02-14-2012, 09:52 PM | #101 |
Re: '49 chevy with s-10
Got some more time to work on the brake lines. Finally finished the frame part. fixn to start on the accuair for the chassis.
02-14-2012, 10:04 PM | #102 |
Looks very nice. Straight as an arrow......
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
02-15-2012, 11:03 PM | #103 |
Looking great!
What paint did you use on the chassis and components?
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
02-16-2012, 09:53 AM | #104 |
02-16-2012, 11:44 AM | #105 |
looking good
Justin |
02-16-2012, 11:47 AM | #106 |
SSN 706
I guess you'll have to rasie the front and drop the rear to drain your tank? Build is coming along nice.
02-16-2012, 06:54 PM | #107 |
You know, i didnt even think about the drain on the tanks when i mounted them, just thought they looked cool there and gave me lots of room for exhaust. Thanks for pointing that out i will fix that little problem.
02-16-2012, 08:02 PM | #108 |
SSN 706
I'll bet you could get it level just by messing with the air in your bags. Or you could do some welding and grinding and stuff and stuff. Your right it does look cool.
02-19-2012, 03:21 AM | #109 |
Rollinrooster , you have some serious skills my man This is an awesome build !!! Im curious as to the throttle and brake pedals and how they end up. I will patiently wait to see I guess Again, Awesome job
72 C20 Longbed 05 1500 Z71 |
02-19-2012, 08:23 AM | #110 |
Rollinrooster,
Very nice and accurate install on those brake lines. They couldn't be mistaken for a novice install, that's for sure. Keep up the excellent work! Fab1 |
02-19-2012, 09:39 AM | #111 | |
Thanks alot, this is my first time doing a frame swap. As for the throttle / brakes im going to use lokar lakester gas and brake pedals and a scottshotrods 90 degree under dash brake set up. |
02-19-2012, 09:49 AM | #112 | |
You know, that was my first time ever doing brake lines. A very good friend of mine ownes a hotrod shop (PrecisionRod and Custom). He let me borrow some brake line tools and gave me some advice to get started with. Youre not to far away in Kingsport, and are welcome to stop by anytime just pm me. |
02-19-2012, 06:12 PM | #113 | |
I just went through brakes in my class, part of it the students had to make brake lines. I had them do mine I only wish they had turned out as good as yours, you get and At in my book, excellent job. Joe
http://67-72chevytrucks.com/vboard/s...d.php?t=413926 http://youtu.be/Qe9xJUhWkWc |
02-19-2012, 07:56 PM | #114 | |
02-22-2012, 01:09 PM | #115 | |
Thanks for the kind words, i wish i had someone to do mine. |
02-23-2012, 10:14 PM | #116 |
Got some front shocks on the cheap!! thanks to daverod. Just need to finish mounting them.
02-23-2012, 10:43 PM | #117 |
rollinrooster, Chassis looks great. I am glad to see how someone is mounting there shocks when they are bagged. I figured it would look something like that. Keep up the great work.
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
02-24-2012, 11:58 AM | #118 |
SSN 706
Very nice. Did you see how the bottom of mine mounted? Kinda of a u shaped thing that the shock stud mounts into. Made it alittle easier to get in the right spot. Had to move mine a few times. I got them to fit without wheels spacers but I think I will buy some spacers anyways. Kinda depends on what wheels I get.
02-26-2012, 09:56 AM | #119 | |
02-26-2012, 12:52 PM | #120 |
SSN 706
Are the spacers 1". Where did you buy them? I think I'll get some.
02-26-2012, 01:09 PM | #121 |
Absolutely beautiful. Kudos on the super clean details. I've seen a lot of AD's on S10's and yours is one of the best I've ever seen. When viewed from the side the wheel base is perfect for the fender openings (rare on an AD/S10). Also, the wheels suit it perfect. Love it.
02-26-2012, 11:09 PM | #122 |
02-26-2012, 11:13 PM | #123 |
Are you running your air lines down the inside of your frame from your front?
02-27-2012, 09:07 AM | #124 |
02-27-2012, 10:44 AM | #125 |
SSN 706
You'll love it. Best thing is it so easy. Remember to plug in one intake if you don't use it. Make sure your grounds are good. Did you get the switch too.
