Old 06-04-2011, 07:50 PM   #101
Bodenimus
Re: (( 1960-1966 Chevy/GMC Pickup Truck Restoration/Modification/Customization Ideas
Wow! These trucks are so far out of my league that I don't know where to start. I have a '66 Chevy C10 SWB pickup that I just want to replace the engine in. It currently has the 250 six cylinder and I want to put a V8 in it. I am not a mechanic and I don't even know where to start ( such as what motor will fit without rebuilding the whole truck ). This truck will be just for everyday driving, not a showpiece. I guess I just want suggestions or comments from someone who has been there before and knows what all I am going to encounter. I have owned the truck for 38 years and it is in very good condition, just needs a new motor. Any help that you may provide will be greatly appreciated.
Bodenimus is offline   Reply With Quote
Old 06-04-2011, 08:28 PM   #102
jocko
jocko's Avatar
For V8 options, 66 came stock with a 283 or 327, so any small block chevy will easily fit (and all accessories, etc are easily available) - so, 283, 327, 307, 305, 350. Easiest is a 350 since they practically grow on trees, but a 283/327 of somewhere mid-60's vintage is a cool addition. If you're not up for a rebuild yourself of the junkyard small block, a crate engine is probably right up your alley. In addition to the above stock cubes, crate motors are generally found in a 350 or 355 (bored 350) or 383 (bored/stroked 350). If you go crate, 383 is a vrery good option. Recommend a head to toe (carb to pan) running engine since you you won't have the add-ons (water pump, distrib, manifold, carb, etc etc) to swap from you 6 cyl. You may still need to do a little shopping (or a large swap meet usually has refurbished ones) for some a/c, alternator, and power steering pump brackets (if you're running any of the upgrades like ps/a/c, etc). You will need V8 motor mounts, and they should bolt right into your frame and onto about any small block. Personally, I'd swap the tranny out too - if you're looking for a driving machine - the powerslide auto or stock 3/4-speeds leave a little to be desired in my opinion. Remember, you've always got the forum to ask the stumpers you run into - guaranteed someone on here has an answer. No guarantee it's the RIGHT answer, but, you get the idea... Only way to learn is to dive in. Sounds like a blast, good luck!
Old 06-04-2011, 09:25 PM   #103
markeb01
Senior Enthusiast
markeb01's Avatar
And welcome to the forum!
Old 06-05-2011, 11:32 AM   #104
Bodenimus
Hey thanks for the information. That is exactly what I was looking for. One other question (for now anyway). If I choose to go with the 350 engine which seems to make the most sense, do I need to get a wiring harness for that engine since it will probably be totally different from the exixting 6 cylinder.
Old 07-11-2011, 11:12 AM   #105
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Exclamation Re: (( 1960-1966 Chevy/GMC Pickup Truck Restoration/Modification/Customization Ideas
Originally Posted by 1Bad62Pro/Street View Post
Frizzle Fry
http://67-72chevytrucks.com/vboard/s...91#post4783691
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 07-16-2011, 04:00 PM   #106
1Bad62Pro/Street
Talking Re: (( 1960-1966 Chevy/GMC Pickup Truck Restoration/Modification/Customization Ideas
67' - 70' Stepside Rear Bumper
Old 08-12-2011, 11:25 PM   #107
1Bad62Pro/Street
Customized to the max:
Old 08-12-2011, 11:34 PM   #108
1Bad62Pro/Street
Convertible:
Old 08-12-2011, 11:34 PM   #109
markeb01
Senior Enthusiast
markeb01's Avatar
Here are a couple more pictures of the same truck, before the grille/headlight changes, and addition of the hood ornament. Reminds me of some of the earliest model kits I built as a kid.
Old 08-12-2011, 11:52 PM   #110
1Bad62Pro/Street
2" Chopped '62
http://chaoticustoms.com/content/vie...t.cfm?GalID=44
Old 08-13-2011, 12:18 AM   #111
1Bad62Pro/Street
Carpet dash???
That steering wheel has to go!!!
http://fortwayne.ebayclassifieds.com...ck/?ad=8813615
Old 09-07-2011, 09:00 PM   #112
1Bad62Pro/Street
Thumbs up Re: (( 1960-1966 Chevy/GMC Pickup Truck Restoration/Modification/Customization Ideas
'60-'66 Body On A '73-'87 Frame
Captainfab
http://67-72chevytrucks.com/vboard/s...d.php?t=481023
Old 09-07-2011, 09:33 PM   #113
Max1775
Max1775's Avatar
The PT truck is just sick...
Max1775 is offline   Reply With Quote
Old 09-18-2011, 01:08 AM   #114
Slow Build
Slow Build's Avatar
Saw this on a 64 at Billetproof California today. It's subtle and it's more practical than attractive, though I think it looks good.
Check out the screening below the cowl.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 09-18-2011, 01:18 AM   #115
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Maybe painted an accent color, or matching the body paint would be better. It doesn't look bad, but could possibly be better. Any pictures of the whole truck?
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 09-18-2011, 02:03 AM   #116
Slow Build
Slow Build's Avatar
Thought you would never ask.
Past GM Trucks:
Old 09-18-2011, 02:11 AM   #117
Slow Build
Slow Build's Avatar
A few more.
Past GM Trucks:
Old 09-18-2011, 02:25 AM   #118
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
^How Clean is That!
66 C20 Service Truck:
Old 09-18-2011, 11:25 AM   #119
markeb01
Senior Enthusiast
markeb01's Avatar
That is one of the most amazingly detailed trucks I've ever seen.
Old 09-18-2011, 01:29 PM   #120
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
WOW, that is a beautiful truck!!!
Jason
Old 11-22-2011, 09:57 AM   #121
1Bad62Pro/Street
Arrow Re: (( 1960-1966 Chevy/GMC Pickup Truck Restoration/Modification/Customization Ideas
http://www.customclassictrucks.com/e...w/viewall.html
Old 11-29-2011, 07:50 PM   #122
1Bad62Pro/Street
A wild '55 Chevy Kustom at the Long Beach Motorama 2011
Not a 60-66........ But you get the idea on the customized bed!
http://67-72chevytrucks.com/vboard/s...48#post5038048
Old 12-04-2011, 10:32 AM   #123
brawley
Easy Does It
brawley's Avatar
Filling the seams along bedsides and hood. I did this to mine -I think it looks alot smoother/ cleaner. Also filled in the turn signal holes and stake pockets.
brawley is offline   Reply With Quote
Old 01-11-2012, 04:55 PM   #124
1Bad62Pro/Street
Altered Stepside Bed and Tilt/Dump Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Impala bumper '62:
http://67-72chevytrucks.com/vboard/s...d.php?t=502690
Old 01-11-2012, 05:19 PM   #125
forestb
forestb's Avatar
Hay is not that blue truck the same one that they are building in Custom Classic Trucks?
forestb is offline   Reply With Quote
