). Any info or help on the push rod and lines would be appreciated.
Thanks,
Brim
Brim is offline   Reply With Quote
